Append line of text to file.
Post new topic   Reply to topic    www.mcselec.com Forum Index -> KokkeKat FAT-free SD card lib
PostPosted: Thu Dec 25, 2014 3:27 am    Post subject: Append line of text to file. Reply with quote
I built a single-chip decoder Sel Call (using ICP). Added to the RTC and display. Now I would like to write to the card detected events
...and after fiew tests..
Everything work super! Very Happy
amirf
PostPosted: Tue Dec 30, 2014 1:31 pm    Post subject: Reply with quote
Please share it EDC , tq
PostPosted: Tue Dec 30, 2014 2:32 pm    Post subject: Reply with quote
In the new year I decided to improve not only the skills, but also foreign languages Very Happy I will try.
To write something on the card you have in the beginning to recognize card type and recognize the file type. To do this, run one after the other two sub-programs. "Sdinit" and "Sdinitfs". If at the end of the variable "Sdstatus = 0" means that we can write bytes one after another. Therefore, a temporary variable that rewrite the text you want to save the buffer Overlay I created.
I'm not a specialist and the first time I write something on the card with the use of the library. Surely you can do better.
$regfile = "m32def.dat"
$crystal = 16000000
$hwstack = 128
$swstack = 64
$framesize = 64
$include "KokkeKat_FAT-free_SD_lib_decl.bas"
' my settings in this config file
'Const Sdinitdetail = 1
'Const Sdfsactive = 1
'Const Sdusefind = 1
'Const Sdusefindstoreentry = 0
'Const Sdusedirlist = 0
'Const Sddirlistarraysize = 12
'Const Sdrmode = 1
'Const Sdwmode = 2
'Const Sduseappend = 1
'Const Sdcleartail = 0
'Const Sdusefsinfo = 1
'Const Sduselfn = 0
'Const Sduselfncompare = 0
'Const Sdusewipe = 0
'Const Sdusedirlistdelete = 0
'Const Sdusesizeinfo = 0
'Const Sdusecrc7 = 0
Dim Temp_string As String * 20
Dim Temp_bufor(20) As Byte At Temp_string Overlay
Dim Send As Byte , Send_len As Byte , Datas As Byte
Dim Something_must_be_saved As Byte                         'for this example
'init card
Lcd "Init SD"
 Gosub Sdinit
If Sdstatus = 0 Then
   Gosub Sdinitfs
Home
 Wait 1
 Lcd "Okay!  "
Else
 Lcd "No Card"
'### DOUBLE SPEED of SPI      It is in the declarations but I preferred it to have a test on top
Spsr.0 = 1                                                  ' Double speed (results in f osc / 2)
Spcr.1 = 0                                                  ' f osc / 4
Spcr.0 = 0
Wait 1
Lowerline : Lcd "Waiting..."
'*********************** START ***********************
'main loop
  If Something_must_be_saved = 1 Then Gosub Save_to_sd
'************************ END ************************
$include "KokkeKat_FAT-free_SD_lib_code.bas"
'zapis na karte
Save_to_sd:
 Gosub Sdreadfsinfo
Sdentrynames = "LOGGED     "                                'name of file on card (11 characters)
Sdstartdirclusterd = 0
'     I have RTC
'Sdyear = Year
'Sdmonth = Month
'Sdday = Day
'Sdhours = Hour
'Sdminutes = Minute
'Sdseconds = Second
Gosub Sdpreparetoappend                                     'find file and last record
Sdclosefile = 0                                             ' Always make sure that Sdclosefile = 0 before writing
Sdbyterw = 32                                               ' Write "Space"
Gosub Sdwritebyte                                           'this saves one single byte to card
For Datas = 1 To 3
       'written in a single line will be three consecutive text variables
   Select Case Datas
    Case 1 : Temp_string = Time_string
     Send_len = 20
    Case 2 : Temp_string = Rezultat_string
     Send_len = 20
    Case 3 : Temp_string = Temp_str
     Send_len = Len(temp_str)                               'variables such as different lengths (example)
   End Select
 For Send = 1 To Send_len   'variables such as different lengths (example)
   If Sdclosefile = 0 Then
      Sdbyterw = Temp_bufor(send)
   Else
   'Handle partition full
   Else
      ' Handle partition full
    'from this point enter and mark the end of the line
      Sdbyterw = 13                                         ' Write "Enter"
      Gosub Sdwritebyte
   Else
      Sdbyterw = 10                                         ' Write "LF"   next line
      Gosub Sdwritebyte
   Else
Gosub Sdfinalizeafterwriting                                ' After writing the last byte, close the file
Gosub Sdwritefsinfo                                         ' Save the updated fsinfo variables back
On the need to create the file. For example LOGGED.txt. Then rename it so that it does not have an extension. "LOGGED" (11 characters - insert spaces). If you want to use the "normal" name is required unless additional 254B
...and this example of the output and write on the card. You can see three separate variables in one line
Nie 28-12-2014 23:45 401040140234201 Fiat
Nie 28-12-2014 23:46 401040140340240 Ford
Nie 28-12-2014 23:46 403040340340341 Opel
Pon 29-12-2014 00:03 401040140234201 Fiat
Pon 29-12-2014 00:05 401040140340240 Ford
Pon 29-12-2014 00:05 403040340340341 Opel
With PCF8583 + 100year calendar + SelCall Decoder + Kokkekat + LCD program takes ~16KB
Have fun and nice day Very Happy
KokkeKat
PostPosted: Fri Jan 02, 2015 10:09 pm    Post subject: Reply with quote
Great work and thanks for sharing!
Smile
Niclas
Post new topic   Reply to topic    www.mcselec.com Forum Index -> KokkeKat FAT-free SD card lib All times are GMT + 1 Hour
