pinkfloyd11
Posted: Wed Mar 11, 2015 4:31 pm Post subject: Send SPI command to CC1101 |
Hello
I have problem on while(miso)
Read seem to work also without while(miso)
Write don't work again....
' SPI SEND and RECEIVE COMMAND
'Direttive al compilatore
$Regfile="m48pdef.dat"
$Crystal=4000000
$hwstack=40
$swstack=16
$framesize=32
$Include "CC1101 REGISTER.inc"
CONFIG Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 16, NOSS = 0
SPIINIT
DECLARE SUB CONFRONTA_DUE_LETTURE()
DECLARE SUB SCRIVI_LEGGI_E_CONFRONTA()
LED_ROSSO Alias PortD.3
CONFIG LED_ROSSO = Output
LED_VERDE Alias PortC.2
CONFIG LED_VERDE = Output
CHIP_SELECT Alias Portb.2
CONFIG CHIP_SELECT = Output
Dim Reg_Part_Number as Byte
Dim Reg_Curr_Version as Byte
Dim Reg_Sync_W as Byte
Dim Reg_Sync_R as Byte
Dim Byte_Ricevuto_1 as Byte
Dim Byte_Ricevuto_2 as Byte
Dim Valore_Scritto as Byte
Dim Valore_Letto as Byte
Dim S As String * 8
'Dal Datasheet table 43
'0x04 SYNC1 Sync word, high byte
'[7] := Header --> 1
'[6] := Burst --> 0
'[5-0] := Indirizzo Registro --> 0x00 --> 000100
'[Byte completo] = 00000100
S = "00000100"
Reg_Sync_W = binval (S)
'[6] := Burst --> 0
S = "10000100"
Reg_Sync_R = binval (S)
'Dal Datasheet table 44:
'0x30 (0xF0) PARTNUM Part number
'[6] := Burst --> 0
'[5-0] := Indirizzo Registro --> 0x30 --> 110000
'[Byte completo] = 10110000
S = "10110000"
Reg_Part_Number = binval (S)
'0x31 (0xF1) VERSION Current version number
'[6] := Burst --> 0
'[5-0] := Indirizzo Registro --> 0x30 --> 110001
'[Byte completo] = 10110001
S = "10110001"
Reg_Curr_Version = binval (S)
DO
'CALL CONFRONTA_DUE_LETTURE
CALL SCRIVI_LEGGI_E_CONFRONTA
Wait 1
LOOP
'_______________________________________________________________________________________
Byte_Ricevuto_1 = 11
Byte_Ricevuto_2 = 22
'READ 1
SET LED_ROSSO
RESET CHIP_SELECT
SPIout Reg_Part_Number, 1
SPIin Byte_Ricevuto_1, 1
SET CHIP_SELECT
waitms 200
RESET LED_ROSSO
Wait 1
'READ 2
SET LED_VERDE
RESET CHIP_SELECT
SPIin Byte_Ricevuto_2, 1
SET CHIP_SELECT
waitms 200
RESET LED_VERDE
waitms 400
IF Byte_Ricevuto_1 = Byte_Ricevuto_2 THEN
SET LED_ROSSO
WAIT 10
END IF
END SUB
Valore_Scritto = 11
Valore_Letto = 22
'WRITE ROSSO
SET LED_ROSSO
RESET CHIP_SELECT
waitms 1
while PINB.4=1
wend
SPIout Reg_Sync_W, 1
waitms 1
SPIout Valore_Scritto, 1
waitms 1
SET CHIP_SELECT
Waitms 200
RESET LED_ROSSO
'READ VERDE
SET LED_VERDE
Waitms 1
RESET CHIP_SELECT
Waitms 1
'while PINB.4=1
'wend
SPIout Reg_Sync_R, 1
waitms 1
SPIin Valore_Letto, 1
Waitms 1
SET CHIP_SELECT
waitms 200
RESET LED_VERDE
IF Valore_Scritto = Valore_Letto THEN
Valore_Scritto = 11
Valore_Letto = 22
SET LED_ROSSO
WAIT 5
RESET LED_ROSSO
WAIT 1
END IF
END SUB
