Posted: Mon Feb 22, 2016 2:55 pm Post subject: |
Ben and Theo can make about anything. I have seen a lot of great projects which they shared here. What i find great is that they always take the time to build the projects in an attractive case. This time with the color matching LCD they even wend a step further. It is great to have such friends. Especially since they create these great unique gifts.
I have a nice collection in the mean time with 'Made in Tilburg'
It was still my plan to take pictures and show them but still have no camera connected to my dev pc.
So it is nice that Ben at least uploaded this picture.
Thanks guys ! _________________ Mark |
Paulvk
Posted: Tue Feb 23, 2016 3:20 am Post subject: |
A made with Bascom page on your main site with pictures of the great projects that have been made with Bascom
to show what is possible.
I often get the comment "Oh its basic we want a more serious language" when I suggest its use.
This might show them it is a serious commercial language.
Regards Paul |
bzijlstra
Posted: Fri Mar 04, 2016 2:14 pm Post subject: Settings for flashing ESP8266 |
Two different 'builders' had some problems flashing the ESP8266 shield.
After correct flashing no connection to the access point. After some research:
Here are the settings for the ESP8266 with Arduino IDE 1.6.7
Have fun
Ben Zijlstra
Theo Kleijn |
bzijlstra
Posted: Thu Jun 23, 2016 4:13 pm Post subject: New pictures |
Two new pictures
Nice weather here in Holland
Added a PCF8583 I2c clock IC which get syncronized with the internet.
On this new board.
Have fun
Ben Zijlstra |
Meister
Posted: Sat Aug 13, 2016 9:48 pm Post subject: Did not compile |
Hello,
Compile of weatherstation_3 on generic ESP8266 board did not even start:
L:\Temp\weatherstation_3\weatherstation_3.ino in L:\Temp\weatherstation_3 not found.
But compiling weather-station-v2 from Github runs but ends with error,
"drawframe1" was not declared in this scope.
What did I wrong in especially with weatherstation_3?
Best regards, Meister |
bzijlstra
Posted: Tue Aug 16, 2016 4:14 pm Post subject: ESP8266 programming... |
Arduino 1.6.5
The ZIP-file is unpacked in
documents\arduino\weatherstation\weatherstation_3
You will get these files:
WeatherClient.cpp
WeatherClient.h
Weatherstation_3.ino
Click the ino file twice and Arduino IDE will start.
Select Generic ESP8266 or NodeMCU 1.0
Compile and upload. Start the Arduino internal terminal at 9600 baud. If everything is correct you should see the ESP8266 trying to connect to your access point. And after that a connection to www.eventcaster.nl (you have to get an API-key at www.forecast.io).
Hope you get it working. Have seen you asked the same question at the Ultra Light MQTT client, but I answer here.
Have fun
Ben Zijlstra |
bzijlstra
Posted: Sun Feb 19, 2017 3:25 pm Post subject: Weatherstation 4.0 |
There is new Bascom-AVR and ESP8266 code for Weatherstation 4.0
All initiative from Arduino Mega 2560
Current weather but also a week forecast
Several locations
Several week forecasts
http://weerstation.benshobbycorner.nl
It is in Dutch, but with Google Translate you can translate it to your own languages. Noticed however that the pictures could not be found.
So for the pictures you have to check the original site.
Have fun
Ben Zijlstra
Posted: Mon Feb 20, 2017 3:53 pm Post subject: |
Hello Ben,
Thanks for this great update. You documented it well. Indeed google translate will do a good job.
I need to study your v4 code. But as usual you write clear documented code, and your web shows a good explanation.
I like the new forecast screens. I also understand the eventcaster now.
Now all we need is good weather  _________________ Mark |
gmirc
Posted: Mon Feb 10, 2020 10:44 am Post subject: Weatherstation 4.0 of Ben's |
Hello
Unfortunately Ben's has left us.
I am looking at his weather station, may on his site http://weerstation.benshobbycorner.nl we can no longer download its sources.
If someone got them it would be great to put them on the forum.
Best regard. |
