Arduino Uno not taking code
Goto page 1, 2  Next
Neptune769
PostPosted: Sat Apr 30, 2016 2:31 am    Post subject: Arduino Uno not taking code Reply with quote
Hello Everyone,
I have been away for several years. I just found out that Bascom can be used on Arduino hardware. I copied some code to test. When I compile it, it is okay. However when I try to program the Arduino the TX & RX LEDs flash as if it is sending the program. But it doesn't work like it should. Can anyone tell me what the problem could be? I would appreciate any help. The code I wanted to test is below.
Thank you,
Dennis L.
$regfile = "m328pdef.dat"
$crystal = 16000000
Config Clockdiv = 1
Config Pinb.5 = Output
Set Portb.5
Waitms 200
Reset Portb.5
Waitms 500
bzijlstra
Bascom Ambassador
PostPosted: Sat Apr 30, 2016 11:34 am    Post subject: Port... Reply with quote
Try config portb.5 = output
Neptune769
PostPosted: Sun May 01, 2016 5:54 pm    Post subject: Reply with quote
Thanks for the reply. However it still not working.
bzijlstra
Bascom Ambassador
PostPosted: Sun May 01, 2016 6:03 pm    Post subject: Stacks... Reply with quote
Where are the lines
Hwstack
Swstack
Framesize
Try it without the config clockdiv
There are two Arduino options to program, which one do you use and at what baudrate?
What Bascom-AVR version are you using?
JP Duval wrote a small instruction how to program the Arduinos.
Have fun
Ben Zijlstra
Neptune769
PostPosted: Sun May 01, 2016 6:24 pm    Post subject: Re: Stacks... Reply with quote
bzijlstra wrote:
Where are the lines
Hwstack
Swstack
Framesize
Have fun
Ben Zijlstra
Hi Ben,
I copied the code from the thread "getting started with Arduino and bascom" by Duval JP. The Hwstack, Swstack & Framesize were not in the code. I wouldn't know what numbers to enter for those.
I will try it without the config clockdiv.
I am using the USB port on the Arduino to program with Programmer set to Arduino with baud rate to 115200 as shown in the zip file from Duval JP.
I am using Bascom ver. 2.0.7.5
Thanks for your help.
bzijlstra
Bascom Ambassador
PostPosted: Sun May 01, 2016 9:10 pm    Post subject: add stacks... Reply with quote
Add
$hwstack = 40
$swstack = 40
$framesize = 40
Checked, the test led of the Arduino Uno is on Portb.5
If we can not fix it, it is time for JP Duval to have a look Cool
Have fun
Ben Zijlstra
Neptune769
PostPosted: Sun May 01, 2016 9:29 pm    Post subject: Re: add stacks... Reply with quote
bzijlstra wrote:
Add
$hwstack = 40
$swstack = 40
$framesize = 40
Have fun
Ben Zijlstra
I added the three lines to the code. It is still not working. I appreciate the help. The code is below.
$hwstack = 40
$swstack = 40
$framesize = 40
$crystal = 16000000
'Config Clockdiv = 1
Config Portb.5 = Output
Set Portb.5
Waitms 200
Reset Portb.5
Waitms 500
PostPosted: Mon May 02, 2016 11:19 am    Post subject: Reply with quote
Ok
The test program I posted been tested, it works.
Have test you the blink example given by Arduino?
Have you tested the led electrically?
is it an official UNO? copies are not controlled, the led may be upside down?
the USB connection is the serial port, you can try "print" and test it with the terminal emulator
as below:
' ARDUINO-UNO V3.BAS
' (c) 1995-2011, MCS Electronics
' This is a sample file for the Mega328P based ARDUINO board
' Select Programmer 'ARDUINO' , 115200 baud and the proper COM port timeout 200
$regfile = "M328pdef.dat"
$crystal = 16000000
$hwstack = 128
$swstack = 64
$framesize = 128
$baud = 57600
' les config----------------------------------------------------------------------
Config Clockdiv = 1 'par défaut le M328 utilise une clock diviser par 8
Set Portb.5
Print "led = 1"
Wait 1
Reset Portb.5
Wait 1
Print "led = 0"
End 'end program
JP Wink
Neptune769
PostPosted: Mon May 02, 2016 11:19 pm    Post subject: Reply with quote
Duval JP wrote:
Ok
as below:
Hi Duval,
There is a program on the Uno that makes an LED fade on & off. That was done with the Arduino IDE so that When the above program is working I will see the difference. That works fine. I have tried it on 3 Unos 1 Official and two copies. They all do the same thing. The LED is good.
Paulvk
PostPosted: Tue May 03, 2016 10:36 am    Post subject: Reply with quote
Neptune769
Did you copy and paste Duval JP program
Does bascom show you your chip in the programming screen
Regards Paul
aphawk
PostPosted: Tue May 03, 2016 3:16 pm    Post subject: Reply with quote
I can confirm that Duval's program works ok.
I use AVRDUDE commands as a command line in Bascom's Programmer Configurations to write to Arduino Uno, for more than 2 years this works very well.
Paulo
Neptune769
PostPosted: Wed May 04, 2016 12:52 am    Post subject: Reply with quote
Paulvk wrote:
Neptune769
Regards Paul
Hi Paul,
Yes I copy and pasted the code. Also the chip is listed in the Bascom Options under the Compiler, Chip tabs.
I attached a screen capture.
Thank you,
Neptune769
PostPosted: Wed May 04, 2016 12:57 am    Post subject: Reply with quote
Paulo
aphawk,
Thanks for the info.
Paulvk
PostPosted: Wed May 04, 2016 10:07 am    Post subject: Reply with quote
Hello Neptune769
No not that screen
The bascom program chip screen (F4) on key board
Regards Paul
PostPosted: Wed May 04, 2016 6:27 pm    Post subject: Reply with quote
I dont understand because this programm works with Win XP, WIN7, win10
did you look where your arduino is connected : com?
JP Question
Goto page 1, 2  Next
Page 1 of 2
