Paulvk
Posted: Mon Dec 07, 2015 10:06 am Post subject: 1-Wire search & save + DS1820 |
Here is some working code for finding 1-wire devices and storing the IDs in EEPROM
Also code for reading DS1820 temperature sensors'
Regards Paul
Code: |
'name : 1wireSearch.bas
'micro : Mega168p
'suited for demo : No Only due to code size which could be
'reduced by removing print commands!!!!!!!!
'commercial addon needed : no
$regfile = "m168pdef.dat"
$crystal = 8000000
$baud = 9600
$hwstack = 100 ' default use 32 for the hardware stack
$swstack = 100 'default use 10 for the SW stack
$framesize = 100 'default use 40 for the frame space
'Config 1wire = Portc.4 'use this pin
Io_1wire_port Alias Pinc
Declare Sub Read_ds1820(byval Piin As Byte )
Declare Sub Send1wire_cmd(byval Cmd As Byte , Byval Piin As Byte )
Declare Sub Look_for_devices
Declare Sub Save_eeprom
Declare Sub Check_stord
Declare Function Compare(val1 As Byte , Val2 As Byte , Byval Btcomp As Word) As Word
Dim Sc(9) As Byte ' result when reading DS chip
Dim Scd As Double At Sc(1) Overlay '1st 8 bytes ofSc(9)
Dim Dev_sc As Double
Dim Dev_scb(8) As Byte At Dev_sc Overlay '8 bytes of Dev_sc
Dim Work As Double
Dim Workw(2) As Dword At Work Overlay
Dim Devs(20 ) As Eram Double '8 bytes per device
Const Devices = 20 'max number of devices
Dim Cntr As Byte
Dim J As Byte
Dim K As Byte
Dim L As Byte
Dim I As Byte , W As Word
Dim Z As Single
Dim Zs As String * 5 'for print to LCD
Poort Alias Pinc 'pin for 1-wire
' 1WIRE COMMANDS
Const C1w_read_rom = &H33
Const C1w_match_rom = &H55
'tell all devices to do a temperature read
'send this command to address all devices on the bus
Const C1w_skip_rom = &HCC
'then send this command the instruction to tell all do temperature conversion
Const C1w_convert_t = &H44
Const C1w_search_rom = &HF0
Const C1w_alarm_search = &HEC
Const C1w_wr_scratchpad = &H4E
Const C1w_rd_scratchpad = &HBE
Const C1w_cpy_scratchpad = &H48
Const C1w_recall_memory = &HB8
Const C1w_convert_v = &HB4
Config Pinb.2 = Output 'LCD back light on my board
' Config 1wire = Portc.4 'use this pin
Config Lcdpin = Pin , Db4 = Portd.5 , Db5 = Portd.4 , Db6 = Portd.3 , Db7 = Portd.2 , E = Portb.0 , Rs = Portb.1
I = 1
Set Portb.2 'turn back light on
1wwrite C1w_skip_rom , 1 , Poort , 4 'address all devices
1wwrite C1w_convert_t , 1 , Poort , 4 'tell all to convert
'Now search for devices on the bus
Call Look_for_devices
Cls
Locate 1 , 1
Lcd "family code";
Locate 2 , 1
Lcd Hex(sc(1));
Wait 5
Cls
Call Read_ds1820(4)
Cls
Locate 1 , 1
Lcd "Deg C " ;
Zs = Fusing(z , "##.##")
Lcd Zs
' Name: Read_DS1820()
' Function: read the temperature from sensor (separated temp sensor)
' Input : 1Wire Hardware
Local T As Integer
Local Tt As Single
Local Tl As Single
'clear variables
Z = 0
T = 0
Call Send1wire_cmd(c1w_rd_scratchpad , 4 ) ' read scratchpad
Sc(1) = 1wread(9 , Poort , Piin ) ' read bytes in array
If Sc(9) = Crc8(sc(1) , 8) Then ' check CRC
