Understanding FT800
jjl
PostPosted: Fri Feb 20, 2015 2:44 pm    Post subject: Understanding FT800 Reply with quote
Hi All.
I have a question regarding the operation / use of the FTDI FT800 chip / display.
I have the VM800C35A-D.
Let's say I draw a X- and an Y axis on the display. I will then sample some data and display them as dots in realtime.
Do I then have to send the hole command-list agian, including the XY-axis and the dots, so if I have 100 samples I have to send a command-list with more than 100 commands ????
Or another exampel: You have a screen with lots of buttons and you want one of them to blink, do I then again have to send all the commands for all the buttons ?
I hope I have misunderstood something Confused
Have a nice weekend.
Jens
Denmark
PeterM
PostPosted: Fri Feb 20, 2015 8:32 pm    Post subject: Reply with quote
Jens
Before I answer don't be overwhelmed by the amount of work needed to display
data or any Graphics because its not as bad as you think. You have to do things
in a slightly different way because you are now dealing with a Graphics Processing Unit
which has a lot of flexibility and power.
Don't make it sound that bad Smile, yes you have to send everything again but you
already did that in the first place by drawing the screen, sampling the data and displaying
the plots, so just repeat that process again.
Again, yes you have to draw everything, you just repeat the routine again with any changes needed.
Don't forget all the Graphic drawing can happen really fast (typically up to 60Hz).
If you have to erase something on the LCD you don't need to erase that area, just draw
the new graphics as needed.
Note: If you don't like that method there is a demo file called plot.bas which uses a different method of displaying data
which you can also look at.
Peter
PeterM
PostPosted: Fri Feb 20, 2015 8:38 pm    Post subject: Reply with quote
Jens
Peter
jjl
PostPosted: Sat Feb 21, 2015 10:19 am    Post subject: Reply with quote
Hi Peter.
Thank you for your reply.
Maybe I was a bit negative Evil or Very Mad
You are right, it's another way to control a display, one have to get used to it.
I can see all the good things, few wires, easy button control, simpel touch control with the Tag command, no need for a PC and memory Card for programming the display etc. these Things was the reason for me to try the FT800.
Now I know that I have to send the hole list every time I make a change.
The Scissor command looks interesting. Can I write to the "Scissor area" without disturbing the surounding area ? Or is that just a dream ? Very Happy
Have a nice weekend
/JJ
Denmark
10.15 AM
5 deg. C. Cloudy and foggy. No Wind.
PeterM
PostPosted: Wed Feb 25, 2015 1:37 am    Post subject: Reply with quote
jjl
I am no Graphics Expert but looking at various samples to get an understanding, it looks like you can
clip around the area and just draw within the selected coordinates you specify. The Scissor works just like a Scissor I suppose.
I another similar function to look at is StencilOp.
Note:
Just for anyone reading this post, to use the FT800 is straight forward BUT to benefit using
some of the advance Graphics functions an understanding of OpenGL is a must.
The FTDI/FT800 doco is not very descriptive because they assume you have some Graphics
background like OpenGl.
Another great source of samples is in this PDF by the FT800 God - James Bowman
http://excamera.com/files/gd2book_v0.pdf
Also have a look at his mindblowing demos!
http://excamera.com/sphinx/gameduino2/
Peter
