bascom ==> arduino
sultanm9000
PostPosted: Tue Nov 24, 2015 7:28 am    Post subject: bascom ==> arduino Reply with quote
Hello,
"How do the connection (Arduino Atmega2560) with Bascom
Confused:
(BASCOM-AVR version : 2.0.7.7 , Latest : 2.0.7.8 )
dabatek
PostPosted: Tue Nov 24, 2015 8:20 am    Post subject: Arduino Atmega2560 Reply with quote
Hi !
On page 137 Bascom Avr PDF help...
But, in few steps:
First connect Arduino Atmega2560 with usb to your PC, than in Bascom menu OPTIONS chose Programmer, than chose: ARDUINO STK500V2,
proper COM port (in device manager can find which com is used for Arduino...) and for baud 115200...
work like normal programmer... Smile
Have a nice day.
PostPosted: Tue Nov 24, 2015 5:52 pm    Post subject: Reply with quote
and here I write a step by step tutorial, look some other tips on Arduino in the forum index Bascom-Arduino
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=12472
It works fine on W7, W8.1, W10(32) and Win10(64)
JP
Wink
sultanm9000
PostPosted: Wed Nov 25, 2015 10:33 pm    Post subject: Reply with quote
What is the cause of this error please "? Crying or Very sad
bzijlstra
Bascom Ambassador
PostPosted: Thu Nov 26, 2015 12:52 am    Post subject: Baudrate? Reply with quote
What board are you using?
What is the baudrate you are using?
Are you using a cable on the ISP connector or the bootloader?
Ben Zijlstra
sultanm9000
PostPosted: Thu Nov 26, 2015 8:08 am    Post subject: Reply with quote
What board are you using? mega2560
What is the baudrate you are using? 9600 and 115200
Use USB cable
Thank you Ben Zijlstra
Paulvk
PostPosted: Thu Nov 26, 2015 10:13 am    Post subject: Reply with quote
Have you loaded the driver for the M2560 onto your computer?
Regards Paul
PostPosted: Thu Nov 26, 2015 3:02 pm    Post subject: Reply with quote
As I said in my tutorial
FIRST the 2560 arduino must be work with arduino compiler, here : https://www.arduino.cc/en/Main/Software then you must see the port used in the parameters of your computer.
if the small blink program gave in the sample arduino doesn't work, you can reload the driver from Arduino IDE
THEN and only if the steps above are working you can work with Bascom IDE
Did you follow it ?
Are you use to use the good serial port ? (in the picture the Arduino is not recognized.) then If you use the autoflash you must wait until bascom see your Arduino board
Please use the good forum for arduino question : http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewforum&f=21
JP
