Alex20q90
Posted: Sun Jan 18, 2015 2:25 pm Post subject: XTEA Problems |
Hello,
i use the XTEA from Bascom to encrypt and decrypt. That works.
But if i try to decrypt or encrypt with a PHP or VB.Net (2010) it doesnt work!
Anybody have a worked code for VB that i can use with bascom?
Best regards
Alex
techknight
Posted: Sat Aug 22, 2015 2:35 am Post subject: |
I know this is old, But I ran into a similar problem. The problem is with Big-Endian vs Little-Endian. its different between high-level and low-level systems. There is a library XTEA2 which fixed it, based upon my requests. |
danielle
Posted: Mon Jun 13, 2016 3:24 pm Post subject: Using of XTEA2 |
Hello,
i just want to use the "new" lib "XTEA2.lib" wich comes with the latest version of Bascom (2.0.7.9).
When i use "Xteaencode Msg(1) , Key(1) , 16" the compiler will still use the "old" version "XTEA.lib"
So how can I use or how do i have to call the "XTEA2.lib"?
Thanks in advance, dani
techknight wrote: | I know this is old, But I ran into a similar problem. The problem is with Big-Endian vs Little-Endian. its different between high-level and low-level systems. There is a library XTEA2 which fixed it, based upon my requests. |
danielle
Posted: Mon Jun 13, 2016 4:15 pm Post subject: Re: Using of XTEA2 |
OK, at least i figured it out ...
I simply had to put $lib "xtea2.lib" at the code.
danielle wrote: | Hello,
