12 Volt Car battery charger with ADC
rafael_jimenez
PostPosted: Wed Mar 11, 2015 11:52 am    Post subject: 12 Volt Car battery charger with ADC Reply with quote
Hello People,
I'm doing a battery charger for my car,but can not get me as I wish functions.
in my code, I read the ADC status every two seconds, I think it is configured well timer1,
but the timer1 makes me blink on port B, 0 each interruption, when the battery is charging,
maybe you can tell me where my problem?
by the way,
under conditions( IF Then , I have tried in various ways) that would begin charging the battery when low volt 12.20
but I can not get the relay is activated when the battery is low volt 12.20,
maybe someone can lend a hand, please.
'** 12 Volt Car Battery Charger Monitor
'** Battery 68Ah 560A.
'** Battery need 14,40 Volt constant current
'** Compiler version :2.0.7.8
'** Compiler build   :2.0.7.8.004
'** IDE version      :2.0.7.8.003
'** Windows OS       :Windows 7 Ultimate
'** Windows Sp : Service Pack 1
'** Rafael B.Jimenez
$regfile = "m32def.dat"                                     ' Atmega32
$crystal = 1000000                                          '1Mhz
$hwstack = 20
$swstack = 20
$framesize = 20
'$sim
Dim A As Byte                                               'for 14 x ADC
Dim Voltage As Word                                         'calculated voltage ADCvalue
Dim Valueadc As Word                                        'Battery Voltage
Dim Timecount As Word
Dim Displayvolt As String * 3                               'convert number to string for decimal point value
Dim Voltstring As String * 4
 Config Portb.0 = Output                                    'Switch Solid State Relay
 Config Porta.6 = Input                                     ' pin for ADC
'----------configuration Timer1--------------
 Config Timer1 = Timer , Prescale = 64
Enable Timer1
On Timer1 Isrtimer1
Timer1 = 34286
'_________________________________________
'_______________Configuration LCD ________________________________
 Config Lcdpin = Pin , Rs = Portc.2 , E = Portc.3 , Db4 = Portc.4 , Db5 = Portc.5 , Db6 = Portc.6 , Db7 = Portc.7
Config Lcd = 20 * 4
'---------------------Configuration ADC----------------------
   Config Adc = Single , Prescaler = Auto , Reference = Avcc
   Start Adc
  Wait 2
'__________________________________________________
  Isrtimer1:
    Reset Portb.0                                           'Relay is OFF
        Waitms 5
    Valueadc = 0
   For A = 1 To 14
    Valueadc = Valueadc + Getadc(6)
    Next A
  '---------display state ---------------
     If Valueadc > 4176 Then                                ' if the value is over 14,40, 4176/14,40 = 29
    Cls
    Lcd "FuLL"
   If Valueadc = 0 Then                                     'when value adc cero , no battery
  Cls
 Locate 1 , 1
 Lcd "  no "
 Locate 2 , 1
 Lcd "battery"
   If Valueadc < 4076 And Valueadc > 0 Then                 'If valueADC are under ValueADC and over cero
    Set Portb.0                                             'Switch Relay ON
 Cls
      Voltage = Valueadc / 29
      Displayvolt = Str(voltage)
            Voltstring = Format(displayvolt , " 0.0")
            Locate 1 , 1
            Lcd "charging"
            Locate 2 , 1
    Lcd Voltstring ; " V"
    Final:
      Reset Portb.0                                         'switch Relay OFF
      Cls
        Lcd "full"
     Wait 2
your help is appreciated
Thank you
Regards
snipsnip
PostPosted: Wed Mar 11, 2015 12:45 pm    Post subject: Reply with quote
Try not using CLS, instead just print extra spaces to over write the longest text ie "hello world" will be replaced with "gone ........... "(dots are spaces)
CLS Takes a long time!!
Also - why you doing everything in the interrupt - do as little as possible. you've set it for two secs but have a wait 2 at the end of it before the exit ??
