Pset to Line
mcupwr
PostPosted: Sun Mar 15, 2015 1:30 pm    Post subject: Pset to Line Reply with quote
Does someone have tip how to join two pixels X1 and X2 with some pixels between (not line)
in this code (now is between two pixels empty space)? For an example, if is Y1=10 and next
randome Y2=20, between is empty line (space), but it should be solid, filled with pixels...
I was tried to use in code this math Y = Y1 +((y2 - Y1) /(x2 - X1)) *(x - X1) , but 2.0.7.8
BASCOM write an error "Data type of souorce and target variables does not match".....
X,Y are words...probably I use wrong sintax.. Rolling Eyes
'basic loop
   For X = 0 To 64
      Y = Some_random_value '0-2000
      Y = Y / 8
      Y = 32 - Y
      Pset X , Y , 255
Tnx
MCUpwr
snipsnip
PostPosted: Sun Mar 15, 2015 2:32 pm    Post subject: Reply with quote
you should be able to mod something from here..
http://en.wikipedia.org/wiki/Bresenham%27s_line_algorithm
copied from above.
plotLine(x0,y0, x1,y1)
dx=x1-x0
dy=y1-y0
D = 2*dy - dx
plot(x0,y0)
y=y0
for x from x0+1 to x1
if D > 0
y = y+1
'maybe just randomise whether x,y are plotted here?????
plot(x,y)
D = D + (2*dy-2*dx)
else
plot(x,y)
D = D + (2*dy)
JC
PostPosted: Tue Mar 17, 2015 1:38 am    Post subject: Reply with quote
Remember you can only have one math function per line, in Bascom.
This is a line plotting routine in Bascom, using Bresenham's algorithm.
Obviously this isn't the full program, but perhaps it will help get you started.
Glcdline:
   'Draw a Straight Line on the GLCD, Pixel Coordinates.
   'Use Bresenham's algorithm.
   'On Entry have: (GX1,GY1) and (GX2,GY2)
   'GX1, GX2: Columns: 0-127, Left to Right
   'GY1, GY2: Rows: 0-63, Top Down
   'Supports the Inverse Mode Flag, as does Text.
   'Error Checks for valid location prior to plotting, (within GPixSet).
   'Uses GPixSet
   'Set Pixel Value for subsequent GPixSet routine
   If I = 1 Then
      Pv = 0                                                'Pixel = Off, Inverted
   Else
      Pv = 1                                                'Pixel = On, black on Clear
   'First look at Delta X & Delta Y, see slope of line, most flat or vert
   Gdx = Gx2 - Gx1
   Gdx = Abs(gdx)
   Gdy = Gy2 - Gy1
   Gdy = Abs(gdy)
   Vert = 0                                                 'Line is mostly horz, Slope < 45 degrees
   If Gdy > Gdx Then
      Vert = 1                                              'Line is mostly vertical, Slope > 45 deg
   'If line is mostly vertical, swap the coordinates
   If Vert = 1 Then
      Swap Gx1 , Gy1
      Swap Gx2 , Gy2
   'If line is R to L, then Swap
   If Gx1 > Gx2 Then
      Swap Gx1 , Gx2
      Swap Gy1 , Gy2
   Gdx = Gx2 - Gx1
   Gdy = Gy2 - Gy1
   Gdy = Abs(gdy)
   Lerr = Gdx / 2
   Gly = Gy1
   If Gy1 < Gy2 Then
      Ystep = 1
   Else
      Ystep = -1
   For Glx = Gx1 To Gx2                                     'Plot the points
     If Vert = 1 Then
         'Plot (Gly,Glx)
         Pc = Low(gly)
         Pr = Low(glx)
      Else
         'Plot (Glx,Gly)
         Pr = Low(gly)
         Pc = Low(glx)
      Gosub Gpixset                                         'Plot the point
      Lerr = Lerr - Gdy
      If Lerr < 0 Then
         Gly = Gly + Ystep
         Lerr = Lerr + Gdx
   Next Glx
Evert :-)
PostPosted: Tue Mar 17, 2015 9:06 am    Post subject: Re: Pset to Line Reply with quote
mcupwr wrote:
X,Y are words...
Think that PSET expects bytes for X and Y.
