Joined: 11 Dec 2007 Posts: 112 Location: rio de janeiro
Posted: Sat Jan 31, 2015 2:47 pm Post subject: strange problem with loop for-next
Hello all!
I was trying to run an old program to dump eeprom contents and found a strange result.
I was able to dump only the first line , and after some inspection I noticed that the loop for-next is not working , or I am not seeing the real problem.
Bellow I provide a code fragment and please note that I replaced eeprom instructions for dummy byte only for checking purposes. I can see that thereīs neither bufferout overflow nor Contagem2 loop performing..
When run in simulator you see only the first line printed...
Using last version 2.0.7.8
Dim Strtime As String * 9
Dim Bufferout As String * 120
Dim Contagem1 As Word
Dim Contagem2 As Word
Dim D As Byte
Dim Mes As Byte
'---------- DUMP ------------------------
For Contagem2 = 0 To 32767 Step 16
Bufferout = ""
Strtime = "0000" + Hex(contagem2 )
Strtime = Right(strtime , 4)
Bufferout = Strtime + " "
For D = 0 To 15
Contagem1 = Contagem2 + D
'Readeeprom Mes , Contagem1
Mes = 49
Bufferout = Bufferout + Hex(mes) + " "
Bufferout = Bufferout + "| "
For D = 0 To 15
Mes = 49
If Mes < 32 Then
Mes = 32
Bufferout = Bufferout + Chr(mes)
Print Bufferout
