Problem after Upgrade to 2.0.7.8
bifi
PostPosted: Thu Jan 15, 2015 12:32 pm    Post subject: Problem after Upgrade to 2.0.7.8 Reply with quote
Hello Forum,
after updating to 2.0.7.8 the following code does no longer compile.
I get an Error: Error : 242 Line : 29 Data type of source and target variables do not match [ 0]
Here is my code:
$regfile      = "m644def.DAT"
$crystal      = 16000000
$baud         = 19200
$hwstack      = 128
$swstack      = 128
$framesize    = 60
Declare Sub 8416_AFD_Rd()
Declare Sub 8416_Rd(ByVal 8416_ADR As Byte, ByVal 8416_MAP As Byte, 8416_DATA As Byte)
Const 8416_W                          = &H20                                    ' CS8416 Adresse write
Const 8416_R                          = &H21                                    ' CS8416 Adresse read
Const 8416_AFD                        = &H0B
Dim   8416_AUDIO_FORMAT_DETECT        As Byte                                   ' &H0B R
      8416_96KHZ                      Alias 8416_AUDIO_FORMAT_DETECT.0
      8416_DGTL_SIL                   Alias 8416_AUDIO_FORMAT_DETECT.1
      8416_DTS_CD                     Alias 8416_AUDIO_FORMAT_DETECT.3
      8416_DTS_LD                     Alias 8416_AUDIO_FORMAT_DETECT.4
      8416_IEC61937                   Alias 8416_AUDIO_FORMAT_DETECT.5
      8416_PCM                        Alias 8416_AUDIO_FORMAT_DETECT.6
do
loop
Sub 8416_AFD_Rd()
    Call 8416_Rd(8416_W, 8416_AFD, 8416_AUDIO_FORMAT_DETECT)
End Sub
    I2cstart
    I2cwbyte 8416_ADR
    I2cwbyte 8416_MAP
    I2cstop
    I2cstart
    I2cwbyte 8416_R
    I2crbyte 8416_DATA, NACK
    I2cstop
End Sub
Any idea ?
Kind regards
Michael
PostPosted: Thu Jan 15, 2015 1:21 pm    Post subject: Reply with quote
this is a bug. when you remove the _ in constants it will compile. it is caused by the more flexible way you can pass constants to sub routines. of course this bugs defeats that purpose. we will publish a fix for this.
bifi
PostPosted: Thu Jan 15, 2015 1:31 pm    Post subject: Reply with quote
Hi Mark,
thank you for your quick Response.
I my program i have a lot of const with an underscore in the name.
But only this one above gives an error.
Best regards
Michael
PostPosted: Thu Jan 15, 2015 1:35 pm    Post subject: Reply with quote
yes but that is because you start with a number. constants, variables, etc. best never start with a number. if you want a number start with c so you get c12345 for example.
drejansen
PostPosted: Fri Jan 16, 2015 1:56 pm    Post subject: the _ problem Reply with quote
thanks!
i am almost become crazy
now i see the solution.
greetings, Dré
Pluk het moment!
een hele dag lukt toch niet.
Groeten, Dré Jansen
Evi
PostPosted: Mon Jan 19, 2015 10:25 am    Post subject: Reply with quote
I installed this version. New IDE launched for a moment and then collapsed.
Old version 1.11.9.0 works fine.
Windows 7x64
PostPosted: Mon Jan 19, 2015 10:31 am    Post subject: Reply with quote
Evi : write to support and do not forget to include your serial.
PostPosted: Tue Jan 20, 2015 12:12 pm    Post subject: Reply with quote
The problem was an illegal old version. so if the IDE just ends without error, simply install a legal license.
