Atmega1284 and PWM
maxneo
PostPosted: Tue Jan 27, 2015 11:02 am    Post subject: Atmega1284 and PWM Reply with quote
I have a problem with Atmega1284 it would not compile when I use Timer3 to PWM. See the code below.
$regfile = "m1284pdef.dat"
$crystal = 8000000
$hwstack = 32
$swstack = 16
$framesize = 40
Config Clockdiv = 1
line 40 Config Timer3 = Pwm , Pwm = 10 , Compare A Pwm = Clear Down , Compare B Pwm = Clear Down , Compare C Pwm = Clear Down , Prescale = 8
chan1 Alias Pwm3a 'PORTE.3
chan2 Alias Pwm3b 'PORTE.4
chan3 Alias Pwm3c 'PORTE.5
When I compile, I get this message
Error : 12 Line : 40 Unknown CONFIG parameter [PIN] , in File : C:\Program Files (x86)\MCS Electronics\BASCOM-AVR\SAMPLES\TestPWM.bas
What am I doing wrong
Sincerely Janne
i.dobson
PostPosted: Tue Jan 27, 2015 11:23 am    Post subject: Reply with quote
Are you sure that timer 3 has 3 pwm Outputs?
This works:
Config Timer3 = Pwm , Pwm = 10 , Compare A Pwm = Clear Down , Compare B Pwm = Clear Down , Prescale = 8
Regards
Ian Dobson
PostPosted: Tue Jan 27, 2015 11:26 am    Post subject: Reply with quote
all timers have just 2 outputs.
maxneo
PostPosted: Tue Jan 27, 2015 11:44 am    Post subject: Reply with quote
Thanks on much I got for me that there were 3 pc timer in Atmega1284 thank you got me on the right ulcers.
grateful Janne
Tubeampman
PostPosted: Tue Jan 27, 2015 1:35 pm    Post subject: Reply with quote
Hi
This helped me to use timer3.
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=12180&highlight=
Øyvind
