compare pwm error??
techknight
PostPosted: Fri May 01, 2015 3:25 pm    Post subject: compare pwm error?? Reply with quote
I updated to 2.0.7.8 again thinking I would give it a second try. Maybe I shouldnt have after the update, I ran into this error:
Unknown CONFIG Parameter. Compare PWM
On this line:
Config Timer2 = Pwm , Prescale = 1 , Compare Pwm = Clear Down
Using an ATmega1284.
Any thoughts??
PostPosted: Fri May 01, 2015 3:41 pm    Post subject: Reply with quote
Try :-
Config Timer2 = Pwm , Prescale = 128 , Compare A Pwm = Clear Down, Compare B Pwm = Clear Down
Pwm2a = 0
Many AVR's have 2 pwm outputs per timer, so you need to tell Bascom which PWM Output you want to use (A or B)
Ian Dobson
PostPosted: Fri May 01, 2015 3:55 pm    Post subject: Reply with quote
exact, and while add it, replace the space with underscores :, like : Compare_A_Pwm
techknight
PostPosted: Fri May 01, 2015 10:30 pm    Post subject: Reply with quote
That worked. I guess on newer versions, your tightening the use of sloppy coding?
