rafael_jimenez
Posted: Wed Mar 11, 2015 11:52 am Post subject: 12 Volt Car battery charger with ADC |
Hello People,
I'm doing a battery charger for my car,but can not get me as I wish functions.
in my code, I read the ADC status every two seconds, I think it is configured well timer1,
but the timer1 makes me blink on port B, 0 each interruption, when the battery is charging,
maybe you can tell me where my problem?
by the way,
under conditions( IF Then , I have tried in various ways) that would begin charging the battery when low volt 12.20
but I can not get the relay is activated when the battery is low volt 12.20,
maybe someone can lend a hand, please.
Code: | '*******************************************************************************
'** 12 Volt Car Battery Charger Monitor
'** Battery 68Ah 560A.
'** Battery need 14,40 Volt constant current
'** Compiler version :2.0.7.8
'** Compiler build :2.0.7.8.004
'** IDE version :2.0.7.8.003
'** Windows OS :Windows 7 Ultimate
'** Windows Sp : Service Pack 1
'** Rafael B.Jimenez
$regfile = "m32def.dat" ' Atmega32
$crystal = 1000000 '1Mhz
$hwstack = 20
$swstack = 20
$framesize = 20
'$sim
Dim A As Byte 'for 14 x ADC
Dim Voltage As Word 'calculated voltage ADCvalue
Dim Valueadc As Word 'Battery Voltage
Dim Timecount As Word
Dim Displayvolt As String * 3 'convert number to string for decimal point value
Dim Voltstring As String * 4
Config Portb.0 = Output 'Switch Solid State Relay
Config Porta.6 = Input ' pin for ADC
'----------configuration Timer1--------------
Config Timer1 = Timer , Prescale = 64
Enable Timer1
On Timer1 Isrtimer1
Timer1 = 34286
'_________________________________________
'_______________Configuration LCD ________________________________
Config Lcdpin = Pin , Rs = Portc.2 , E = Portc.3 , Db4 = Portc.4 , Db5 = Portc.5 , Db6 = Portc.6 , Db7 = Portc.7
Config Lcd = 20 * 4
'---------------------Configuration ADC----------------------
Start Adc
Wait 2
'__________________________________________________
Isrtimer1:
Reset Portb.0 'Relay is OFF
Waitms 5
Valueadc = 0
For A = 1 To 14
Valueadc = Valueadc + Getadc(6)
Next A
'---------display state ---------------
If Valueadc > 4176 Then ' if the value is over 14,40, 4176/14,40 = 29
Lcd "FuLL"
If Valueadc = 0 Then 'when value adc cero , no battery
Locate 1 , 1
Lcd " no "
Locate 2 , 1
Lcd "battery"
If Valueadc < 4076 And Valueadc > 0 Then 'If valueADC are under ValueADC and over cero
Set Portb.0 'Switch Relay ON
Voltage = Valueadc / 29
Displayvolt = Str(voltage)
Voltstring = Format(displayvolt , " 0.0")
Locate 1 , 1
Lcd "charging"
Locate 2 , 1
Lcd Voltstring ; " V"
Final:
Reset Portb.0 'switch Relay OFF
Lcd "full"
Wait 2
your help is appreciated
Thank you
snipsnip
Posted: Wed Mar 11, 2015 12:45 pm Post subject: |
Try not using CLS, instead just print extra spaces to over write the longest text ie "hello world" will be replaced with "gone ........... "(dots are spaces)
CLS Takes a long time!!
Also - why you doing everything in the interrupt - do as little as possible. you've set it for two secs but have a wait 2 at the end of it before the exit ??
Id re-write the whole thing without using interrupts - You don't need it for "get adc". keep it simple.
Posted: Wed Mar 11, 2015 12:51 pm Post subject: |
Please do not put your program in the ISR. What you should do is keep the ISR and short as possible. What you should do is just set a flag in the ISR and the main program looks at this flag.
Something like:
if Flag=1 then
do something
flag=0
end
ISR:
Flag=1
return
Posted: Wed Mar 11, 2015 12:54 pm Post subject: |
- I removed your serial nr. from your post.
how do you connect the battery to the A/D converter input? I assume you have a resistor divider. Since you have a reference of AVCC, which is 5v ? make sure the maximum input is 5V. (use a zener to protect against overload).
I do not get this code :
For A = 1 To 14
Next A
if you want an average you need to divide it.
i also do not get the fact that you have an empty do..loop and use an ISR.
you can simply put your ISR code inside this loop.
Last, increase $hwstack to 40 when using an ISR. _________________ Mark |
rafael_jimenez
Posted: Thu Mar 12, 2015 12:02 pm Post subject: |
Thank you very much,
Hello Mr. snipsnip,
you are reason, but I did only to see Voltage State, because my code is for Attiny45 without display
Thank you
Hello Mr.i.dobson,
I donīt have to much experience with Interrupt but I make change in my code now.
