kiki
Posted: Mon Mar 09, 2015 3:44 pm Post subject: kiddieride music box |
hi, I just want to sharing my program i made..
here i make the program use for kiddierides machine.the hardware i use:atmega8,mp3 player(i use mp3 player cause i can't make the program using sd card ), 7segment for digital timer.and here is the code:
$regfile = "m8def.dat"
$crystal = 4000000
'$sim
Config Portb = Output
Config Portc.0 = Output
Config Portc.1 = Output
Config Portc.2 = Output
Config Portc.3 = Output
Config Pind.0 = Input
Config Pind.1 = Input
Config Pind.2 = Input
Config Pind.3 = Input
Config Portd.4 = Output
Config Portd.6 = Output
Config Portd.7 = Output
Tambah Alias Pind.0 'use for counting up
Kurang Alias Pind.1 'use for counting down
Menu Alias Pind.2
Coin1 Alias Pind.3
Srcoin Alias Portd.6
Mp3 Alias Portd.7
Dim Simpan As Integer
Dim C As Integer , C1 As Integer , C2 As Integer
Dim Uang As Byte , Uang1 As Byte , Uang2 As Byte 'uang = setting coin
Dim A As Byte 'a = timer1 , b = setting lompatan , c = pembukuan
Dim Angka As Byte
Dim Angka1 As Byte
Dim Angka2 As Integer
Dim Angka3 As Integer
Dim Count As Integer , Tem1 As Integer , Tem2 As Integer ,
Dim Rib As Integer , Rat As Integer , Pul As Integer , Sat As Integer
Config Timer1 = Timer , Prescale = 8
Enable Timer1
On Timer1 Nilai
Tcnt1 = 32768
Stop Timer1
A = 0
Reset Portd.4
Waitms 1
Atas:
Readeeprom Count , 0
If Count = -1 Then Count = 0
Readeeprom Uang , 5
If Uang = 255 Then Uang = 0
Rib = Count / 1000
Tem1 = Count Mod 1000
Rat = Tem1 / 100
Tem2 = Tem1 Mod 100
Pul = Tem2 / 10
Sat = Tem2 Mod 1
If Menu = 0 Then
Waitms 200
Goto Waktu
If Coin1 = 0 Then
Decr Uang
Waitms 100
If Uang = 0 Then
Incr C
If C = 10000 Then
C = 9999
Writeeeprom C , 15
Goto Bawah
Portb = Lookup(sat , Hitung)
Portc = &B0111
Waitms 1
Portb = Lookup(pul , Hitung)
If Rib = 0 And Rat = 0 And Pul = 0 Then
Portc = &B1111
Else
Portc = &B1011
Waitms 1
Portb = Lookup(rat , Hitung)
If Rib = 0 And Rat = 0 Then
Portc = &B1111
Else
Portc = &B1101
Waitms 1
Portb = Lookup(rib , Hitung)
If Rib = 0 Then
Portc = &B1111
Else
Portc = &B1110
Waitms 1
'====================setting waktu==============================================
Waktu:
If Menu = 0 Then
Waitms 200
Goto Coin
If Tambah = 0 Then
Waitms 200
Pul = Pul + 3
If Pul = 6 Then
Pul = 0
Incr Rat
If Rat = 10 Then
Rat = 0
Incr Rib
If Rat = 0 And Rib = 6 Then
Rat = 0
Rib = 0
Pul = 0
Sat = 0
If Rib = 2 And Rat = 4 Then
Rib = 0
Rat = 0
Angka = Sat * 1
Angka1 = Pul * 10
Count = Angka1 + Angka
Angka2 = Rat * 100
Count = Angka2 + Count
Angka3 = Rib * 1000
Count = Angka3 + Count
Writeeeprom Count , 0
If Kurang = 0 Then
Waitms 200
Pul = Pul - 3
If Pul = -3 Then
Pul = 3
Decr Rat
If Rib = 0 And Rat = -1 And Pul = 3 Then
Rib = 0
Rat = 0
Pul = 0
If Rat = -1 Then
Rat = 9
Decr Rib
Angka = Sat * 1
Angka1 = Pul * 10
Angka2 = Rat * 100
Angka3 = Rib * 1000
Portc = &B0111
Waitms 1
Portc = &B1111
Else
Portc = &B1011
Waitms 1
Portc = &B1111
Else
Portc = &B1101
Waitms 1
If Rib = 0 Then
Portc = &B1111
Else
Portc = &B1110
Waitms 1
'===============================setting coin====================================
Coin:
