Plons
Joined: 24 May 2005 Posts: 435 Location: Hilversum - The Netherlands
Posted: Tue Feb 23, 2016 1:35 pm Post subject: |
I posted earlier about problems with larger fonts than font8x8.font. Here: http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&p=68398#68398
There was an error in ILI9341_M328_revA.inc: in Code: | Sub Lcd_text(byval S As String , Byval Xoffset As Word , Byval Yoffset As Word , Byval Forecolor As Word , Byval Backcolor As Word)
| was a mix up between X and Y.
Local A As Word , Pixels As Byte , Count As Byte , Carcount As Byte , Temp As Word
Local Row As Byte , Block As Byte , Byteseach As Byte , Blocksize As Byte
Local Colums As Byte , Columcount As Byte , Rowcount As Byte , Stringsize As Byte
Local Pixelcount As Byte , Offset As Word
Local Pointer As Word
Local X As Word , Y As Word
Stringsize = Len(s) - 1 'Size of the text string -1 because we must start with 0
!Lds _DPTRL , {Lcd_chartable} 'Restore Font Label
!Lds _DPTRH , {Lcd_chartable+1}
#if Varexist( "RAMPZ")
___readrampz = Lcd_chartable_rampz
#endif
Read Block
Read Byteseach
Read Blocksize
Colums = Blocksize / Block 'Calculate the numbers of columns
Row = Block * 8 'Row is always 8 pixels high = 1 byte, so working with row in steps of 8.
Row = Row - 1 'Want to start with row=0 instead of 1
Colums = Colums - 1 'Same for the colums
Pointer = Varptr(s)
For Carcount = 0 To Stringsize 'Loop for the numbers of characters that must be displayed
Offset = Inp(pointer) 'Font files start with character 32
Offset = Offset - 32
Incr Pointer
If Lcd_digit_font = 1 And Offset > 14 Then Offset = Offset - 15 'For reduced Digit Font
Offset = Offset * Blocksize
Offset = Offset + 4
Lcd_tempword = Lcd_chartable + Offset 'Point to Character
!Lds _DPTRL , {Lcd_tempword}
!Lds _DPTRH , {Lcd_tempword+1}
#endif
Temp = Carcount * Byteseach
Temp = Temp + Xoffset
For Rowcount = 0 To Row Step 8 'Loop for numbers of rows
Y = Yoffset + Rowcount
X = Temp
For Columcount = 0 To Colums 'Loop for numbers of Columns
Read Pixels
For Pixelcount = 0 To 7 'Loop for 8 pixels to be set or not
If Pixels.pixelcount = 1 Then
Lcd_set_pixel X , Y , Forecolor
Else
Lcd_set_pixel X , Y , Backcolor
' As it was in ILI9341_M328_revA.inc
' Incr X
' Next Pixelcount
' X = X - 8
' Incr Y
' As it is now in ILI9341_M328_revB.inc
Incr Y
Next Pixelcount
Y = Y - 8
Incr X
Next Columcount
Next Rowcount
Next Carcount
End Sub
Attached the updated library. _________________ Bascom AVR ver 2.0.8.6
Dragon-lair: http://www.aplomb.nl/TechStuff/Dragon/Dragon.html
"leef met vlag en wimpel, maar hou het simpel" |
dabatek
Posted: Wed Mar 23, 2016 9:45 pm Post subject: Larger Font on ILI9341 |
I use display 3,2 inch with 16 Bit parallel mode (lib from Netzman ) and all work OK, but I can not get a larger font than 8x8.
SPI variant of lib have support for larger font.
Is it possible to use a text-routine from SPI lib (with some editing) for 16 bit parallel lib. I tried, but without success.
Please... help
Z. Dabic
Thank you... |
Plons
Posted: Tue Apr 12, 2016 1:57 pm Post subject: |
It has proven to be very usefull to read a thread thoroughly : my post right above yours tells you how to fix the problem. _________________ Bascom AVR ver 2.0.8.6
dabatek
Posted: Thu Apr 14, 2016 10:24 pm Post subject: |
Oh...
Sometimes I can not see the forest for the trees
Thank you... |
alexprint36
Posted: Sun May 22, 2016 7:50 pm Post subject: |
Hello! When you try to compile, I get an error. It is unclear assignment Pin connection display
Code: | Const Lcd_ctrl_port = Portf
Const Lcd_data_port_1 = Porta
Const Lcd_pin_dc = 2
Const Lcd_pin_cs = 3
Const Lcd_reset_pin = 4
Const Lcd_pin_wr = 1
Const Lcd_pin_rd = 0 |
Igor_67
Joined: 16 Jan 2011 Posts: 12 Location: Barnaul, Russia
Posted: Thu Aug 18, 2016 6:54 pm Post subject: |
Hi all!
