Joined: 28 Jun 2005 Posts: 212 Location: Ashburton / Mid Canterbury / New Zealand
Posted: Wed Aug 12, 2015 1:35 pm Post subject: RTC clock address selecting
I'm busy changing one of my projects from a DS1307 to a DS3231 RTC. Im using the SWQ pin to drive a INT in my program.
My old for the DS1307 code is
'Setup the module so SQW outpin triggers at one sec I2cstart'Setup the SQW pin for 1 pulse/sec I2cwbyte Ds1307w 'DS1307 write address I2cwbyte7'Data to go to the control register 7 I2cwbyte &B00010000 'set I2cstop
my new code for the DS3231 is
'Setup the module so SQW outpin triggers at one sec I2cstart'Setup the SQW pin for 1 pulse/sec I2cwbyte Ds1307w 'Ds1307w I2cwbyte&HE 'Data to go to the control register 7 I2cwbyte &B01000000 'set I2cstop
this works fine with no worries
My question is
What does "I2cwbyte Ds1307w" do? I know it has something to do with the I2C rtc address of the RTC. If i change the code to I2cwbyte Ds3231w it fails to compile. Where does Bascom look up the information on Ds1307w to get the address from. I want to change it so my code matched the RTC i'm now using.
Posted: Thu Aug 13, 2015 12:37 am Post subject:
Hi Ben
Yes you're right there are 2 constants for the 1307 R/W. Where is the address for that those constants stored in bascom?. I want to add the DS13231 RTC to the list. I know the addresses are the same as my code works but i would like to add this RTC to it so my code looks correct ETC and possibly add other external devices as well at some stage.
Posted: Thu Aug 13, 2015 1:34 am Post subject:
Sorry yes your right
I couldn't see the wood for the trees.
In the C:\Program Files\MCS Electronics\BASCOM-AVR\LIB folder there is a few ds1307.lib files. What do they do??
