I2C ERAM 24C256 - A little help needed
twenty13
PostPosted: Wed May 03, 2017 10:09 am    Post subject: I2C ERAM 24C256 - A little help needed Reply with quote
The code below does not work. I am not sure how to configure for ERAM with XMEGA. I have changed the EEPROM address in the lib file to suit that of my EEPROM. I have also tried "Open "twic" For Binary As #1" The EEPROM is working fine with the normal routines. Any help will be much appreciated
Regards,
$regfile = "xm128a1def.dat"
$crystal = 32000000
$hwstack = 512
$swstack = 512
$framesize = 512
Config Sysclock = 32mhz
Config Com1 = 56000 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Open "COM1:" For Binary As #1
$eepromsize = &H8000
Config Submode = New
Config Base = 0
Config Eeprom = Mapped
Dim Twi_start As Byte
Dim D As Byte
Dim C As Byte
Dim E As Byte
Dim B As Byte
Dim A(10 , 10) As Eram Byte
$lib "fm24c64_256.lib"
Config Scl = Portc.1                                        ' we need to provide the SCL pin name
Config Sda = Portc.0                                        ' we need to provide the SDA pin name
Config Twi = 4000000
I2cinit
  Print#1 , "Write Eram"
   For C = 0 To 1
       For D = 0 To 23
       E = D * 2
       A(c , D) = E
       Next D
   Next C
   Print#1 , "Eram written..."
   Print#1 , "Read eram"
   For C = 0 To 1
       For D = 0 To 23
       B = A(c , D)
       Print#1 , B
       Waitms 100
       Next D
   Next C
   Print#1 , "Eram read..."
[/list]