I have a little question:
Is suitable ili9341 library for ili9340? |
pier_pe
pier_pe
Posted: Wed Sep 07, 2016 5:37 pm Post subject: |
Hi.
Link to the library work but on this page is not displayed diagrams to connect the display. |
pier_pe
Posted: Sun Oct 30, 2016 10:00 pm Post subject: |
Does anyone have a connection diagram of the display in parallel 16bit mode? |
Netzman
Posted: Wed Nov 23, 2016 8:23 pm Post subject: |
Hello,
The connection scheme is online now.
the server has been moved again, during that process the images got lost (most of them I could recover, i've had at least the ones of the display library).
Best regards _________________ LCD Menu | Proportional Fonts |
pier_pe
Posted: Sun Nov 27, 2016 5:47 pm Post subject: |
Hello.
Help me anyone in the configuration file ILI9341.inc?
I want to run 16bit display mode under arduino mega 2560.
I do not know how to configure file .inc.
The arduino mega pins DB0-DB7 controls the port C pins and DB8-DB15 port A.
D / C is a pin PD7
CS to pin PG1
WR to pin PG2
RESET pin is PG0
Set somebody .inc file under such control and ATmega2560?
The problem is also with a sample program.
There is an error in this location:
' =========== Rotation ============
For Pixels = 0 To 4
Lcd_set_rotation Pixels <<<<<<<<---------------------------------HERE IS ERROR
Lcd_clear Color_white
Y = Lcd_screen_height - 20
Lcd_fill_rect 0 , Y , Lcd_screen_width , Lcd_screen_height , Color_black
Y = Y + 4
Statustext = "Rotation " + Str(lcd_rotation)
Lcd_tt_text Statustext , 10 , Y , Color_white
X = Lcd_screen_width - 80
X = X / 2
Y = Lcd_screen_height - 155
Y = Y / 2
Restore Hand
Lcd_pic_flash X , Y , 80 , 155
Waitms 1500
Bascom gives this error:
Error: Line 71: 175 Different type parameter passed then DECLARED [PIXELS], in File: E: \ Electronics \ Bascom \ ILI9341 \ ili9341.bas |
pier_pe
Posted: Sun Nov 27, 2016 7:12 pm Post subject: |
Hey, I know what the pinout is Arduino Mega.
I wrote a display is controlled by arduino just do not know how to configure the .inc file to display work on the Arduino Mega. |
Posted: Sun Nov 27, 2016 7:51 pm Post subject: |
Quote: | Lcd_set_rotation Pixels <<<<<<<<---------------------------------HERE IS ERROR |
I think.."Lcd_set_rotation(Pixels) <<<<<<<<---------------------------------HERE IS WHY"  |
pier_pe
Posted: Sun Nov 27, 2016 8:13 pm Post subject: |
Error corrected. Variable used was inadequate.
I have for a whole bunch of other errors:
Error : 86 Line : 455 Invalid parameter for CONFIG parameter or value [8] , in File : Colors565.inc
Error : 71 Line : 1146 Different parameter type passed then declared [COLOR_L] , in File : Colors565.inc
Error : 71 Line : 1146 Different parameter type passed then declared [COLOR_H] , in File : Colors565.inc
Error : 242 Line : 90 Source variable does not match the target variable [ 0] , in File : ProportionalFont.inc
Error : 46 Line : 93 Assignment error [R23: 0 TEMPINDEX: 301] , in File : ProportionalFont.inc
Error : 242 Line : 114 Source variable does not match the target variable [ 0] , in File : ProportionalFont.inc
Error : 242 Line : 117 Source variable does not match the target variable [ 0] , in File : ProportionalFont.inc
Error : 46 Line : 121 Assignment error [R23: 0 TABLECHAR: 301] , in File : ProportionalFont.inc
Error : 242 Line : 139 Source variable does not match the target variable [ 0] , in File : ProportionalFont.inc
Error : 242 Line : 147 Source variable does not match the target variable [ 0] , in File : ProportionalFont.inc
Error : 242 Line : 151 Source variable does not match the target variable [ 0] , in File : ProportionalFont.inc
Error : 242 Line : 162 Source variable does not match the target variable [ 0] , in File : ProportionalFont.inc
Error : 46 Line : 164 Assignment error [R11: 0 FONTDATA: 301] , in File : ProportionalFont.inc |
