Posted: Fri Jan 15, 2016 3:26 pm Post subject: Thingspeak field update example |
Hello. This code is only example and I post it because it work
Code react if "WIFI GOT IP" string is detected.
I use Xmega because voltage levels but any micro with enough SRAM should work
Also I test this for someone else and it took me some time to figure out every important "https /NOT htttp, spaces etc."
It will be nice someday if we just can type " my interest" in search engine and solution will pop up
You can look how this code work on YT (short video but live update on Thingspeak) https://www.youtube.com/watch?v=AAJZ240QjdE
I`m not string parser master so anyone can wrote own code. This is working example.
Code: | '****************************************************************
'* UPDATING THINGSPEAK FIELD WITH ESP8266 AND XMEGA *
'* ESP8266 AT COMMANDS V.051 SDK 1.5.0 *
'* BARTek niveasoft(at)tlen.pl *
$regfile = "xm128a3udef.dat"
$crystal = 32000000 '32MHz
$hwstack = 80 'this is for my other tasks so
$swstack = 100 'you can modify values to your needs
$framesize = 100
Config Submode = New
Const Api_key = "ABCDEFGHIJKLMNOP" '' <<<<< YOUR API WRITE KEY
Const Debuging = 1
' ***************** SYSTEM CLOCK CONFIG **************************
' INTERNAL 32MHz NO PRESCALE
' ENABLING AUTOMATIC OSCILLATOR CALIBRATION
Osc_dfllctrl.0 = 1
Dfllrc32m_ctrl.0 = 1
'************ CONFIGURATION FOR COM1 ON PORTC ********************
' ESP8266 ON COM1
Config Com1 = 115200 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8 'Tx-PC3 Rx-PC2
Open "COM1:" For Binary As # 1
Config Serialin0 = Buffered , Size = 100 'for COM1
Config Input1 = Crlf , Echo = Crlf
Const Max_str_len = 150 : Dim Com1_str As String * Max_str_len
#if Debuging = 1
'*********** CONFIGURATION FOR COM2 ON PORTC *********************
' COM2 IS FOR DEBUG SO SEPARATE CONFIG
Config Com2 = 115200 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8 'Tx-PC7 Rx-PC6
Open "COM2:" For Binary As # 2
Config Serialin1 = Buffered , Size = 50 'for COM2
Config Input2 = Cr , Echo = Cr
Dim Com2_str As String * 50
#endif
Dim Char As Byte , Mark As Byte , Count As Byte
Dim Cmd As String * 100 , Cmd_len As String * 15
Dim Field1 As String * 5 , Lenght As Byte
Dim State As Byte , Old_state As Byte , Mem_state As Byte
Const Startup = 0
Const Waiting = 1
Const Send_len = 2
Const Sending = 3
Led Alias Portf.0 : Config Led = Output
'*** SUB FOR USART HANDLING ***
Sub Get_reply
Com1_str = ""
Count = 0
Char = Inkey(# 1)
If Char > 0 Then
Select Case Char
Case 13 : If Com1_str <> "" Then Exit Do
Case 10 : If Com1_str <> "" Then Exit Do
Case Else
Com1_str = Com1_str + Chr(char )
Incr Count
If Count >= Max_str_len Then
Com1_str = ""
Count = 0
If Com1_str <> "" Then Mark = 1
'*** SUB FOR DEBUG ON COM2 ***
Sub Show_state
Local St_str As String * 10
Select Case State
Case 0 : St_str = "Startup"
Case 1 : St_str = "Waiting"
Case 2 : St_str = "Send_len"
Case 3 : St_str = "Sending"
Old_state = State
Print # 2 , "Now State=" ; St_str
'*** SUB FOR ESP8266 ***
Sub Esp8266
Select Case State
Case Startup
If Mark = 1 Then
Mark = 0
Select Case Com1_str
Case "WIFI GOT IP"
'AT+CIPSTART="TCP","184.106.153.149",80
Cmd = "AT+CIPSTART={034}TCP{034},{034}184.106.153.149{034},80"
Print # 1 , Cmd
Field1 = Str(rnd(100)) ' <<<<<< random value for Testing
#if Debuging = 1
Print # 2 , "Field value=" ; Field1
#endif
Cmd = "GET https://api.thingspeak.com/update?api_key="
Cmd = Cmd + Api_key
Cmd = Cmd + "&field1="
Cmd = Cmd + Field1
Cmd = Cmd + "{010}{010}"
Mem_state = State 'memorize that we starting
State = Waiting
Case Else
#if Debuging = 1
Print # 2 , Com1_str
#endif
Case Waiting ' if we waiting for answear
If Mark = 1 Then
Mark = 0
'Case "CONNECT"
Case "OK" ' if we see OK
Select Case Mem_state
Case Startup 'previous was Startup so this is first "OK"
Mem_state = Send_len
Lenght = Len(cmd ) : Cmd_len = Str(lenght )
Cmd_len = "AT+CIPSEND=" + Cmd_len
Print # 1 , Cmd_len
Case Send_len 'second "OK" so we send Len of data we want send
Print # 1 , Cmd
State = Sending
Mem_state = Sending 'memorize that we send data to server
' ( for Error handling )
#if Debuging = 1
#endif
Case "ERROR"
#if Debuging = 1
#endif
State = Startup
Case "CLOSED"
#if Debuging = 1
#endif
State = Startup
Case Else
#if Debuging = 1
#endif
Case Sending
If Mark = 1 Then
Mark = 0
Case "SEND OK"
State = Startup
#if Debuging = 1
#endif
' *** MAIN LOOP START HERE ****
Call Esp8266
#if Debuging = 1
If Old_state <> State Then Call Show_state
#endif
If Ischarwaiting(# 1) > 0 Then Call Get_reply
Have a nice day. |
Posted: Fri Jan 15, 2016 6:29 pm Post subject: Esp8266 |
Thanks for sharing. Very nice example.
