bascom end ardunoisp
marc3
PostPosted: Tue Jan 13, 2015 4:46 pm    Post subject: bascom end ardunoisp Reply with quote
Dear Members,
I am using bascom 2.0.7.5 on windows xp home end a arduino_uno board, no problem.
Now i wanted to use a arduino_isp programmer ( not the uno ) to program the ATtiny's.
afther installing the driver ( libusb device ), i can't make it working, by chosing progammer end parameter settings.
Can someone explain to me what exactly ineed to set.
Thank you
bzijlstra
Bascom Ambassador
PostPosted: Tue Jan 13, 2015 5:37 pm    Post subject: arduino_isp Reply with quote
Googled for this device. http://arduino.cc/en/Main/ArduinoISP
Is this the hardware you are using?
I see some Windows drivers on this page. Did you install that?
In your hardware device list do you see any new device?
Did you do a test from within the Arduino IDE?
Burning a bootloader...
Ben Zijlstra
marc3
PostPosted: Tue Jan 13, 2015 10:32 pm    Post subject: Reply with quote
Yes that's the hardware i use.
the right windows driver is installed.
In my hardware list i see the new device: libusb device arduino isp.
I haded to install the arduino IDE version: 1.5.8 ( 1.5.7 is mininum requerd )
i didn't try to burn a bootloader on the uno (m328Pdef ), but i tryed to load a simple skeths, notting haped.
PostPosted: Tue Jan 13, 2015 11:01 pm    Post subject: Reply with quote
This seems more arduino related than bascom. This forum is for using bascom with arduino hardware.
bzijlstra
Bascom Ambassador
PostPosted: Tue Jan 13, 2015 11:07 pm    Post subject: arduino_isp Reply with quote
In the Arduino-IDE I consider you have chosen the right board and if possible the right programmer. In red you will see all kinds of errors when things go wrong. Do you have any errors? It is in the bottom screen.
Have you tried any usb programmer options in Bascom-AVR?
Ben Zijlstra
