Mulit Dimensional Array Questions
Goto page 1, 2  Next
TSEYFARTH
PostPosted: Sat Jan 31, 2015 7:41 pm    Post subject: Mulit Dimensional Array Questions Reply with quote
Hello all,
What is the correct syntax to convert this:
 Dim RxBuffer(10,64) As Byte
 Dim Temp_RxBuffer(64) As Byte
        spiin RxTempBuf(1), Dta_len  'Rx_FIFO_Bytes
to this?
       spiin Rxbuffer(idx, 1), Dta_len  'Rx_FIFO_Bytes
In the main .Bas file I do have the multi index array initialized so that is not the problem.
  b_temp1 = RxBuffer(Temp1 ,Temp2)
The latter does not compile. I am trying to avoid having to perform a loop operation to copy the data from RxTempBuf. I realize this may not be possible today, since the multi index arrays are new but if it is and I just have syntax wrong I would appreciate pointers!
Thanks all,
Tim
Visovian
PostPosted: Sun Feb 01, 2015 8:02 am    Post subject: Reply with quote
Dim RxBuffer(10,64) As Byte 'array of 10 arrays(64)
Dim RxtempBuf(64) As Byte
Dim temp_b as byte
Imagine RxBuffer(10,64) as 1O rows, each row is an array(64):
1st_array(64) starts at adr RxBuffer(1,1) ends at RxBuffer(1,64) (1st row)
2nd_array(64) starts at adr RxBuffer(2,1) ends at RxBuffer(2,64) (2nd row)
3rd_array(64) starts at adr RxBuffer(3,1) ends at RxBuffer(3,64)
10th_array(64) starts at adr RxBuffer(10,1) ends at RxBuffer(10,64)
Now you want to place array RxTempBuf(64) into RxBuffer(10,64).
First choose if you want to place it into the 1st_array or the 2nd_array or...
In the example the 1st_array is chosen.
So you copy:
RxBuffer(1,1) = RxTempBuf(1) 'copy RxTempBuf(1) to the 1st row, 1st element of RxBuffer
RxBuffer(1,2) = RxTempBuf(2) 'copy RxTempBuf(2) to the 1st row, 2nd element of RxBuffer
RxBuffer(1,3) = RxTempBuf(3)
RxBuffer(1,64) = RxTempBuf(64)
Use loop:
For i = 1 to 64
RxBuffer(1,i) = RxTempBuf(i)
Note that the first index is always 1, as the whole original array goes to the first row.
Lets read the 15th element from the array:
temp_b = RxBuffer(1,15) 'row 1, element 15
Write 25 to the 30th element
RxBuffer(1,30) = 25
probably should be
 spiin Rxbuffer(1 , idx), Dta_len  'Rx_FIFO_Bytes
Meister
PostPosted: Sun Feb 01, 2015 11:16 am    Post subject: Reply with quote
No way to use memcopy there instead of loop? Is there some change in memcopy in 2.0.7.8?
PostPosted: Sun Feb 01, 2015 12:53 pm    Post subject: Reply with quote
Sure it works Very Happy
Only it won't, if the array dimensioning of the first range in the target array doesn't match the range of the source array.
$Regfile = "m328pdef.dat"
$Crystal = 4000000
$hwstack = 40
$swstack = 16
$framesize = 32
Dim RxBuffer(64 , 10) As Byte
Dim bs As Word
Dim Index_RxBuffer as Byte
Temp_RxBuffer(5) = 69
Index_RxBuffer = 3
bs = MemCopy(Temp_RxBuffer(1) , RxBuffer(1 , Index_RxBuffer) , 64)
Btw., this doesn't work, however it should:
print RxBuffer(1 , 1) , 640
TSEYFARTH
PostPosted: Sun Feb 01, 2015 8:42 pm    Post subject: Reply with quote
Hi eveyone,
The whole idea was NOT to use a tempbuffer. Maybe I muddied the water with the line showing the tempbuffer in what I wanted to change the code to. ie. I should have left out the Temp_RxBuffer(64) part to be clearer.
So to clarify, I want to make this work - which it currently does not.
As for the memcopy, Mark wrote yesterday in http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=12743 that memcopy *should work* but does not. He is going to look into it.
Anyway, the main question is, is there a way to perform the spiin command -
Thanks again for all of the responses!
Tim
PostPosted: Sun Feb 01, 2015 9:44 pm    Post subject: Reply with quote
I've updated only by today, and I can tell it works.
As you can tell too, if you run my code in simulator and watch the memory window.
The reason no code in the linked thread will work, is the wrong order of both indexes:
sets up an array like that:
00 00 00 00 00 00 00 00 00 00
+60 times...
Obviously a straight copy with memcopy() of 64 bytes into several blocks of 10 bytes will fail.
You should be able to use this as workaround:
$Crystal = 4000000
$hwstack = 40
$swstack = 16
$framesize = 32
Dim RxBOvl(640) As Byte At RxBuffer Overlay
Dim tmp_idx As Word
Dim idx as Byte
Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = High , Phase = 1 , Clockrate = 4 , Noss = 1
Spiinit
idx = 2
tmp_idx = idx - 1
tmp_idx = tmp_idx * 64
tmp_idx = tmp_idx + 1
spiin RxBOvl(tmp_idx) , 64                                  'Rx_FIFO_Bytes
TSEYFARTH
PostPosted: Sun Feb 01, 2015 10:27 pm    Post subject: Reply with quote
Hi MWS,
The use of an overlay is interesting - I will try that.
For the multi-index arrays, the release notes said that the simulator will not work correctly with multi index arrays, so be aware of that.