Hello Mr. Arbert, Sorry for my error ,
I Do Test with one Adjustable Power Supply from 11,80V to 16,80V.
Your are reason, I have Resistor divider but with Pot 10K, so
Ground 5K6 >>>Pot 10K<<<< 100K Resistor to 12V + Battery,
I Adjust with Pot the ADC to work fine.
Now my code Work.
But
[code]
''** Windows OS :Windows 7 Ultimate
$hwstack = 40
$swstack = 40
$framesize = 40
'$sim
Config Lcd = 20 * 4
Cursor = Off
Start Adc
Valueadc = 0
For A = 1 To 15
Next A
Portb.0 = 0
Lcd "FuLL"
' Portb.0 = 1
Locate 1 , 1
Lcd " No "
Locate 2 , 1
Lcd "Battery "
If Valueadc < 4177 And Valueadc > 0 Then 'If valueADC are under ValueADC and over cero
Portb.0 = 1 'Switch Relay ON
Locate 1 , 1
Lcd "charging"
Locate 2 , 1
Lcd Voltstring ; "V "
I mean:
I want that when the Port-B is low is kept low until the voltage of the battery reaches 12 volts, the battery should always be between 12.20 to 12.30 volt and then under 12,20 the PortB.0 go High.
I test divers Form but do not get fine.
maybe someone has a better idea than I.
Always thought as my code works, but want it
when the value reaches 12.20 adc disable relays
Thnak you very much.
Regards |
Deanus
Posted: Sun Mar 15, 2015 8:53 am Post subject: |
Hi Rafael_jimenez,
I agree with the others whe they say do the minimum abount possible sutch as set a flag and do the rest in the main loop.
A couple of things with battery chargers,
1) Turn OFF the charging voltage Before measuring the battery voltage else you will only be reading the charge voltage and the program will terminate the charge too early.
2) You don't mention what type of battery you are charging. NiMh, NiCd, SLA, LiIo all have different charging patterns.
3) I really would like to see the battery that requires charging anywhere from Quote: | '** Battery 68Ah 560A. | . Quite a battery. Submarine battery maybe?
4) After the
Next A |
you should do a" Valueadc /15" to average the number out, and to deal with smaller numbers. Not strickly necessary but thats what I would do.
5) what is your ADC reference voltage set to ?
6) Your voltage divider needs looking at. If you say
Quote: | Ground 5K6 >>>Pot 10K<<<< 100K Resistor to 12V + Battery | The using the calculator at this site, http://www.raltron.com/cust/tools/voltage_divider.asp
Then when the pot is at the uppermost voltage to the ADC is 0.6V
Input Voltage 12V
R1 100000r
R2 5600r
Output Voltage 0.636V
When the input voltage is 1V the output to the ADC is 0.053V
These voltages to the ADC are too low. The ADC measures voltages from 0v to 5V |
rafael_jimenez
Posted: Sun Mar 15, 2015 1:14 pm Post subject: |
Hello Deanus,
Thank you for you answer,
My Battery is for Car, GigaWatt Calcium Technology and form manufacturer say need Constant 14,40 volt,
my Adjustable constant Power Supply is from 0Volt to 15Volt 4Amp
I do so
For A = 1 To 15
Next A
for better unit resultad,
Sorry, perhaps ye not understand my explanation, I use 2 Resistor and one Potentiometer in my Resistor dividir to Adjust the correct ADC Value for Battery and looking so,
GND<5K6> (to 10K Potentiometer here to adc(6) <100> to Battery Plus
please See Schematic circuit.
My code prepare for one Attiny45 with Led charging control.
My code it works, but only I nedd when Battery is to 14,40 Volt Switch Off and Waiting when Battery voltage come down to 12,30 Volt, my Code doe Hystery and continuous loading all,
I need a solution, when the battery is charged burdens stop and wait until it is depleted
I am no to much experiencie with bascom , I am I am an electrician
Thank you for you help
Regards |
Posted: Sun Mar 15, 2015 8:42 pm Post subject: |
This example show simple logic. You can set "name" for constans for better code readable and then use simple "state of unit mechanism"
State of unit You can change in any part/ place of code and then in next loop another part of code will be run.
Dim Status As Byte
Const Unknown = 0
Const Charging = 1
Const Discharging = 2
'### program START ###
'this is only example to show logic
Valueadc = Getadc(6)
Select Case Status
'after Boot
Case Unknown
Select Case Valueadc
Case 0 To 11.0 V ' insert Your calculated value
Home : Lcd "No battery "
Case 11.1 To 14 , 3 V
Home : Lcd "Charging... "
Status = Charging
Set Relay
Case 14 , 4 To 15 , 3 V
Home : Lcd "Battery Full"
Status = Dicharging
End Select 'end select voltage after boot
'if unit charging battery
Case Charging
Case 0 To 11.0 V
'shortcut protection
Reset Relay
Status = Unknown
Case
14 , 4 To 15 , 3
Status = Dicharging
End Select 'end select when charging
Case Discharging
Case 12.2 V To 12 , 4 V
Status = Charging
Set Relay
End Select 'end select when waiting for discharge
End Select 'end select STATUS
'### END ###
P_Santos
Posted: Mon Mar 16, 2015 4:50 pm Post subject: |
I take this post to try to know how to properly do the evaluation of the percentage of the autonomy of a Litium battery.
