Joined: 28 Jun 2005 Posts: 212 Location: Ashburton / Mid Canterbury / New Zealand
Posted: Fri Jul 31, 2015 11:40 am Post subject: Adruino Resetting with incomming serial data
Hi all
I've got a Arduino mega project hooked up to a PC for sensor data logging. The comms is USB to the micro USB port on the arduino. I have got MS Access to send an sensor ID via the usb comms. The Arduino reads this ID and reads the sensor and transmits the data back. Works well
I have noticed something weird. When the ID request is transmitted to the Arduino for the first time only ,the Arduino resets. Then it runs up fully. This is not a big issue I'm just wondering why and should it.
Here is the code snippet that reads the comms
Serial_flag =Ischarwaiting()'Listen to the Uart rs232 port for data to turn up
If Serial_flag =1Then'We got something in the Uart
Rx_data =0
Rx_data =Waitkey()'Get it
Filter_command 'Call the sub that fiilters the ID and reads the sensor
Locate1 , 1 LcdSpace(16) Locate1 , 1 Lcd Rx_data ;": "; Sensor_value ' Display it on the LCD before it is sent out. Used for data checking
Print Sensor_value 'Send the data back to access
Tx_data =0 End If
The whole project works well but just trips up for a few cycles at the start
Joined: 22 Apr 2009 Posts: 17 Location: USA, San Diego
Posted: Mon Aug 03, 2015 2:29 pm Post subject:
I had to cut the reset line that was connected on the ftdi chip. Works fine now and if I need to program it again, I manually press the reset button on the arduino as soon I click to program it.
