changing File attributes
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR-DOS
hallo2
PostPosted: Thu Apr 02, 2015 10:25 am    Post subject: changing File attributes Reply with quote
i would like to change the file attribute of a file (read/write access, this is used to enable / disable wifi of an wifi sd card)
in the avr-dos library there only seems to be the command getattr to read the byte - is there a way to write it too ?
I looked in the library but i do not really understand what is going on there
[_GetAttr]
$EXTERNAL _GetDirEntry , _GetFileAttribute , _SearchDirEntry
_GetAttr:
.OBJ 93FF
.OBJ 93EF
   rcall _SearchDirEntry_CheckFileName
   rjmp _GetAttr1
_GetAttr0:
.OBJ 93FF
.OBJ 93EF
   rcall _GetDirEntry_0
_GetAttr1:
.OBJ 91AF
.OBJ 91BF
   brcc _GetAttr2
.OBJ 2788
.OBJ 938C
.OBJ 9508
_GetAttr2:
   rjmp _GetFileAttribute
[end]
Thanks,
Daniel
PostPosted: Thu Apr 02, 2015 11:39 am    Post subject: Reply with quote
this code is used by the GETATTR() function.
There is no SETATTR. Maybe Josef can have a look at it?
hallo2
PostPosted: Thu Apr 02, 2015 11:51 am    Post subject: Reply with quote
yes i know that.
If i understood what happens in the getattr i was wondering if i can write an setattr Smile
but i don't understand it Wink
Thanks for the help
PostPosted: Thu Jun 04, 2015 12:07 pm    Post subject: Reply with quote
Josef has added setattr.
it will be in the next update.
if you want to test it, write to support. do not forget to supply serial.
here is a preview of the code :
'                        simulate-AVR-DOS.bas
'  simulate AVR-DOS using virtual XRAM drive
$regfile = "M128def.dat"
$crystal = 16000000
' Adjust HW Stack, Soft-Stack and Frame size to 128 minimum each!!!
$hwstack=128 : $swstack=128 : $framesize=128
$xramsize = &H10000  'specify 64KB of XRAM for the file system
$sim 'for simulation only !
$baud = 19200
Config Clock = Soft
Config Date = Mdy , Separator = dot
Dim Btemp1 As Byte ,battr1 as Byte, battr2 as Byte
$include "Config_XRAMDrive.bas"                             ' Does drive init too
$include "Config_AVR-DOS.BAS"
Print "Wait for Drive"
If Gbdriveerror = 0 Then
   Print "Init File System ... ";
   Btemp1 = Initfilesystem(1)                                ' Partition 1
                                          ' use 0 for drive without Master boot record
   If Btemp1 <> 0 Then
      Print  "Error: " ; Btemp1 ; " at Init file system"
   Else
      Print  " OK"
      Print  "Filesystem: " ; Gbfilesystem
      Print  "FAT Start Sector: " ; Glfatfirstsector
      Print  "Root Start Sector: " ; Glrootfirstsector
      Print  "Data First Sector: " ; Gldatafirstsector
      Print  "Max. Cluster Nummber: " ; Glmaxclusternumber
      Print  "Sectors per Cluster: " ; Gbsectorspercluster
      Print  "Root Entries: " ; Gwrootentries
      Print  "Sectors per FAT: " ; Glsectorsperfat
      Print  "Number of FATs: " ; Gbnumberoffats
Else
   Print  "Error during Drive Init: " ; Gbdriveerror
Dim strDummy as String * 12
Dim Datei As String * 12 , Attribut As Byte
Datei = "Test1.txt"
Open Datei For Output As #11
Print #11 , "Testzeile1"
Close #11
open "Test2.txt" For output as #11
Print #11, "Testzeile2"
close #11
open "Test3.txt" for output as #11
Print #11, "Testzeile3"
close #11
' Set readonly Bit in Test1.txt
Attribut = &B00000001
Setattr Datei , Attribut
' Reset Archib-Bit in test1.txt
Attribut = &B00100000
clearattr Datei , Attribut
' Check for Filename with wildcard, which is not supported
Datei = "Test*.txt"
Print gbDOSError
Datei = DIR("Test*.txt")
while Datei > ""
   SetAttr Attribut
   Datei = DIR()
wend
While Datei > ""
   battr1=Getattr()
   clearattr Attribut
   battr2=Getattr()
   print datei ;" "; battr1;" " ; battr2
   Datei = DIR()
wend
mmarlette
PostPosted: Thu Jun 04, 2015 2:29 pm    Post subject: Reply with quote
Very nice!
Thank you Josef and Mark for GREAT products and exceptional support!!!
Mark- For ones that purchased an AVR-DOS commercial license, how do we get the updated source? SLA, support, DL page?
Regards,
PostPosted: Thu Jun 04, 2015 3:31 pm    Post subject: Reply with quote
We update the package with a new update of bascom. so when you have registered at register.mcselec.com you can download it from there.
We post a news topic on the mcs homepage when a package is updated.
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR-DOS All times are GMT + 1 Hour
