m64def.dat or m64m1.dat
gilson163
PostPosted: Sat Nov 14, 2015 1:20 pm    Post subject: m64def.dat or m64m1.dat Reply with quote
I'm developing a project using ATMEGA64L-8MU (QFN 64) and BASCOM I have to use '$regfile = "m64def.dat" to build the softare and not give error. If use "$regfile = "m64m1.dat" of the following error # 41. Would anyone can help me or explain me why this error? Or why can not I use the "m64m1.dat"? Here below file for analysis
Thank you.
(BASCOM-AVR version : 2.0.7.8 , Latest : 2.0.7.8 )
_kaktus_
PostPosted: Sat Nov 14, 2015 1:42 pm    Post subject: Reply with quote
You tried on an earlier version of Bascom?
i.dobson
PostPosted: Sun Nov 15, 2015 9:19 am    Post subject: Reply with quote
Hello,
Looks as if the m64m1.dat is missing the port definitions for porta/data direction Register A.
In the IO section of the dat file I see
PORTE   = $0E
DDRE    = $0D
PINE    = $0C
PORTD   = $0B
DDRD    = $0A
PIND    = $09
PORTC   = $08
DDRC    = $07           ; New
PINC    = $06           ; New
PORTB   = $05
DDRB    = $04
PINB    = $03
This is in Bascom Version 2.0.7.9
If you find the correct addresses for PortA, PinA and DDRA and add them to the data file the code should work.
Regards
Ian Dobson
PostPosted: Mon Nov 16, 2015 10:50 am    Post subject: Reply with quote
you can not simply add them. they are not missing : this PORTA does not exist in the mega64M1.
Have a look in the datasheet and the pinout. you will not find any pin named with PA. At least, i did not find any.
That a chip has a similar name does not mean much. you can upgrade from 16M1 to 32M1 to 64M1 without problems, but you can not from a normal mega64 to an M.
i.dobson
PostPosted: Mon Nov 16, 2015 6:25 pm    Post subject: Reply with quote
Oh, OK I've learnt something new. I always thought that AVR's started with PortA.
Regards
Ian Dobson
gilson163
PostPosted: Mon Nov 16, 2015 9:50 pm    Post subject: Reply with quote
I did not understand completely . How then do detail to cancel this error in BASCOM compiler ?
PostPosted: Mon Nov 16, 2015 10:00 pm    Post subject: Reply with quote
it is not a problem of the compiler.
you try to access hardware (a PORTA) that does NOT exist for that chip !
- please check the PDF of the used processor
- lookup PORTA
- you will see it does not exist
gilson163
PostPosted: Mon Nov 16, 2015 10:20 pm    Post subject: Reply with quote
so if I use $regfile(m64def.dat) for atmega64L-8mU (QFN64) will have no problem. I develop the software with this? All functions work normally?
PostPosted: Mon Nov 16, 2015 10:28 pm    Post subject: Reply with quote
if your processor is atmega64L, then yes, that would be the proper thing to do.
but if your processor is atmega64M1, it will not work when using portA.
gilson163
PostPosted: Mon Nov 16, 2015 11:23 pm    Post subject: Reply with quote
I understand, thank you for the explanation.