'find the resolution of temp bits
Select Case Sc(5)
Case 127 ' 127 = 12 bits
Tl = 0.0625
Case 95 ' 95 = 11 bit
Tl = 0.125
Case 63 ' 63 = 10 bits
Tl = 0.25
Case 31 ' 31 = 9 bits
Tl = 0.5
End Select
T = Makeint(sc(1) , Sc(2))
Tt = T
Tt = Tt * Tl
Z = Tt
Call Send1wire_cmd(c1w_convert_t , 4) ' start conversion for next read
End Sub Read_ds1820()
' Name: Send1wire_cmd(cmd)
' Function: Send a command to a predefined 1W device dsid()
' Input : 1WIRE Command (see command list)
' Output: 1Wire Hardware
1wverify Sc(1) , Poort , Piin ' Send chip unique ID
If Err = 0 Then
1wwrite Cmd , 1 , Poort , Piin ' send command
End Sub
'==Search for devices on the buss
'==Put the IDs new into EEPROM
Local Xv As Byte
Xv = 0
Sc(1) = 1wsearchfirst(poort , 4)
Cls
Locate 1 , 1
Cntr = 1
If Err = 0 Then 'found device
Print "found one"
Incr Xv 'add one for every device found
Call Check_stord
Lcd Hex(sc(i)); 'print the number to LCD
Print Hex(sc(i)); 'print the number
'Wait 2
Print
Print
Wait 1
' Now Search For Other Devices
Sc(1) = 1wsearchnext(poort , 4)
Print "found another"
Incr Xv
Call Check_stord
'Print
Loop Until Err = 1
Locate 2 , 1
Cntr = 1
Print Xv ; " devices found"
End Sub
'==save device IDs to eeprom
Sub Save_eeprom
Local Xl As Byte
Local Wd As Double
Print "save eeprom"
'blank eeprom is all FFFF
Workw(1) = &HFFFFFFFF
Workw(2) = &HFFFFFFFF
For Xl = 1 To Devices
Wd = Devs(xl)
If Wd = Work Then 'blank eeprom bytes are FF
Print "WD is it"
Devs(xl) = Scd 'save to eeprom
Exit For
Elseif Wd = 0 Then
Print "WD is it"
Exit For
If Xl = Devices Then
Print "Not saved out of space"
End Sub
Sub Check_stord
Local Devpoint As Byte
Local Res As Byte
Print "Checking!"
For Devpoint = 1 To Devices
Dev_sc = Devs(devpoint)
Print "If Scd = Dev_sc Then "
Print "Sc() " ;
For I = 1 To 8
Print Hex(sc(i));
Print
Print "Dev_scb " ;
For I = 1 To 8
Print Hex(dev_scb(i));
Print
'Now we use the MWS Compare!
Res = Compare(dev_scb , Scd , 8)
If Res = 0 Then 'stored
Exit For 'its stored so lets not waste time
If Res > 0 Then
Print "not stored"
Call Save_eeprom
Else
Print "device stored"
End Sub
' The MWS Compare
!LD XL, Y+0 ' get pointer to BtComp
!LD XH, Y+1
!LD R24, X+ ' R24/25 as counter
!LD R25, X
!MOVW R16, R24 ' save BtComp for later calculation of mismatch position
!LD XL, Y+4 ' get pointer to Val1 into X
!LD XH, Y+5
!LD ZL, Y+2 ' get pointer to Val2 into Z
!LD ZH, Y+3
!cmp_start:
!LD R20, X+ ' X points to Val1
!LD R21, Z+ ' Z points to Val2
!CP R20, R21 ' compare!
!BRNE cmp_nomatch ' if equal: ok, next one
!SBIW R24, 1 ' decrease loop counter
!BRNE cmp_start ' if not zero do another turn
!RJMP cmp_end
!cmp_nomatch:
!SBIW R24, 1 ' else: calculate the position of compare mismatch
!SUB R16, R24
!SBC R17, R25
!MOVW R24, R16
!cmp_end:
!LD XL, Y+6
!LD XH, Y+7
!ST X+, R24 ' store success or position of mismatch
!ST X, R25
End Function
Posted: Tue Dec 08, 2015 10:13 pm Post subject: |
Thanks for sharing Paul !
