atmega1284p
maxneo
PostPosted: Mon Jan 12, 2015 8:14 pm    Post subject: atmega1284p Reply with quote
I need a booloader for atmega1284p grateful for the help :D
Paulvk
PostPosted: Mon Jan 12, 2015 10:29 pm    Post subject: Reply with quote
Hello maxneo
Have a look in bascom help and samples code for MCS bootloader
Regards Paul
maxneo
PostPosted: Tue Jan 13, 2015 7:02 pm    Post subject: Reply with quote
I do not understand how to find the values of Atmega1284p can someone explain how to do it or is it the same as for ATMEGA128
below Atmega88
#if Downloader Chip = 88 'Mega88
$ loader = $ c00 "this address you can find in the datasheet
'The downloader address is the same as the boot vector address
Const Maxwordbit = 5
Config Com1 = Dummy, Synchron = 0, Parity = None, Stop bits = 1, Data bits = 8, Clockpol = 0
#endif
grateful for answers
maxneo
PostPosted: Tue Jan 13, 2015 10:03 pm    Post subject: Reply with quote
Have tried to make a bootloader to atmega1284 but get error code
Error : 344 Line : 5 Program will overwrite bootloader [ 1640 too long] , in File : C:\PROGRAM FILES (X86)\MCS ELECTRONICS\BASCOM-AVR\LIB\FP_TRIG.LBX
$regfile = "m1284def.dat"
Const Loaderchip = 1284
if Loaderchip = 1284 ' Mega1284P
$loader = &H10000 ' 1024 words
Const Maxwordbit = 7 'Z7 is maximum bit '
#endif
Is there anyone who can help me
Thank you in advance
bzijlstra
Bascom Ambassador
PostPosted: Tue Jan 13, 2015 10:43 pm    Post subject: Reply with quote
There are a few things that can be done. First of all, could you show us the fusebit settings of your atmega1284p. Specially the reset-vector.
Do you have another atmega1284p with bootloader. I know this microcontroller is used on the Sanguinololu board. You could do a full copy and check the reset-vector settings. Reset-vector is pointing to 0000 or to the bootloader start location.
A bootloader will have all 'FF's till it is at the bootloader location, in your case 1024 words. This can be checked if you do a manual programming. You can check the buffer.
Don't worry, I am waiting for my Atmega1284p, and will put an Arduino bootloader in it.
Have fun
Ben Zijlstra
PostPosted: Tue Jan 13, 2015 11:10 pm    Post subject: Reply with quote
it is the same as for m128.
So just add this :
#elseif Loaderchip = 1284
    $loader = &HFC00                                        ' 1024 words
#endif
and define a const for loaderchip=1284
if you get errors you best post you code here (zipped)
maxneo
PostPosted: Wed Jan 14, 2015 8:05 am    Post subject: Many Thanks Reply with quote
Many Thanks
