16x32 RGB LED matrix panel
Goto page Previous  1, 2
Paulvk
PostPosted: Thu May 24, 2018 11:41 am    Post subject: Reply with quote
As using a full byte consumes a lot of ram
I decided to try to write some asm to send one byte to a 74hc595
but its almost working just need some help to get there
UPDATE
OK got it working now how to send a byte variable from bascom to it
Regards Paul
$asm
     PUSH R16
     push R17
     push R18
     PUSH R19
      '  Send 8-bit data to 74HC595 Shift Register
      ldi R16,0b1010_0100         ;test data now how to put data in from byte variable in bascom
    Send_byte:
        ldi        R19,0b1000_0000        ; Set Bit counter
    Next_bit:
        mov        R17,R16       ; Move data byte to temp
        and        R17,R19                ; Check bit
        breq        zero                ; Set Data to 0
        sbi       Panel_r1_p,  Panel_r1_b        ; Set Data to 1
        rjmp        shift                ; shift bits
   Zero:
        cbi       Panel_r1_p,  Panel_r1_b
   Shift:
        sbi        Panel_clk_p, Panel_clk_b        ; CLK up
        nop
        cbi        Panel_clk_p, Panel_clk_b        ; CLK down
        clc                        ; Clear Carry flag
        ror        R19                ; Shift bit counter
        brne        next_bit        ; Next iteration
        sbi        Panel_lat_p, Panel_lat_b        ; When done, Latch
        nop
        cbi        Panel_lat_p, Panel_lat_b
   POP R16
   POP R17
   POP R18
   POP R19
   $end Asm
Paulvk
PostPosted: Thu May 24, 2018 1:15 pm    Post subject: Reply with quote
Now it is working next to get it into O-Family's code
Regards Paul
$asm
     PUSH R16
     push R17
     push R18
     PUSH R19
     push XL
     PUSH XH
        Loadadr Transfer_bits , X
        ld R16,X+
    Send_byte:
    Next_bit:
   Zero:
   Shift:
        nop
        nop
   POP R16
   POP R17
   POP R18
   POP R19
   POP XL
   POP XH
   $end Asm
PostPosted: Fri May 25, 2018 1:11 am    Post subject: Reply with quote
I don even try to realize/resolve this.. but Im thinking that POP`ing should be some kind of reversed way Very Happy
My thinking was that RETI takes last saved PK
O-Family
PostPosted: Sat May 26, 2018 1:08 am    Post subject: Reply with quote
To calculate the position (address) of the LED buffer, a multiplication (MUL) instruction is required.
Therefore, a program for reusing the registers R0, R1 is suitable.
And I think that the 74HC595 is 8 serial connections, so we need to send 8 bytes with one interrupt.
sangwoo
PostPosted: Mon Jul 09, 2018 3:36 pm    Post subject: Hello O-Family Reply with quote
Hello O-Family
Thank you for answer.
on drawing subroutine
Add LEDY 3, LEDY 4
Do I have to add up two lines each?
It\'s a lot more complicated than I thought.
O-Family
PostPosted: Sat Jul 14, 2018 4:14 am    Post subject: Reply with quote
Yes.
My routine supports RGB color, so the correction will be more.
In the first place, with single color and RGB full color you need to change the structure of the display memory greatly.
I will support your efforts.
sangwoo
PostPosted: Mon Jul 16, 2018 4:26 pm    Post subject: Reply with quote
Thank O-Family
I did it
One line below has been added.
If Ledy = 2 Or Ledy = 4 Then Ledtempw1 = Ledtempw1 + 256
O-Family
PostPosted: Fri Jul 20, 2018 2:05 pm    Post subject: Reply with quote
Hi, sangwoo
It was nice to finish!
The fact that the number of dots is large is because many information can be displayed, so I think that an interesting device will be completed!
mansur
PostPosted: Tue Aug 21, 2018 2:37 am    Post subject: Reply with quote
Hi O-Family,
thanks for sharing,
but i dont understand and difficult to asm understanding.
can you provide the full bascom language even need more RAM.
Thanks.
Mansur. H
Automation & Instrument Engineer
O-Family
PostPosted: Thu Aug 23, 2018 11:55 am    Post subject: Reply with quote
Hi, mansur
I do not understand the meaning of the question.
What help do you need?
mansur
PostPosted: Tue Aug 28, 2018 4:37 am    Post subject: Reply with quote
[quote=\"O-Family\"]Hi, mansur
What help do you need?[/quote]
I mean, can you provide the full bascom source?
because i\'m not understand about your program in assembler:
$notransform On                                             \'Do not automatically correct instructions that use R23 or R0.
$asm
Tint2a:
   PUSH R2
   IN R2,SREG                                               \'Saved status register.
   PUSH R0
   PUSH R1
   PUSH XL
   PUSH XH
   LDS XL,{rowadr}                                          \'Read the row address of the LED buffer.
   LDI XH, Ledbuff_Length                                   \'Number of horizontal axis bytes of LED buffer. (32 horizontal dots * number of panels + scroll buffer)
   MUL XH,XL                                                \'Calculate the position of the LED buffer.
   Loadadr Ledbuff(1) , X                                   \'RGB LED panel The start address of the data buffer.
   ADD XL,R0                                                \'Add the row address to the LED buffer.
   ADC XH,R1
   LDS R0,{Transfer_Length}                                 \'The number of bytes to transfer to the LED buffer.
Tint2a1:
   LD R1,X+                                                 \'Read lit data from the LED buffer.
   Out Panel_rgb , R1                                       \'Set RGB data.
   SBI Panel_clk_p, Panel_clk_b                             \'Set the RGB LED panel [CLK] to [H].
   CBI Panel_clk_p, Panel_clk_b                             \'Set the RGB LED panel [CLK] to [L].
   DEC R0
   BRNE Tint2a1                                             \'If Transfer end for the number of horizontal axis bytes? Else
   LDS XL,{rowadr}                                          \'Read row address.
   SBI Panel_oe_p, Panel_oe_b                               \'Set the RGB LED panel [OE] to [H]. (Turn off all LEDs)
   SBI Panel_lat_p, Panel_lat_b                             \'Set the RGB LED panel [LAT] to [H].
   CBI Panel_lat_p, Panel_lat_b                             \'Set the RGB LED panel [LAT] to [L].
   CBI Panel_a_p, Panel_a_b                                 \'Set the row address to the port.
   CBI Panel_b_p, Panel_b_b
   CBI Panel_c_p, Panel_c_b
   SBRC XL,0
   SBI Panel_a_p, Panel_a_b
   SBRC XL,1
   SBI Panel_b_p, Panel_b_b
   SBRC XL,2
   SBI Panel_c_p, Panel_c_b
   INC XL                                                   \'Increase row address.
   ANDI XL,$07
   STS {rowadr},XL                                          \'Save the row address.
   POP XH
   POP XL
   POP R1
   POP R0
   Out Sreg , R2                                            \'Return status register.
   POP R2
   CBI Panel_oe_p, Panel_oe_b                               \'Set the RGB LED panel [OE] to [L].
   RETI
$end Asm
   \'  * Timer2 Compare Match B interrupt *
$asm
Tint2b:
   PUSH R24
   LDI R24,$FF
   STS {Ledintf},R24                                        \'Set the LED display interrupt generation flag.
   POP R24
   RETI
$end Asm
$notransform Off
Thanks for your attention.
Mansur. H
Page 2 of 2
