After bootloader works, but through the programmer does not
Goto page 1, 2, 3  Next
sasha_1973
PostPosted: Wed Mar 18, 2015 4:12 am    Post subject: After bootloader works, but through the programmer does not Reply with quote
Health to you!
There was an inexplicable problem: - after bootloader works, but through the programmer does not want to, please tell me, what could be the reason?
Tested Bascom 2.0.7.1; 2.0.7.8
Programmers - USBISP; USBISP MKII
Previously, these problems were not observed!
PostPosted: Wed Mar 18, 2015 7:27 am    Post subject: Reply with quote
If the program is flashed via ISP, it overwrites the bootloader, the reset vector still points then to the bootloader section and fails accordingly. You need to change the BOOTRST fuse.
sasha_1973
PostPosted: Wed Mar 18, 2015 10:18 am    Post subject: Reply with quote
Does not work. Fyuz set correctly.
PostPosted: Wed Mar 18, 2015 10:50 am    Post subject: Reply with quote
If the BOOTRST fuse is set correctly (unprogrammed=1), then some more possible effects could be:
1) the bootloader prepares anything for the external attached hardware
2) the bootloader sets up some of the internal controller hardware, which the application itself forgets to set up
3) the bootlader creates itself a delay, which allows the attached hardware to get ready
4) the ISP programmer is disconnected from USB, but not from ISP, which may block the used ISP-pins
For 1, I don't see anything in the bootloader doing this, 2 only the UART gets set up, 3 maybe, 4 maybe.
You better describe "does not want to": does it not work at all, or does only some function not work as intended?
And show a screen shot of fuse settings.
Next step: write a small program, which simply toggles a pin, or blinks a led, to test that normal program start works.
Evert :-)
PostPosted: Wed Mar 18, 2015 9:42 pm    Post subject: Reply with quote
Do you remove the ISP when trying?
Keep in mind that if you use the hardware SPI with the Noss option you need to set the SS pin (B2) to output, think your program stucks on the Config spi, helpfile:
In order to use the SPI in master mode, you need to set the SS pin to output. You only need to set the pin to output when you use the NOSS=1 option.
#if Const_realization_spi = 0
      Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = High , Phase = 0 , Clockrate = 4 , Noss = 1
      Config portb.2 = output
#endif
sasha_1973
PostPosted: Thu Mar 19, 2015 3:11 am    Post subject: Reply with quote
The note says: --"1 or 0. Use 1 when you do not want the SS signal to be generated in master mode." I have done so and.
Const Const_realization_spi = 0 ' If "0" - implementation of hardware (hardware terminals), if "1" - implementation of software (any conclusions)
#endif
#if Const_realization_spi = 1
Config Spi = Soft , Din = Pind.5 , Dout = Portd.6 , Clock = Portd.7 , Ss = None
#endif
Cs_max7219 Alias Portb.0 : Config Cs_max7219 = Output
Spsr.0 = 1 : Spcr.0 = 0 : Spcr.1 = 0 ' F_spi = F_osc / 2; Double Speed (CK/2) Master SPI Mode
Spiinit
Waitms 50
If it would not be right, would not work and after the bootloader
sasha_1973
PostPosted: Thu Mar 19, 2015 3:21 am    Post subject: Reply with quote
It does not work exactly the source! Any other works without problems.
PostPosted: Thu Mar 19, 2015 8:46 am    Post subject: Reply with quote
Nearly impossible to understand what you write.
Does that say, that other code, for example a blink-code, does work, but the attached code in your top-post does not work at all?
Or does it say, that your attached code only works partly?
Did you even try to understand, what Evert wrote?
You do not set the SS-pin to output in your code.
Still it would work, if the SS-pin would be pulled high by an external resistor, but if the circuit lacks also this resistor, the pin is able to float.
Open pins have a very high input impedance and thus they may take random states.
As Atmels datasheet reads:
If SS is configured as an input, it must be held high to ensure Master SPI operation. If the SS pin is driven low by peripheral circuitry when the SPI is configured as a Master with the SS pin defined as an input, the SPI system interprets this as another master selecting the SPI as a slave and starting to send data to it. To avoid bus contention, the SPI system takes the following actions: ...
it becomes clear, that if the SS-pin is not output or in a defined state, the whole thing works only randomly.
The reason it works with bootloader but not with ISP, may be looked up in the magic crystal ball, but is otherwise of no further interest, as first you have to correct either your code or your circuit.
So this:
may be the wrong conclusion. However, still I can only guess, what you want to say.
Would you mind to use google translator, or a similar service?
sasha_1973
PostPosted: Thu Mar 19, 2015 4:29 pm    Post subject: Reply with quote
[/quote]
Would you mind to use google translator, or a similar service?[/quote]
And you think I am than I use?
А Вы думаете, я чем я пользуюсь?
PostPosted: Thu Mar 19, 2015 5:02 pm    Post subject: Reply with quote
"And you think I'm what I use"
Better would be:
"What do you think, what I use"
Ok, I guess Google has to work on it Very Happy
How about the tech details: did you set the SS-pin to output?
sasha_1973
PostPosted: Thu Mar 19, 2015 5:15 pm    Post subject: Reply with quote
А это по Вашему, что?
And it is in your opinion, what?
PostPosted: Thu Mar 19, 2015 5:23 pm    Post subject: Reply with quote
PB0 is the pin you use for CS of the max7219, but we do not talk about that.
We talk about the ATMega328P SS-pin on PB2, this pin needs to be set either to output or pulled high externally, to make the SPI work properly as master.
It does not matter, if you do not use this pin at all, as these are the requirements given by Atmel.
See my excerpt above of the datasheet.
sasha_1973
PostPosted: Thu Mar 19, 2015 5:29 pm    Post subject: Reply with quote
Хорошо, тогда почему не работает программный SPI ?
Well, then why do not run the soft SPI ?
PostPosted: Thu Mar 19, 2015 5:52 pm    Post subject: Reply with quote
Try this, it gave me a better translation than Google:
http://www.online-translator.com/
For your question: how would I know? We did not talk about that.
Your code uses Const Const_realization_spi = 0, means hard-SPI, and that is what we talked about.
As far I read from the thread, you did not tell whether soft-SPI runs or runs not.
How would it be, if you set the *?&%§$? pin as output and report the result?
sasha_1973
PostPosted: Thu Mar 19, 2015 6:25 pm    Post subject: Reply with quote
Спасибо!
Thanks!
По поводу (Const Const_realization_spi = 0 или = 1), не имеет значения, не работают оба варианта!
In an occasion (to Const Const_realization_spi = 0 or = 1), doesn't matter, both options don't work!
Page 1 of 3