Id re-write the whole thing without using interrupts - You don't need it for "get adc". keep it simple.
i.dobson
PostPosted: Wed Mar 11, 2015 12:51 pm    Post subject: Reply with quote
Hello,
Please do not put your program in the ISR. What you should do is keep the ISR and short as possible. What you should do is just set a flag in the ISR and the main program looks at this flag.
Something like:
do
  if Flag=1 then
    do something
    flag=0
loop
end
ISR:
  Flag=1
  return
Regards
Ian Dobson
PostPosted: Wed Mar 11, 2015 12:54 pm    Post subject: Reply with quote
- I removed your serial nr. from your post.
how do you connect the battery to the A/D converter input? I assume you have a resistor divider. Since you have a reference of AVCC, which is 5v ? make sure the maximum input is 5V. (use a zener to protect against overload).
I do not get this code :
For A = 1 To 14
Next A
if you want an average you need to divide it.
i also do not get the fact that you have an empty do..loop and use an ISR.
you can simply put your ISR code inside this loop.
Last, increase $hwstack to 40 when using an ISR.
rafael_jimenez
PostPosted: Thu Mar 12, 2015 12:02 pm    Post subject: Reply with quote
Thank you very much,
Hello Mr. snipsnip,
you are reason, but I did only to see Voltage State, because my code is for Attiny45 without display Very Happy
Thank you
Hello Mr.i.dobson,
I donīt have to much experience with Interrupt but I make change in my code now.
Hello Mr. Arbert, Sorry for my error ,
I Do Test with one Adjustable Power Supply from 11,80V to 16,80V.
Your are reason, I have Resistor divider but with Pot 10K, so
Ground 5K6 >>>Pot 10K<<<< 100K Resistor to 12V + Battery,
I Adjust with Pot the ADC to work fine.
Now my code Work.
But
[code]
''** Windows OS :Windows 7 Ultimate
$hwstack = 40
$swstack = 40
$framesize = 40
'$sim
Config Lcd = 20 * 4
Cursor = Off
Start Adc
Valueadc = 0
For A = 1 To 15
Next A
Portb.0 = 0
Cls
Lcd "FuLL"
' Portb.0 = 1
Cls
Locate 1 , 1
Lcd " No "
Locate 2 , 1
Lcd "Battery "
If Valueadc < 4177 And Valueadc > 0 Then 'If valueADC are under ValueADC and over cero
Portb.0 = 1 'Switch Relay ON
Locate 1 , 1
Lcd "charging"
Locate 2 , 1
Lcd Voltstring ; "V "
I mean:
I want that when the Port-B is low is kept low until the voltage of the battery reaches 12 volts, the battery should always be between 12.20 to 12.30 volt and then under 12,20 the PortB.0 go High.
I test divers Form but do not get fine.
maybe someone has a better idea than I.
Always thought as my code works, but want it
when the value reaches 12.20 adc disable relays
Thnak you very much.
Regards
Deanus
PostPosted: Sun Mar 15, 2015 8:53 am    Post subject: Reply with quote
Hi Rafael_jimenez,
I agree with the others whe they say do the minimum abount possible sutch as set a flag and do the rest in the main loop.
A couple of things with battery chargers,
1) Turn OFF the charging voltage Before measuring the battery voltage else you will only be reading the charge voltage and the program will terminate the charge too early.
2) You don't mention what type of battery you are charging. NiMh, NiCd, SLA, LiIo all have different charging patterns.
3) I really would like to see the battery that requires charging anywhere from
. Quite a battery. Submarine battery maybe?
4) After the
For A = 1 To 15
Next A
you should do a" Valueadc /15" to average the number out, and to deal with smaller numbers. Not strickly necessary but thats what I would do.
5) what is your ADC reference voltage set to ?