I think that when we are measuring the voltage it must will have to be injected a load to the battery.
Will my reasoning correct?
P_Santos |
rafael_jimenez
Posted: Sun Mar 22, 2015 1:31 pm Post subject: |
Thank you EDC,for you logic Function, but no undestand to much, I Teste your code, but I can not find good results,
I test now so
Code: | '* *******************************************************************************
$regfile = "m168def.dat" ' Atmega32
$crystal = 8000000 '1Mhz
$hwstack = 40
$swstack = 40
$framesize = 40
'$sim
Dim A As Byte 'for 15 x ADC
Config Portb.0 = Output 'Solide Stat Relay
Config Portd.6 = Output ' by low led Flash
Config Portd.7 = Output 'Reserve
Config Portc.0 = Input ' pin for ADC
Relay Alias Portb.0
Led Alias Portd.6
Config Lcdpin = Pin , Rs = Portd.0 , E = Portd.1 , Db4 = Portd.2 , Db5 = Portd.3 , Db6 = Portd.4 , Db7 = Portd.5
Config Lcd = 20 * 4
Cursor = Off
Start Adc
' __________________________________________________
Relay = 0
Valueadc = 0
For A = 1 To 15
Valueadc = Valueadc + Getadc(0)
Next A
Case 00000 To 12225 : Gosub Status ' 0 Volt to 12.25volt Battery is Low
Waitms 50
Case 12226 To 14410 : Gosub Charging ' 12.26Volt to 14.40 Battery Charging
Waitms 50
Case 14511 To 15421 : Gosub Full '14.45 to 15.40 Battery is Full
Waitms 50
Full:
Locate 1 , 1
Lcd "Battery is "
Locate 2 , 1
Lcd "FuLL "
Relay = 0 'relay is OFF
Status:
Toggle Led ' led flash by low battery
Waitms 50
Locate 1 , 1
Lcd "Battery is "
Locate 2 , 1
Lcd " Low "
Relay = 1 ' relay is ON
Charging:
Relay = 1 'Switch Relay ON
Voltage = Valueadc / 100
Locate 1 , 1
Lcd "charging "
Locate 2 , 1
Return |
Result,
When Battery is Full 14,40 Volt and Volt come Down battery come back to charging , so is no my plan,
I wish thats ,when battery are Full 14,40 volt and Battery is under 12,30 volt beginn to charging and no under 14,40 volt.
I donīt Find one logic Soluction.
someone hat best Ideas?.
Please I need help.
Thank you |
Posted: Sun Mar 22, 2015 2:04 pm Post subject: |
Try this joined code Ofcourse some bug can be..
Code: | '$sim
$hwstack = 40
$swstack = 40
$framesize = 40
Config Lcd = 20 * 4
Cursor = Off
'---------------Configuration ADC---------------------------------
Start Adc
Config Portb.0 = Output : Relay Alias Portb.0 'Solide Stat Relay
Config Portd.6 = Output : Led Alias Portd.6 ' by low led Flash
Dim Displayvolt As String * 5 'convert number to string for decimal point value
Dim Status As Byte
Const Unknown = 0
Const Charging = 1
Valueadc = 0
For A = 1 To 15
Next A
Select Case Status
'after Boot
Case Unknown
Case 0 To 11000
Case 12226 To 14510
Status = Charging
Set Relay
Case 14511 To 15421
Status = Discharging
Case Charging
Case 0 To 9000
Reset Relay
Status = Unknown
Case 14511 To 15421
Reset Relay
Case Discharging
Case 0 To 11000
Status = Unknown
Case 11001 To 12225
Status = Charging
Set Relay
Displayvolt = Format(displayvolt , " 0.0")
Lowerline : Lcd Displayvolt ; "V "
'### END ###
rafael_jimenez
Posted: Sun Mar 22, 2015 2:54 pm Post subject: |
Thank very much EDC
Now you function , very nice
I studie you Code .
I wannt now one Ask,
to see nummber in decimal in Display but so
00.00, I test with String but I do not get the point.
can you give me an example, Please.
Thank you to much.
Rafael |
rafael_jimenez
Posted: Mon Mar 23, 2015 12:24 pm Post subject: |
Ok now i understand,
Thank for your clarification.
Regard
Raffi |