The compare function from MWS is added to 2080 so take care that in an update it will give a conflict. _________________ Mark |
Paulvk
Posted: Wed Dec 09, 2015 12:17 am Post subject: |
Hello Mark
Yes I will have to update the post with another version when it comes out.
I am also not using some of the variables exactly as intended but there is no 8 byte variable in bascom
It would be nice to have a 8 and 16 byte pure binary variables to work with hardware connected to the AVR
Maybe a quad word Qword and octo word Oword
Regards Paul |
Paulvk
Posted: Sun Dec 20, 2015 11:31 am Post subject: |
Now so the free version of Bascom can be used I have set up conditional compilation
By setting one of the constants Test or Uselcd to 0 less than 4k of code is produced
Regards Paul
Code: |
'micro : Mega168p
'suited for demo : yes by setting constants Test or Uselcd to 0
$crystal = 8000000
$baud = 9600
Dim Work As Double
Dim Cntr As Byte
Dim J As Byte
Dim K As Byte
Dim L As Byte
Dim Z As Single
' 1WIRE COMMANDS
' by setting one or both of these to 0 the free version can be used
Const Test = 1 '1 will enable print commands
Const Uselcd = 0 '1 will enable LCD
'set to 1 for print to rs232 debuging
I = 1
#if Test = 1
Print "starting"
#endif
#if Uselcd = 1
Cls
Locate 1 , 1
Lcd "family code";
Locate 2 , 1
Lcd Hex(sc(1));
Wait 5
Cls
#endif
Call Read_ds1820(4)
#if Uselcd = 1
Cls
Locate 1 , 1
Lcd "Deg C " ;
Lcd Zs
#endif
Local T As Integer
Local Tt As Single
Local Tl As Single
'clear variables
Z = 0
T = 0
Select Case Sc(5)
Tl = 0.0625
Tl = 0.125
Tl = 0.25
Tl = 0.5
End Select
Tt = T
Tt = Tt * Tl
Z = Tt
If Err = 0 Then
End Sub
Local Xv As Byte
Xv = 0
Cls
Locate 1 , 1
Cntr = 1
#if Test = 1
Print "found one"
#endif
Call Check_stord
'Wait 2
#if Test = 1
Print
Print
#endif
Wait 1
#if Test = 1
#endif
Incr Xv
Call Check_stord
'Print
Loop Until Err = 1
Locate 2 , 1
Cntr = 1
#if Test = 1
#endif
End Sub
Sub Save_eeprom
Local Xl As Byte
Local Wd As Double
#if Test = 1
Print "save eeprom"
#endif
Wd = Devs(xl)
#if Test = 1
Print "WD is it"
#endif
Exit For
Elseif Wd = 0 Then
#if Test = 1
Print "WD is it"
#endif
Exit For
#if Test = 1
#endif
End Sub
Sub Check_stord
Local Res As Byte
#if Test = 1
Print "Checking!"
#endif
#if Test = 1
Print "Sc() " ;
For I = 1 To 8
Print Hex(sc(i));
Print
Print "Dev_scb " ;
For I = 1 To 8
Print
#endif
If Res > 0 Then
#if Test = 1
Print "not stored"
#endif
Call Save_eeprom
Else
#if Test = 1
#endif
End Sub
' The MWS Compare
!LD XH, Y+1
!LD R25, X
!LD XH, Y+5
!LD ZH, Y+3
!cmp_start:
!RJMP cmp_end
!cmp_nomatch:
!SUB R16, R24
!SBC R17, R25
!MOVW R24, R16
!cmp_end:
!LD XL, Y+6
!LD XH, Y+7
!ST X, R25
End Function
Paulvk
Posted: Mon Jun 20, 2016 1:06 pm Post subject: |
Sadly this one can not be used with the free version as it just exceeds the 4K limit by 200 bytes.
But the .HEX & .BIN files will let you load the UNO
Note the I2C address has been set to H46 by shorting A2 on the board
This uses the Arduino UNO with an Pcf8574 I2C lcd driver to display the
Family code on the LCD and the temprature
Regards Paul |