I do not understand what you mean by:
The intent is to have 10 indexes, each 64 bytes wide. The code
spiin Rxbuffer(idx, 1), Dta_len 'Rx_FIFO_Bytes Should be able to receive the number of bytes (Dta_len) into the Index identified by the variable idx.
Anyway, the overlay is interesting and may be something to look at for the near term - of faster than the looping. I bet though, that by the time this all gets settled, Mark will have an update ready that cures these ills Smile
Tim
PostPosted: Mon Feb 02, 2015 12:25 am    Post subject: Reply with quote
I only need to see which bytes at which position are changed, as soon the array is written. This should not have changed, so I assume the memory window is correct. Additional information shown in the window may be incorrect, but I don't need it.
A multidimensional array is represented internally by occupation of a linear and one dimensional array, only with the difference, that either the compiler knows at compile time how to solve fixed indexed addresses, or if indexes are variables, it integrates code to enable the micro controller to calculate the address at runtime.
A RxBuffer(10,64) consists of (see my 00 example) 10 linear connected bytes, then the next 10, a.s.o., till 64.
For the user it looks the same, whether access is to RxBuffer(1,1 to 64) or to RxBuffer(1 to 64, 1), but for the controller it makes a huge difference.
To access RxBuffer(1,1 to 64), the controller accesses byte 1, 11, 21, 31,..., 631.
It is the reason memcopy() fails, as it is not a connected, instead a clustered array.
If in contrary the array is dimensioned RxBuffer(64,10), 64 bytes are linear connected, so
RxBuffer(1 to 64, 1) actually accesses byte 1 to 64 within the said big linear array.
Memcopy() works well on this, and also SPIIN will work, if you only tell the right position within the one dimensional array, my code does this.
The overlay just represents the container, where the multidimensional array is hosted. It allows to drive around such roadworks, where the multidimensional array is not fully integrated yet.
TSEYFARTH
PostPosted: Mon Feb 02, 2015 12:39 am    Post subject: Reply with quote
MWS,
Thanks for the detailed explanation!
That really helps to make sense of this. It appears that, for my purposes, using ary(64,10) makes the most sense.
Thank you VERY much! I am going to try this in between Super Bowl timeouts - er... thats not possible since the commercials are the best during the Super Bowl! Smile
Tim
Visovian
PostPosted: Mon Feb 02, 2015 10:49 am    Post subject: Reply with quote
MWS:
IMO RxBuffer(10,64) contains 10 arrays, each array is 64 bytes.
In the memory it is 64 linear connected bytes, then the next 64, a.s.o., till 10.
My demo Bascom hates multidim arrays so I am attaching an example from Avrstudio.
PostPosted: Mon Feb 02, 2015 11:21 am    Post subject: Reply with quote
I dont have a clue what avr studio has to do with this? i did not check if avr studio use the same order but i do know that one can lay out in different form. that is why it is not a good idea to include info about studio.
In bascom ofset calculation used : (index1-base) + ((index2-base) * elements1 ) + ((index3-base) * elements1*elements2) * dataLength
Thus ar(10,64) index1 is 10 and index2 is 64.
To calculate 1,1, the formula is 9 + 63*10, and that is what MWS explained. While the total memory used is the same, it makes a difference.
Since memcopy has a built in check in order to prevent memory corruption, it will not copy since the compiler finds 10 bytes maximum.
While i changed it, it is much better to dim 64,10 since that will give linear memory.
I will add this to the help since this is very important in practice.
Visovian
PostPosted: Mon Feb 02, 2015 11:34 am    Post subject: Reply with quote
Agreed.
PostPosted: Mon Feb 02, 2015 2:55 pm    Post subject: Reply with quote
Your definition is too unsharp, and further it is wrong in regards of Bascom.
You can address it like 10 * 64 or 64 * 10, and however you do, it will lead you always to the same certain memory cell.
The difference is internal organization, as soon you leave well paved roads, you need to know your example is 10 linear connected bytes and this 64 times.
At least that's the way Mark decided it to be this way in Bascom.
In this matter I do hard to understand, what a C-example debugged with AVR-Studio should tell me in context.
To learn from your snippet, the dimensioning is just the other way around compared to Bascom.
I further do not understand, why you don't compare Bascom's internal structure with a closer relationship, for example Visual Basic, or any another PC based Basic dialect.
Yeah, as said, funny, an example in C-language.
I fully understand, if Bascom did not work, in case you have tried to feed it with C. Smile
Btw., the comparison you drew is like if your dentist is located on the 4th floor in a certain street and you expect to find dentists on 4th floors all over in other streets too. Very Happy
TSEYFARTH
PostPosted: Mon Feb 02, 2015 5:26 pm    Post subject: Reply with quote
Hello all,
The explanation MWS provided was very good and gave me, at least, the clarity needed. I had originally thought that 10,64 was correct, to arrays of 64 bytes, but that as I was shown was backwards. Really makes no difference which is which so long as it is known and works. This is why I changed my code to 64,10 yesterday.
Once this kinks are worked out of this new feature it will be very very nice indeed!
For me, my immediate needs are to use multi index for spiin commands and print commands without any code in between. That would be the cats meow!
Thanks again all - great job Mark, keep it up!
Tim
PostPosted: Mon Feb 02, 2015 11:15 pm    Post subject: Reply with quote
About SPIIN, that does work.
you pass the address of the first element you want to fill. But as the memory is filled in memory at a certain way as explained before, the result will be different as one might expect.
So the simplest way is to change the order of the indexes.
Goto page 1, 2  Next
Page 1 of 2
