moreau
Posted: Wed Nov 25, 2015 11:21 am Post subject: rc5 backgorung and dcf77 |
Hello,i need use rc5 and dcf77 simultaneously but..
rc5 in background mode need timer1, dcf77 need timer1. test to use a 16 bit timer like timer3 won't work.
I'm using a atmega128 with ir connected to pe7 (ic3).
Config Rc5 = Pine.7 , Timer = 3 , Mode = Background ->.equ tifr3 not found
How to do to use timer3 for rc5 ? if possible.
Thank you
:roll:
Posted: Thu Nov 26, 2015 4:47 pm Post subject: |
the m128 has a diffrent register name.
you could add this to the code :
CONST TIFR3=ETIFR
config rc5 .... _________________ Mark |
moreau
Posted: Thu Nov 26, 2015 5:48 pm Post subject: rc5 and dcf |
thanks too much, you saved me
d. |
daro
Posted: Sun Mar 12, 2017 9:15 pm Post subject: Background& Prescaler? |
I have also problem witch
Code: | Config Rc5 = Pine.7 , Timer = 3 , Mode = Background |
Using ATmega64, and compilator show error:
Error : 96 Line : 43 Prescale value must be 1,8,64,256 or 1024 [ 16] , in File : E:\!Elektronika\!Moje projekty\Dariusz Kloc\Aktualne, zaczęte, w trakcie opracowywania\Sterownik tablicy i zegara\Code Safe table\Safe_table_v_1.bas
When change Confor RC5 from old:
Code: | Config Rc5 = Pine.6 , Wait = 2000 |
to Background mode...
I used also Timer 1 but to countdown 1secounds but Timer1 also generated the same erros "prescale value must..."
Where is the problem?
There is all my configuration:
Code: | $regfile = "m64def.dat"
$crystal = 11059200 '
$hwstack = 192 'Stos Systemowy , Gosub , Interrup
$swstack = 192 'Sub , Function
$framesize = 192 'Byval , Local , Print , Lcd , Input
$prog &HFC , &HAE , &HC9 , &HFF ' generated. Take care that the chip supports all fuse bytes.
$lib "rc5.lib"
Config Adc = Single , Prescaler = Auto , Reference = Avcc
Config 1wire = Portg.0
Config Sda = Portd.1 'I2C RTC
Config Scl = Portd.0 'I2C RTC
Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 4 , Noss = 1
Config Com2 = 115200 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
Open "com2:" For Binary As #2
'On Urxc Rs485_isr
Config Timer1 = Timer , Prescale = 256 , Clear Timer = 1 , Compare A = Disconnect , Compare B = Disconnect
Ocr1a = 43199
On Oc1a Countdown
Config Watchdog = 2048
Config Aci = On , Compare = Off , Trigger = Falling
On Aci Write_eeprom 'przerwanie od komparatora do zapisu po zaniku napięcia
'Config Rc5 = Pine.6 , Wait = 2000 'RC5
Const Tifr3 = Etifr
Config Int4 = Falling
On Int4 Rtc_int |
Bascom AVR ver 2.0.7.8 |
Evert :-)
Posted: Sun Mar 12, 2017 10:00 pm Post subject: |
according the help file you can only use timer 0(default) or timer 2 (if your chip has timer 2) and not timer 3.
Code: |
Config Rc5 = Pine.7 , Timer = 2 , Mode = Background
_________________ www.evertdekker.com Bascom code vault |
daro
