Posted: Fri Aug 20, 2004 6:59 am Post subject: port bin set and reset or cbi sbi in asm without config port
I am using the portd.0 for data input (Hardware rx input)
so can I using the portd (EXCEPT PORTD.0 pin ) for controlling relay or other devices with the set and reset command or asembler sbi,cbi commant without config portd = outbut
If I am use the config portd = output
I am not using the data input for
portd.0 is right ?
Posted: Fri Aug 20, 2004 2:45 pm Post subject: Re: port bin set and reset or cbi sbi in asm without config
I am not using the data input for portd.0 is right ?
Yes you are right.
you can set individual inputs or outputs as described, or in asm
sbi ddrd, 1'set bit in i/o (output) data direction register port d.1
cbi ddrd, 0' clear bit in i/o (input)....portd.0 or in one hit
ldi r16, &B01111111
outddrd, r16
