SPI stop to work when LCD is added
pinkfloyd11
PostPosted: Wed Mar 11, 2015 9:54 am    Post subject: SPI stop to work when LCD is added Reply with quote
Hello
I'm developing an spi monitor and simulate it in proteus 8.1 sp1.
In debug mode, on slave cpu, you can see the tipical hello world string be received correctly (see CHAR variable).
If I add LCD configuration code, trasmission from SPI end to work.
Have you any idea why happen this?
Thanks
bzijlstra
Bascom Ambassador
PostPosted: Wed Mar 11, 2015 2:12 pm    Post subject: Show the Bascom-code Reply with quote
Show us the Bascom-code
Ben Zijlstra
pinkfloyd11
PostPosted: Wed Mar 11, 2015 2:49 pm    Post subject: Reply with quote
it is inside the project but for semplicity i will copy here:
' SPI MASTER
$regfile = "m328pdef.dat"
$crystal = 16000000
$baud = 57600
$framesize = 128
$hwstack = 40
$swstack = 40
Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 16
SPIINIT
Dim Lunghezza as Byte
Dim Indice As Byte
Dim CHAR As String * 1
Dim Stringa_da_Inviare as String * 11
'MAIN
'PRINT "SPI MASTER"
Stringa_da_Inviare = "Hello World"
Lunghezza = Len(Stringa_da_Inviare)
For Indice = 1 To Lunghezza
CHAR = Mid(Stringa_da_Inviare , Indice , 1)
Spiout CHAR , 1
Waitms 10
'_______________________________________________________________________________________
' SPI SLAVE
$crystal = 16000000
$framesize = 128
$hwstack = 40
$swstack = 40
'CONFIGURAZIONE LCD
'Config PORTC = Output
'Config LCDPIN = Pin , Db4 = PORTC.2 , Db5 = PORTC.3 , Db6 = PORTC.4 , Db7 = PORTC.5 , E = PORTC.1 , Rs = PORTC.0
'Config Lcd = 16x2
'Cursor Off
'CONFIGURAZIONE SPI
Config Spi = Hard , Interrupt = On , Data Order = Msb , Master = No , Polarity = Low , Phase = 0 , Clockrate = 16
SPIINIT
ON SPI SPI_IRS
ENABLE INTERRUPTS
Dim CHAR As String *1
Dim Received_Bytes As Byte
'CLS
'MAIN
DO
LOOP
SPI_IRS:
SPIIN CHAR, Received_Bytes
'LCD Char
bzijlstra
Bascom Ambassador
PostPosted: Wed Mar 11, 2015 4:27 pm    Post subject: quick question Reply with quote
Jtag disabled?
pinkfloyd11
PostPosted: Wed Mar 11, 2015 4:58 pm    Post subject: Reply with quote
How do it?
I'm simulate under Proteus
