Bascom + Olimex AVR ISP MK2
Alex20q90
PostPosted: Fri Aug 14, 2015 11:20 am    Post subject: Bascom + Olimex AVR ISP MK2 Reply with quote
how i get this programmer work?
I Installed AtmelStudio 6. There it works!
For Bascom i have found here:
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=9377&highlight=avr+isp+mk2
but it dont work! i flashed firmware with FLIP.
If i select FLIP in Bascom, nothing happens!
Same withe the original Atmel ISP!
Anybody had a solution for me?
I Would like to programm the XMegas!
Evert :-)
PostPosted: Fri Aug 14, 2015 3:27 pm    Post subject: Reply with quote
Hi Alex,
I don't know the Olimex Isp, but to get an Atmel ISP MK2 working with Bascom you have to read this:
http://avrhelp.mcselec.com/libusb.htm?zoom_highlightsub=usb
PostPosted: Tue Aug 18, 2015 1:20 pm    Post subject: Reply with quote
FLIP in bascom requires FLIP from atmel to be installed and working. FLIP in bascom uses the USB bootloader found on a number of atmel chips. For example usb1287 or usb162. It is not used in any other mode.
mkII requires that you have installed the original driver and that it works. You did that so the next step is to add LIBUSB. THen install a filter driver as described in the help. That way you can use both studio and bascom.
mkII is tested on multiple windows versions. Some clone programmers require different firmware to work with LIBUSB. I believe that is the case for the olimex programmer as well. Olimex has alternative firmware for that.
Alex20q90
PostPosted: Tue Aug 18, 2015 3:51 pm    Post subject: Reply with quote
i already had installed LIBUSB, FLIP, AtmelStudio6 etc.
In Studio6 i can read and write the XMegas, but not in Bascom! Every time wrong chip id!
At Moment i use for normal ATMegas the MCS "USB-ISP Prog" from the shop! I have 3 of it and it works fine!
But i cant program XMegas with it (or i can?). I only would like to programm XMegas too for my bussiness!
So many problems to get it run! Didnt have MCS a solution for it? Like a setup.exe?
Best regards
Alex
PostPosted: Tue Aug 18, 2015 8:21 pm    Post subject: Reply with quote
you should start with giving some proper information.
now you added :
which means that the programmer is recognized. And the chip ID is read.
- Did you made your own DAT file?
- Are you really using 2078 ?
- Which processor do you use?
- do you have the $regfile directive in your code? and for which processor?
Alex20q90
PostPosted: Sat Aug 29, 2015 12:27 pm    Post subject: Reply with quote
i use the dat-file from bascom "xm128a1def.dat"
Yes
The AVR ist a XMega128A1
$regfile = "xm128a1def.dat"
PostPosted: Mon Aug 31, 2015 3:49 pm    Post subject: Reply with quote
it works perfect for me. Just tested.
did you installed LIBUSB ? (see help). you also need to put firmware in the olimex for usage with LIBUSB. It is explained on olimex help page/pdf for the programmer.
bzijlstra
Bascom Ambassador
PostPosted: Mon Aug 31, 2015 4:02 pm    Post subject: Working here.. Reply with quote
I am using a Diamex AVR ISP USB MKII and after installing the libusb mentioned in the help file everything is working. I hope you are using the PID connection of the Atxmega128a1.
Have fun
Ben Zijlstra
