...need some help to Logical operators NOT OR
RWo
PostPosted: Mon Oct 19, 2015 1:58 pm    Post subject: ...need some help to Logical operators NOT OR Reply with quote
...see the samples below. I don't get the sence of them.
$Regfile="m32def.dat"
$Crystal=14745600
$hwstack = 40
$swstack = 16
$framesize = 64
$baud = 19200
$sim
Const RWcDebug = 0
Dim Test(4) as Byte
Dim Test1 as Bit, Test2 as Bit
  '( Sampe 2
  #If NOT RWcDebug                        'NOT is ignored
    If Test(1) < 254 then Incr Test(1)
    If Test(2) < 254 then Incr Test(2)
  #EndIf
  #If RWcDebug
  #Else
  #EndIf
  '( Sample 2
  If NOT Test(3) then                    'NOT create Error 35
    Test(3) = 1
  If NOT Test(3) = 1 then                'NOT create Error 35
    Test(3) = 1
  '( Sample 3
  If Test(3) OR Test(4) then            '...create Error 35
    Test(3) = 1
  If Test(3) = 0 OR Test(4) = 0 then    '...but here, OR works fine
    Test(3) = 1
  Test(3) = 1
  '( Sample 4
  If NOT Test1 then                      'NOT create Error 35
    Set Test1
  If NOT Test1 = 1 then                  'NOT create Error 35
    Set Test1
  ' Sample 5
  'If Test1 OR Test2 then                 'OR create Error 35
  '  Set Test1
  'End If
  If Test1 = 0 OR Test2 = 1 then          'this works ? but why need "=0" is a binary anyway
    Set Test1
Evert :-)
PostPosted: Mon Oct 19, 2015 7:26 pm    Post subject: Reply with quote
It get now really time that you start to read the manual or helpfile.
Bascom != Qbasic.
  Temp = NOT Test1
  If Temp =1 then
    Set Test1
RWo
PostPosted: Mon Oct 19, 2015 8:59 pm    Post subject: Reply with quote
Bascom != Qbasic.
here a sample:
DIM a(3) AS INTEGER
a(1) = 0: a(2) = 0: a(3) = 0
IF NOT a(1) = 1 OR NOT a(2) = 1 THEN
  a(3) = 1
END IF
PRINT a(3)
...use this in QB and run. Then let us know, what is the value of a(3)...
Evert :-)
PostPosted: Mon Oct 19, 2015 9:48 pm    Post subject: Reply with quote
Don't care what's in qbasic, this is the Bascom forum and in Bascom you can't do 2 thing's on the same line. See my previous post.
a+b+c=d works in qbasic, not in Bascom. It's all in the helpfile READ it and delete qbasic.
AdrianJ
PostPosted: Tue Oct 20, 2015 11:51 pm    Post subject: Reply with quote
a(3) = 1
END IF
I could ask why you dont avoid the NOT entirely, and just write
IF a(1) = 0 OR a(2) = 0 THEN
  a(3) = 1
END IF
Saves using extra machine cycles to do the trivial and static calculation NOT (a)
Adrian Jansen
Visovian
PostPosted: Wed Oct 21, 2015 8:22 am    Post subject: Reply with quote
It seems "NOT" in Bascom cannot be used as a logical NOT ( ! in C).
Rather it performs the bitwise NOT (~ in C).
Bascom example:
A = &b_00001111
B = NOT A            ' B = &b_11110000
C example:
A = 0b00001111
B = ! A    //  B = 0
B = ~ A    //  B = 0b11110000
RWo
PostPosted: Thu Oct 22, 2015 4:38 pm    Post subject: Reply with quote
Yes!
QB Help...
NOT Operator
  result = NOT numeric-expression
The logical-complement operator evaluates each bit in numeric-expression,
then sets the corresponding bit in the result according to the following
table:
              Bit in Expression         Bit in Result
                       1                       0
                       0                       1
This inverts the bit values of any variable. If an integer variable has
the value 0 (false), the variable becomes -1 (true), and vice-versa.
bzijlstra
Bascom Ambassador
PostPosted: Fri Oct 23, 2015 7:57 am    Post subject: OR NOT Reply with quote
Did you get it OR NOT?
Simply had to do this...
Have a nice weekend all
Ben Zijlstra
PostPosted: Fri Oct 23, 2015 10:06 am    Post subject: Re: OR NOT Reply with quote
I'm all for creating the RATHERNOT operator. Very Happy
Further I suggest to extend QB's syntax with the WHEREISMYHEAD, DAUOFTHEMONTH, and finally IAMAGENIUSANDNOBODYSEESTHAT operators.
