[solved] What happened to endif?
Sebastian.Heyn
PostPosted: Tue Apr 07, 2015 2:11 pm    Post subject: [solved] What happened to endif? Reply with quote
since I have updated to the latest version, "endif" cannot be used any longer. You have to use "end if"
Is this a bug or was that changed for any good reason?
PostPosted: Tue Apr 07, 2015 8:45 pm    Post subject: Reply with quote
as you can see from the help, endif does not exist. only #endif
this because bascom was inspired by QB and VB which use end if and not endif.
so it is not a bug.
The line auto reformat function changes ? into Print and endif into end if, etc. and since this was called as part of the compilation, the compiler would not mind.
but since a part is rewritten, it is now flagged as an error. I did add it back to the next update so that users do not have to change old code.