6) Your voltage divider needs looking at. If you say
The using the calculator at this site, http://www.raltron.com/cust/tools/voltage_divider.asp
Then when the pot is at the uppermost voltage to the ADC is 0.6V
Input Voltage 12V
R1 100000r
R2 5600r
Output Voltage 0.636V
When the input voltage is 1V the output to the ADC is 0.053V
These voltages to the ADC are too low. The ADC measures voltages from 0v to 5V
rafael_jimenez
PostPosted: Sun Mar 15, 2015 1:14 pm    Post subject: Reply with quote
Hello Deanus,
Thank you for you answer,
My Battery is for Car, GigaWatt Calcium Technology and form manufacturer say need Constant 14,40 volt,
my Adjustable constant Power Supply is from 0Volt to 15Volt 4Amp
I do so
For A = 1 To 15
Next A
for better unit resultad,
Sorry, perhaps ye not understand my explanation, I use 2 Resistor and one Potentiometer in my Resistor dividir to Adjust the correct ADC Value for Battery and looking so,
GND<5K6> (to 10K Potentiometer here to adc(6) <100> to Battery Plus
please See Schematic circuit.
My code prepare for one Attiny45 with Led charging control.
My code it works, but only I nedd when Battery is to 14,40 Volt Switch Off and Waiting when Battery voltage come down to 12,30 Volt, my Code doe Hystery and continuous loading all,
I need a solution, when the battery is charged burdens stop and wait until it is depleted
I am no to much experiencie with bascom , I am I am an electrician
Razz
Thank you for you help
Regards
PostPosted: Sun Mar 15, 2015 8:42 pm    Post subject: Reply with quote
This example show simple logic. You can set "name" for constans for better code readable and then use simple "state of unit mechanism"
State of unit You can change in any part/ place of code and then in next loop another part of code will be run.
 Dim Status As Byte
 Const Unknown = 0
 Const Charging = 1
 Const Discharging = 2
'### program START ###
 'this is only example to show logic
    Valueadc = Getadc(6)
        Select Case Status
        'after Boot
         Case Unknown
               Select Case Valueadc
                  Case 0 To 11.0 V                          ' insert Your calculated value
                    Home : Lcd "No battery  "
                   Case 11.1 To 14 , 3 V
                     Home : Lcd "Charging... "
                      Status = Charging
                       Set Relay
                   Case 14 , 4 To 15 , 3 V
                     Home : Lcd "Battery Full"
                       Status = Dicharging
                 End Select                                 'end select voltage after boot
           'if unit charging battery
          Case Charging
                   Case 0 To 11.0 V
                    'shortcut protection
                     Reset Relay
                      Status = Unknown
                   Case
                     14 , 4 To 15 , 3
                       Status = Dicharging
                   End Select                               'end select when charging
           Case Discharging
                    Case 12.2 V To 12 , 4 V
                      Status = Charging
                       Set Relay
                   End Select                               'end select when waiting for discharge
           End Select                                       'end select STATUS
Wait 1
'### END ###
P_Santos
PostPosted: Mon Mar 16, 2015 4:50 pm    Post subject: Reply with quote
Hello,
I take this post to try to know how to properly do the evaluation of the percentage of the autonomy of a Litium battery.
I think that when we are measuring the voltage it must will have to be injected a load to the battery.
Will my reasoning correct?