Readeeprom Uang , 5
If Menu = 0 Then
Waitms 200
Goto Pembukuan
If Tambah = 0 Then
Waitms 200
Incr Uang
If Uang = 5 Then
Uang = 0
Writeeeprom Uang , 5
If Kurang = 0 Then
Waitms 200
Decr Uang
If Uang = 255 Then
Uang = 5
Rib = Uang / 1000
Uang1 = Uang Mod 1000
Rat = Uang1 / 100
Uang2 = Uang1 Mod 100
Pul = Uang2 / 10
Sat = Uang2 Mod 10
Portc = &B0111
Waitms 1
'=============================pembukuan=========================================
Pembukuan:
Readeeprom C , 15
If C = -1 Then C = 0
Rib = C / 1000
C1 = C Mod 1000
Rat = C1 / 100
C2 = C1 Mod 100
Pul = C2 / 10
Sat = C2 Mod 10
Portc = &B0111
Waitms 1
Portc = &B1111
Else
Portc = &B1011
Waitms 1
Portc = &B1111
Else
Portc = &B1101
Waitms 1
If Rib = 0 Then
Portc = &B1111
Else
Portc = &B1110
Waitms 1
If Menu = 0 Then
Waitms 200
Goto Atas
If Tambah = 0 Then
Waitms 200
C = 0
Writeeeprom C , 15
If Kurang = 0 Then
Waitms 200
C = 0
Writeeeprom C , 15
'==========================start timer==========================================
Bawah:
Set Mp3
Wait 2
Set Portd.4
Start Timer1
Waitms 100
Reset Portd.4
Portc = &B0111
Waitms 1
Portc = &B1111
Else
Portc = &B1011
Waitms 1
Portc = &B1111
Else
Portc = &B1101
Waitms 1
If Rib = 0 Then
Portc = &B1111
Else
Portc = &B1110
Waitms 1
If Count = 0000 Then
Waitms 200
Stop Timer1
Reset Mp3
Goto Atas
'===========================timer1 routine======================================
Nilai:
Incr A
If A = 20 Then
Decr Count
A = 0
Rib = Count / 1000
Rat = Tem1 / 100
Tem2 = Tem1 Mod 100
Pul = Tem2 / 10
Sat = Tem2 Mod 10
If Pul = 9 And Sat = 9 Then
Count = Count - 40
Tcnt1 = 32768
Hitung:
Data &B00111111 , &B00000101 , &B01011011 , &B01001111
Data &B01100101 , &B01101110 , &B01111100 , &B00000111
Data &B01111111 , &B01100111
I already used the program but sometimes the program can get eror like the timer i set it can't save again and i must set again from first and my mp3 player suddenly can run by it self.so the program needs friend's helps to make the program perfect and not eror again ..thanks for your helps. |
bzijlstra
Posted: Mon Mar 09, 2015 4:23 pm Post subject: My two cents |
Just my two cents.... Try to input $Hwstack, $swstack and $framesize. If you don't put them in your code the defaults are used and these are a bit low.
And about the SD-card, what is exatly the problem? You are using AVR-DOS I presume? Can you show your configs? And what type of SD-card are you using?
Have fun
Ben Zijlstra |
kiki
Posted: Tue Mar 10, 2015 6:45 am Post subject: |
Ooo I see, but I don't know how to put the value to $hwstack,$swstack and $framesize hahaha cause I am in learning step . And about sd card I don't know how to start/begin the program software and hardware .but I wanna to say thanks cause bzijlstra already help me. |
kiki
bzijlstra
Posted: Tue Mar 10, 2015 8:41 am Post subject: stacks |
In the top of your program you put
$hwstack = 64
$swstack = 64
$framesize = 64
This wil override the default settings.
Have fun
Ben Zijlstra |
kiki
Posted: Tue Mar 10, 2015 12:09 pm Post subject: |
Oke .thanks very much sir ..I will fix my program with the value that sir give to me.. |
