Subroutines in a seperate file
Climber
PostPosted: Sat May 31, 2014 5:06 pm    Post subject: Subroutines in a seperate file Reply with quote
I have a collection of subroutines that I want to swap to a separate file.
How can I tell my main program where the subroutins are.
I experimented a little with $include "Sub.bas"in the main program but i got a lot of errors.
Example:
Main Program:
$include "SUB.bas"
Declare Sub Wait_taste
'Alias Definition
Center Alias Pinb.4 'Center Taste
Dim Testcount As Byte
Call Wait_taste
End 'end program
Program Sub.bas:
Sub Wait_taste
If Center = 0 Then
Incr Testcount
Lcd Testcount
End Sub
When i compile the main program i get the error : Label not found [Wait_taste ]
I hope someone can tell me how to outsource correctly subroutines
Many greetings
Climber
PostPosted: Sat May 31, 2014 8:40 pm    Post subject: Reply with quote
Hi
the best is to use config submode=new and to include them first.
$regfile="m88def.dat"
$hwstack=32
... etc
config submode=new
$include "SUB.bas"
now just call the subs from here. you do not need declare statements this way, and you do not need goto to jump over code. only the used subs will be included in your code.
Visovian
PostPosted: Sat May 31, 2014 8:52 pm    Post subject: Reply with quote
$include "SUB.bas"
Sub Wait_taste must be declared before it is defined (coded) in 'sub.bas'.
You did it just vice versa.
Try either
Center Alias Pinb.4
Goto Main
$include "sub.bas"
Main:
      Portb = 1
      Wait_taste
End 'end program
Or
Center Alias Pinb.4
      Portb = 1
      Wait_taste
End 'end program
$include "sub.bas"
Climber
PostPosted: Sun Jun 01, 2014 7:59 am    Post subject: Reply with quote
thanks alot for your help.
The following test code with a Butterfly module works
The trick is to insert the $include between the "Goto Main" And the Main or to write the
$include after the main program
To do this not, was the error from me.
No i understand and i'm happy.
$regfile = "m169def.dat"
$crystal = 1000000                                          '1Mhz   Achtung:Fusebit 7 = 0 (Teiler durch 16 = enabled)
$hwstack = 100
$swstack = 80
$framesize = 100
$baud = 4800                                                'Baudrate zum PC: 4800 Baud
 'E/A Belegung Register B
 '        |--------PB7  Tief Taste
 '        ||-------PB6  Hoch Taste
 '        |||------PB5  Piezo Lautsprecher
 '        ||||-----PB4  Center Taste
 '        |||||----PB3  ( Miso )
 '        ||||||---PB2  ( MoSi )
 '        |||||||--PB1  ( SCK
 '        ||||||||-PB0  ("Chip Select" Data Flash Baustein )
 Ddrb = &B0010111                                           '0 = Eingang  1 = Ausgang
Portb = &B11011000                                          '1 = Pullup Widerstand eingeschaltet
'Für das Butterfly Display
$lib "lcd_butterfly.lbx"
Dim _butterfly_digit As Byte
Goto Main
 $include "SUB.bas"
Main:
 Call Wait_taste
End                                                         'end program
Lcd_butterfly_data:
'Data & Fedcba9876543210
Data 0%                                                     ' space  chr(32)
Data &B0010000010000000%                                    ' !
Data &B0000000010010000% ' "
Data &B0000101001010001%                                    ' # -> Grad chr(35)
Data &B0011101111000001%                                    ' $
Data &B1100101101101000%                                    '  %
Data &B1101000110100001%                                    ' &
Data &B0000000010000000%                                    '  '
Data &B0001010001000001%                                    '  (  chr(40)
Data &B0001000100010001%                                    '  )
Data &B1100101000101000%                                    ' *
Data &B0010101010000000%                                    ' +
Data &B0100000000000000%                                    ' ,
Data &B0000101000000000%                                    ' -  chr(45)
Data &B0100000000000000%                                    ' .
Data &B0100000000001000%                                    '/
Data &H5559%                                                ' 0
Data &H0118%                                                ' 1
Data &H1E11%                                                ' 2  chr(50)
Data &H1B11%                                                ' 3
Data &H0B50%                                                ' 4
Data &H1B41%                                                ' 5
Data &H1F41%                                                ' 6
Data &H0111%                                                ' 7   chr(55)
Data &H1F51%                                                ' 8
Data &H1B51%                                                ' 9
Data 0%                                                     ': als Blank
Data 0%                                                     '; als Blank
Data &B1000000000001000%                                    '<   chr(60)
Data &B0001101000000000%                                    '=
Data &B0100000000100000%                                    '>
Data &B0010100001010001%                                    '?
