SIEMENS-S65 LPH8836 LCD library
Mrshilov
Bascom LCD Guru
PostPosted: Sat Feb 21, 2015 1:17 pm    Post subject: SIEMENS-S65 LPH8836 LCD library Reply with quote
LPH8836 LCD for SIEMENS-S65 mechanically compatible with LS020:
but has different controller - Hitachi HD66773.
Library is the same as LS020 one:
Landscape & Portrait mode, quick Cls command (default to "white", but may be set to "black").
Library works on 256-colors mode. For 65k colors used external sub (see attachment).
Tested on 2.0.7.1 & 2.0.7.7 versions on Atmega8, Atmega328p, Atmega128, AT90USB1286, Atmega2560.
Video the same as this test on AT90USB1286/8MHz - http://www.youtube.com/watch?v=gOUIt8xGsxQ&feature=youtu.be
PostPosted: Sat Feb 21, 2015 1:48 pm    Post subject: Reply with quote
Thanks for sharing ! Good that you included PIN info.
I re watched the video and it is very quick. Especial when you consider it only runs at 8 Mhz.