Best regards
P_Santos
rafael_jimenez
PostPosted: Sun Mar 22, 2015 1:31 pm    Post subject: Reply with quote
Thank you EDC,for you logic Function, but no undestand to much, I Teste your code, but I can not find good results,
I test now so
$regfile = "m168def.dat"                                    ' Atmega32
$crystal = 8000000                                          '1Mhz
$hwstack = 40
$swstack = 40
$framesize = 40
'$sim
Dim A As Byte                                               'for 15 x ADC
 Config Portb.0 = Output                                    'Solide Stat Relay
 Config Portd.6 = Output                                    ' by low led Flash
 Config Portd.7 = Output                                    'Reserve
 Config Portc.0 = Input                                     ' pin for ADC
 Relay Alias Portb.0
 Led Alias Portd.6
 Config Lcdpin = Pin , Rs = Portd.0 , E = Portd.1 , Db4 = Portd.2 , Db5 = Portd.3 , Db6 = Portd.4 , Db7 = Portd.5
Config Lcd = 20 * 4
Cursor = Off
Cls
   Start Adc
' __________________________________________________
 Relay = 0
    Valueadc = 0
   For A = 1 To 15
    Valueadc = Valueadc + Getadc(0)
    Next A
            Case 00000 To 12225 : Gosub Status              ' 0 Volt to 12.25volt  Battery is Low
                          Waitms 50
            Case 12226 To 14410 : Gosub Charging            ' 12.26Volt to  14.40 Battery Charging
                                  Waitms 50
             Case 14511 To 15421 : Gosub Full               '14.45 to 15.40 Battery is Full
                                Waitms 50
   End Select
Full:
    Locate 1 , 1
    Lcd "Battery is      "
     Locate 2 , 1
    Lcd "FuLL      "
     Relay = 0                                              'relay is OFF
Status:
 Toggle Led                                                 ' led flash by low battery
Waitms 50
 Locate 1 , 1
 Lcd "Battery is    "
 Locate 2 , 1
 Lcd "   Low       "
 Relay = 1                                                  ' relay is ON
 Charging:
   Relay = 1                                                'Switch Relay ON
      Voltage = Valueadc / 100
            Locate 1 , 1
            Lcd "charging     "
            Locate 2 , 1
Result,
When Battery is Full 14,40 Volt and Volt come Down battery come back to charging , so is no my plan,
I wish thats ,when battery are Full 14,40 volt and Battery is under 12,30 volt beginn to charging and no under 14,40 volt.
I donīt Find one logic Soluction.
someone hat best Ideas?.
Please I need help.
Thank you
PostPosted: Sun Mar 22, 2015 2:04 pm    Post subject: Reply with quote
Try this joined code Smile Ofcourse some bug can be..
'$sim
$hwstack = 40
$swstack = 40
$framesize = 40
Config Lcd = 20 * 4
Cursor = Off
Cls
'---------------Configuration ADC---------------------------------
   Start Adc
 Config Portb.0 = Output : Relay Alias Portb.0              'Solide Stat Relay
 Config Portd.6 = Output : Led Alias Portd.6                ' by low led Flash
Dim Displayvolt As String * 5                               'convert number to string for decimal point value
 Dim Status As Byte
   Const Unknown = 0
   Const Charging = 1
  Valueadc = 0
   For A = 1 To 15
   Next A
        Select Case Status
        'after Boot
         Case Unknown
                  Case 0 To 11000
                   Case 12226 To 14510
                      Status = Charging
                       Set Relay
                   Case 14511 To 15421
                       Status = Discharging
          Case Charging
                   Case 0 To 9000
                     Reset Relay
                      Status = Unknown
                   Case 14511 To 15421
                       Reset Relay
           Case Discharging
                    Case 0 To 11000
                      Status = Unknown
                    Case 11001 To 12225
                      Status = Charging
                       Set Relay
    Displayvolt = Format(displayvolt , " 0.0")
    Lowerline : Lcd Displayvolt ; "V  "
Wait 1
'### END ###
rafael_jimenez
PostPosted: Sun Mar 22, 2015 2:54 pm    Post subject: Reply with quote
Thank very much EDC
Now you function , very nice Very Happy
I studie you Code .
I wannt now one Ask,
to see nummber in decimal in Display but so
00.00, I test with String but I do not get the point.
can you give me an example, Please.
Thank you to much.
Regards
Rafael
PostPosted: Sun Mar 22, 2015 3:18 pm    Post subject: Reply with quote
If I`m understand what You want then instead of this
You can
Voltage = Valueadc / 10 ' <-10 NOT 100 now..
    Displayvolt = Format(displayvolt , " +00.00")  'even plus sign can be added if You want
Remember that decimal point is a sign/char too so string must me bigger to acommodate characters.
..and remember that Status You can change anytime. So You can add Button for example and change Status immediately to Charging (without waiting to battery Low).
You can also reset Relay before measure voltage..everything can be better Very Happy
I think that code where is nothing to improve not exist Very Happy
rafael_jimenez
PostPosted: Mon Mar 23, 2015 12:24 pm    Post subject: Reply with quote
Very Happy Ok now i understand,
Thank for your clarification.
Regard
Raffi