Data &B0101011100010001%                                    '@
Data &H0F51%                                                ' A  naechste Zeilen BCDEFG.. usw. bis Z
Data &H3991% , &H1441% , &H3191% , &H1E41% , &H0E41% , &H1D41% , &H0F50% , &H2080% , &H1510% , &H8648% , &H1440% , &H0578%
Data &H8570% , &H1551% , &H0E51% , &H9551% , &H8E51% , &H1B41% , &H2081% , &H1550% , &H4448% , &HC550% , &HC028% , &H2028% , &H5009%
Data &B1100000010000000%                                    '  chr(91) frei definiert  Beispiel: umgedrehtes Y
Data &B0001101000000001%
Code from SUB.bas
Sub Wait_taste
   If Center = 0 Then
       Incr Testcount
       Cls
       Lcd "TEST"
End Sub
End                                                         'end program
Smile Smile [/list]
mmarlette
PostPosted: Thu Jan 08, 2015 10:24 pm    Post subject: Reply with quote
Mark,
Per your reply above on May 31st. I am using v2.0.7.8
The following code example will not compile. What is wrong. I just don't see it.
Error : 61 Line : 9 Label not found [SETDATE] , in File : C:\PROGRAM FILES\MCS ELECTRONICS\V2078\LIB\DATETIME.LBX
Error : 61 Line : 18 Label not found [SETTIME] , in File : C:\PROGRAM FILES\MCS ELECTRONICS\V2078\LIB\DATETIME.LBX
The SetDate and SetTime references are being derived from the date$ and time$ at lines 64 & 65.
Code Explorer knows where the labels are in DS1307_NewMode.inc
I have also tried removing the Sub DS1307_SetTime() to Sub SetTime() still errors.
Here are the two code pieces.
Main.bas
$regfile = "m2560def.dat"      ' specify the used micro
 $crystal = 16000000            ' used crystal frequency
 $baud = 115200                 ' use baud rate
 $hwstack = 200
 $swstack = 250
 $framesize = 1000
 $programmer=23                 ' Define programmer as ARDUINO V2 (using stk500v2 protocol)
 '$prog $fc,$c6,$df,$ff         ' Lock Bits, Fuse Bits Low, Fuse Bits High, Fuse Bits Extended
 Config SubMode = new
 $include "DS1307_newmode.inc"
 $lib "i2c_twi.lbx"                       ' using hardware I2C/TWI
 Const False = 0
 Const True = 1
 'address of ds1307
 Const Ds1307w = &HD0                     ' Addresses of Ds1307 clock
 Const Ds1307r = &HD1
 'dim other needed variables
 Dim Weekday As Byte
 Dim lngTick as long                     ' one second tick timer counter
 Dim booRTCupdate as boolean             ' Flag to allow event to occur
 Dim strTime As String * 8
 Config Date = mdy , Separator = /        ' configure the date format
 config clock = user                      ' define USER clock, it dims date / time vars
                                          ' The USER must have the calls of settime, setdate, getdatetime
                                          ' to talk to the USER's hardware
 Config Sda = Portd.1                     ' define pin names, scl and sda pins
 Config Scl = Portd.0
 Config Twi = 400000                      ' CONFIG TWI will ENABLE the TWI master interface, 100KHZ or 400KHZ
 i2cinit                                  ' initialize the I2C bus
 '-----[ Output Timer ISR  for Oscilloscope Check on Porta.0 ]-----------------
 Config Porta.0 = Output                  '
 Porta.0 = 1                              ' LED off, active lo.
 TickBit Alias Porta.0
 '-----[ Setup Timer1 for Tick ISR off system XTAL]----------------------------
 ' Timer1 is used for Tick counter at 1Hz
 Config Timer1 = Timer , Prescale = 1024 , Compare A = Disconnect , Clear Timer = 1
 ' crytal   / prescale / x Hz    = Compare1a val needed
 ' 16000000 / 1024     / 1(Hz) = 15625
 Compare1a = 15625
 On Compare1a T1_TickCounter_ISR          ' Define ISR Entry Point
 Enable Timer1
 Enable Compare1a
 '-----[Serial Port(s)]--------------------------------------------------------
 Config Com1 = 115200, Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
 Open "com1:" For Binary As #1
 Waitms 5
 Enable Interrupts                       ' Using a timer to generate 1 second ISR interval
 Print #1, "DS1307"
 ' Clear Vars
 lngTick = 0
 booRTCupdate = false
 date$ = "12/02/14"
 time$ = "20:03:00"
 Do                                 ' Main Loop
    if booRTCupdate = true then
       call GetDateTime()           ' read from RTC
       strTime = Time(_sec)         ' use system vars to create time string
       'strDate = Date(_day)         ' use system vars to create date string
       Print #1, "Date : "; _Month;"/";_day;"/20";_year; "  Time : "; strTime
    end if
'------[ Timer ISR routine ]----------------------------------------------------
T1_TickCounter_ISR:
    Incr lngTick                            ' inc event counter
    Toggle TickBit                          ' allow visual on scope
    booRTCupdate = true                     ' every tick, allow DS1307 RTC to read date/time
DS1307_NewMode.inc
sub DS1307_SetDate()
SetDate:                                     ' need to create a label for BASCOM funtions to hook in to