Have fun
Ben Zijlstra |
Posted: Mon Jan 18, 2016 2:00 pm Post subject: |
thank you for sharing your code. Yes these are nice modules. it is a pity that you can not query the mac address. further they seem to reset quick when you send wrong info. but when sticking to the convention these are great wifi modules. xmega is a good choice. it can also be that newer versions have fixed firmware but i do not want to brick the modules i have  _________________ Mark |
Vlado
Posted: Mon Feb 08, 2016 6:17 pm Post subject: |
Thank you for sharing your code.
Here are AT commands needed to send data to Thiengspeak with GSM module SIM900.
AT commands were tested with terminal.
Quote: | RDY
+CFUN: 1
+CPIN: READY
Call Ready ' IF BAUD RATE IS FIXED GSM AUTOMATIC ANSWER WITH +CFUN: 1, +CPIN: READY (OR ERROR, THEN YOU MUST PUT PIN CODE), AND +CALL: READY
AT+CSQ ' GET SIGNAL LEVEL
+CSQ: 19,0
OK
AT+SAPBR=3,1,"CONTYPE","GPRS" 'CONNECT TO GPRS
OK
AT+SAPBR=3,1,"APN","internet" ' (FOR USER NAME & PSW USE DATA OF YOUR PROVIDER)
OK
AT+SAPBR=1,1
OK
AT+HTTPINIT
OK
at+sapbr=2,1 'Get GSM local IP
+SAPBR: 1,1,"XXX.XXX.XXX.XXX" 'gsm IP ADDRES GPRS OK. IF ANSWER IS +SAPBR: 1,3,"0.0.0.0" GPRS SI NOT CONNECTED
OK
AT+HTTPPARA="CID",1
OK
AT+HTTPSSL=1 'Enable the SSL function (YOU MUST ENABLE SSL ELSE ANSWER FROM SERVER will be 0,603,0)
OK
AT+HTTPPARA="URL","https://api.thingspeak.com/update?api_key=xxxxxxxxxxxxxxxx&field1=18&field2=32&field3=33"+CRLF 'SEND URL XXXXX YOUR API KEY
OK
AT+HTTPACTION=0 'GET ANSWER FROM SERVER
OK
'mind: TIME TO RECIVE ANSWER is between 1 and 5 seconds
+HTTPACTION:0,200,3 ' ANSWER OK, SEND BACK 3 BYTE
AT+HTTPREAD ' READ ANSWER FROM SERVER
+HTTPREAD:3 'ANSWER IS 3 BYTE LONG
120 ' RECIVED DATA FROM SERVER
OK
AT+HTTPTERM 'TERMINATE HTTP SERVICE
OK
AT+HTTPINIT 'INITIALISE HTTP SERVICE
OK
AT+HTTPPARA="URL","https://api.thingspeak.com/update?api_key=XXXXXXXXXXXXXXXX&field1=18&field2=32&field3=33" +CRLF 'SEND URL XXXXX YOUR API KEY
OK
AT+HTTPACTION=0
OK
'Mind: TIME TO RECEIVE ANSWER (1 - 5 sec)
+HTTPACTION:0,200,3
AT+HTTPREAD
+HTTPREAD:3
121
OK
OK
AT+SAPBR=0,1 'DISABLE GPRS
OK
nickb
Posted: Sun Jun 12, 2016 4:24 pm Post subject: |
I purchased another ESP8266 module early this year and it behaved completely different to previous one
The new one had software 0.25.0.0 and the old 0.17.09.01.
AT+GMR
AT version:0.25.0.0(Jun 5 2015 16:27:16)
SDK version:1.1.1
Ai-Thinker Technology Co. Ltd.
If you type AT+CIFSR you get a list of IP's and MACs for acess point and client if you have both enabled.
+CIFSR:APIP,"192.168.4.1"
+CIFSR:APMAC,"1a:fe:34:e6:2d:20"
+CIFSR:STAIP,"0.0.0.0"
+CIFSR:STAMAC,"18:fe:34:e6:2d:20"
On the up side 0.25.0.0 seems to be more stable then the 0.17.09.01 one...
Nick. |
