I assume you use _temp1 as register R24? or is it a variable dimmed somewhere?
I guess that r24 is used by the page setting procedure, something not required by chips <=64 KB
If you send me a sample i can have a look and maybe change it. _________________ Mark
i changed a register so you can use r24.
i also changed the code for when using internal registers so you gain more speed.
if you use 2079, i can email you an update to test it. _________________ Mark
