Mrshilov
Posted: Thu Jul 09, 2015 11:05 pm Post subject: LCD ST7567 library |
LX-12864B11 STN b/w LCD with resolution 128x64. Controller ST7567. Shipped with external backlight module.
This model has 12 pin and works in SPI mode. This mode don't support read from display, so graphic (line, circle, ect.) not possible. Only text and pictures.
SPI speed is up to 20MHz, power supply 3,3V.
Posted: Fri Jul 10, 2015 1:13 pm Post subject: |
Hello Mrshilov,
Thank you for sharing your work. As usual it is complete with circuit and details about connector. Great to see your work. _________________ Mark |
Mrshilov
Posted: Sun Jan 03, 2016 3:21 pm Post subject: |
0,5 inch ST7567 display I found in chinese mp3 player:
In library added contrast regulation (0 to 63, optimal for this display = 31) and solved X/Y problem. |
Posted: Mon Jan 04, 2016 1:42 pm Post subject: |
thank you for the update. great to see how you support your work. Wish you all the best for 2016! _________________ Mark |
Mrshilov
Posted: Sun Jul 22, 2018 7:48 pm Post subject: |
Display from Zalman VE300/VE400, IODD2531, IODD2541 (USB Removable Flash Drive) also uses ST7567 controller. Resolution 128x32. Named MTC3059P04 or MTC3059FB
Datasheet in attachment. |
Posted: Wed Jul 25, 2018 7:54 pm Post subject: |
another update, thanks ! _________________ Mark |
