Bascom IDE multiple screen ssupport ?
Pikczu
PostPosted: Mon Feb 02, 2015 9:07 pm    Post subject: Bascom IDE multiple screen ssupport ? Reply with quote
Hi all This is really question to Mark.
Is it possible to get such feature in next version of Bascom AVR IDE or as addon i don't mind pay for it.
After moving to Project type i have now 44 include files and over 4500 line of code I'm using two 24 inch monitors.
Have to look some times in to two or more *inc files at ones. To do it now i run two Bascom IDE at the same time which is not very comfortable.
Also simulator doesn't work if i have that many include files.
Best Regards
Pawel
PostPosted: Mon Feb 02, 2015 11:11 pm    Post subject: Reply with quote
but there is already support for multiple monitors.
In fact i use 2 monitors myself.
I have my setting to 'extend desktop' in windows so the 2 monitors form 1 big screen.
Did you use Window, Tile options of bascom ? Or do i miss a point?
Otherwise send an image with how you think it must look.
I increased number of files in simulator.
Pikczu
PostPosted: Mon Feb 02, 2015 11:32 pm    Post subject: Reply with quote
Hi Mark at first thank you very much for answer.
I have "extend display" set up in windows.
If i select full screen Bascom ide shows only on one monitor.
To stretch it i have to use window mode and manually drag it across two monitors.
Only help work in two monitor full screen mode strait after click.
Best Regards
Pawel
PostPosted: Mon Feb 02, 2015 11:45 pm    Post subject: Reply with quote
so you mean, you want to use all of the extended space when you maximize window? it is not normal behavior i think. all apps i tried , including help, maximize to the current monitor.
let me know if that is what you mean.
Pikczu
PostPosted: Tue Feb 03, 2015 6:48 pm    Post subject: Reply with quote
Hi Mark that exactly what I'm looking for.
When i click maximize i want IDE to maximize across two monitors.
Best Regards
Pawel
PostPosted: Thu Feb 05, 2015 8:52 pm    Post subject: Reply with quote
i looked into this. you can best write to support.
