lcd designer not work
kos19
PostPosted: Sat Jan 31, 2015 4:45 pm    Post subject: lcd designer not work Reply with quote
Hello all.
After long time I use LCD DESIGNER - Deflcdchar [x] , 32 , 32 , 4 , 4 , 4 , 4 , 4 , 32 ' replace [x] with number (0-7)
After compile and program chip, on display was strange character. I try a few times, but result was always wrong.
All other text on lcd was OK.
Is this bug or something else?
(BASCOM-AVR version : 2.0.7.7 , Latest : 2.0.7.8 )
bzijlstra
Bascom Ambassador
PostPosted: Sat Jan 31, 2015 7:19 pm    Post subject: replace x? Reply with quote
Did you replace the x with the charnumber you will be using?
I did a search on deflcdchar and found a full list of working examples. You must config the right lcd etc.
Have
Ben Zijlstra
snipsnip
PostPosted: Sat Jan 31, 2015 9:37 pm    Post subject: Reply with quote
It is important that a CLS follows the DEFLCDCHAR statement(s).
So make sure you use the DEFLCDCHAR before your CLS statement.
From the help... pretty sure this is the problem.
O-Family
PostPosted: Sun Feb 01, 2015 1:23 am    Post subject: Reply with quote
Does your LCD have the number of the horizontal dots more than 5 dots?
If normal 5 dot type, the value of 32 is funny.
In your statement, display is now below.
   Deflcdchar 0 , 32 , 32 , 4 , 4 , 4 , 4 , 4 , 32
   Locate 1 , 1
   Lcd Chr(0)
snipsnip
PostPosted: Sun Feb 01, 2015 1:47 am    Post subject: Reply with quote
31 = 00011111 ' full row
32 = 00100000 'empty , Don't know why its not just "0"
Confused
dl7sep
PostPosted: Sun Feb 01, 2015 11:27 am    Post subject: Reply with quote
31 =Full = normaly, you have only 5 dots
dot 0 = 1
dot 1 = 2
dot 3 = 4
dot 4 = 8
dot 5 = 16
1+2+4+8+16 =31
32 = Nothing, you have only 5 dots!
Regards
Josef
kos19
PostPosted: Thu Mar 05, 2015 11:59 am    Post subject: Reply with quote
This was first problem.
The second was INITLCD. It should be used before DEFLCDCHAR statement(s).
Thanks for help.