  _day = Makebcd(_day) : _month = Makebcd(_month) : _year = Makebcd(_year)
  I2cstart                                                  ' Generate start code
  I2cwbyte Ds1307w                                          ' send address
  I2cwbyte 4                                                ' starting address in 1307
  I2cwbyte _day                                             ' Send Data to SECONDS
  I2cwbyte _month                                           ' MINUTES
  I2cwbyte _year                                            ' Hours
  I2cstop
  Print #1, "SetDate completed"
'  return
end sub
sub DS1307_SetTime()
SetTime:                                     ' need to create a label for BASCOM funtions to hook in to
  _sec = Makebcd(_sec) : _min = Makebcd(_min) : _hour = Makebcd(_hour)
  I2cwbyte 0                                                ' starting address in 1307
  I2cwbyte _sec                                             ' Send Data to SECONDS
  I2cwbyte _min                                             ' MINUTES
  I2cwbyte _hour                                            ' Hours
  I2cstop
  Print #1, "SetTime completed"
end sub
sub GetDateTime()
  'set PORTA.0
  I2cwbyte 0                                                ' start address in 1307
  I2cwbyte Ds1307r                                          ' send address
  I2crbyte _sec , Ack
  I2crbyte _min , Ack                                       ' MINUTES
  I2crbyte _hour , Ack                                      ' Hours
  I2crbyte Weekday , Ack                                    ' Day of Week
  I2crbyte _day , Ack                                       ' Day of Month
  I2crbyte _month , Ack                                     ' Month of Year
  I2crbyte _year , Nack                                     ' Year
  I2cstop
  _sec = Makedec(_sec) : _min = Makedec(_min) : _hour = Makedec(_hour)
  _day = Makedec(_day) : _month = Makedec(_month) : _year = Makedec(_year)
  'reset PORTA.0
end sub
Please advise. TIA.
Regards,
PostPosted: Fri Jan 09, 2015 2:47 pm    Post subject: Reply with quote
This will compile
 $hwstack = 200
 $swstack = 250
 $framesize = 1000
 $programmer = 23                                           ' Define programmer as ARDUINO V2 (using stk500v2 protocol)
 Config Submode = New
  Config Clock = User                                       ' define USER clock, it dims date / time vars
  Config Date = Mdy , Separator = /                         ' configure the date format
 Const False = 0
 Const True = 1
 Config Com1 = 115200 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
 'address of ds1307
 Dim Weekday As Byte
 Dim Lngtick As Long                                        ' one second tick timer counter
 Dim Boortcupdate As Boolean                                ' Flag to allow event to occur
 Dim Strtime As String * 8
 I2cinit                                                    ' initialize the I2C bus
 Tickbit Alias Porta.0
 Compare1a = 15625
 On Compare1a T1_tickcounter_isr                            ' Define ISR Entry Point
 Enable Timer1
 Enable Compare1a
 Waitms 5
 Print #1 , "DS1307"
 ' Clear Vars
 Lngtick = 0
 Boortcupdate = False
 Date$ = "12/02/14"
 Time$ = "20:03:00"
 Do                                                         ' Main Loop
    If Boortcupdate = True Then
       Call Getdatetime()                                   ' read from RTC
       Strtime = Time(_sec)                                 ' use system vars to create time string
       Print #1 , "Date : " ; _month ; "/" ; _day ; "/20" ; _year ; "  Time : " ; Strtime
T1_tickcounter_isr:
    Incr Lngtick                                            ' inc event counter
    Toggle Tickbit                                          ' allow visual on scope
    Boortcupdate = True                                     ' every tick, allow DS1307 RTC to read date/time
$nocompile
Setdate:                                                    ' need to create a label for BASCOM funtions to hook in to
  I2cstop
  Print #1 , "SetDate completed"
Settime:                                                    ' need to create a label for BASCOM funtions to hook in to
  I2cstop
  Print #1 , "SetTime completed"
Sub Getdatetime()
  'set PORTA.0
  I2crbyte _sec , Ack
  I2cstop
  'reset PORTA.0
End Sub
Some order must be saved. You , for example, cannot use Print #1 before You declare/describe Print #1 and first User Clock must be declared for create variables used in subs. ( I think ) Very Happy But now everything should work.
..and @Climber - You can move Lcd_butterfly_data: to separate file too but then include them under END statement because DATA must be placed there.
mmarlette
PostPosted: Wed Jan 14, 2015 12:04 am    Post subject: Reply with quote
EDC,
Thank you for the code and explanation. All makes sense on the order of the code, rearranged.
Sometimes one looks at stuff to long and forgets basic fundamentals.
Thanks again!!!!
