SSD1306 Oled I2c 0.96 inch
Goto page Previous  1, 2, 3, 4  Next
luizabbadia
PostPosted: Sun Dec 27, 2015 1:50 am    Post subject: Reply with quote
sorry wrong post,wrong duplication,wrong question
View user's profile MSN Messenger
i.dobson
PostPosted: Sun Dec 27, 2015 8:46 am    Post subject: Reply with quote
Hi luizabbadia,
I think this is the code (I had a harddisk Crash a while ago and lost afew files)
Regards
Ian Dobson
luizabbadia
PostPosted: Sun Dec 27, 2015 11:34 am    Post subject: Reply with quote
Many thanks for your attention and quick reply ,Ian!
luizabbadia
PostPosted: Sun Dec 27, 2015 11:46 am    Post subject: Reply with quote
Yes!! It works...thanks!!
That helped me to debug and find one problem!
A bad contact in the protoboard....
Now Mark´s program works too!!!!
Thanks a lot!!
luizabbadia
PostPosted: Sun Dec 27, 2015 11:51 am    Post subject: Reply with quote
Ok[/img]
i.dobson
PostPosted: Sun Dec 27, 2015 12:29 pm    Post subject: Reply with quote
Glad to be of Service.
Ian
Mrshilov
Bascom LCD Guru
PostPosted: Sat Feb 06, 2016 7:16 pm    Post subject: Reply with quote
glcdSSD1306.lib not work on Xmega. CPU hangs. In this example even LED flash not work.
$regfile = "xm256a3budef.dat"
$crystal = 32000000
$hwstack = 100
$swstack = 100
$framesize = 100
Config Osc = Disabled , 32mhzosc = Enabled
Dim Count As Byte
Led Alias Portd.2 : Config Portd.2 = Output
Dim Twi_start As Byte
Config Twic = 400000
I2cinit
$lib "glcdSSD1306.lib"
'************************** Here LED flashes
For Count = 1 To 8
   Toggle Led
   Waitms 300
Next Count
'************************** After this string CPU hangs
Config Graphlcd = Custom , Cols = 128 , Rows = 64 , Lcdname = "SSD1306"
'************************** Here LED not flashes
   Toggle Led
   Waitms 100
PostPosted: Sun Feb 07, 2016 12:25 am    Post subject: Reply with quote
My little investigation take me into Xmega.lib
Address for register of I2C channel is keeped in Z so R30 and R31 cannot be altered.
But LPM for reading from flash uses R30 and R31 so in first when InitLCD read data from flash with LPM then Z is blurred and address for I2C reg is broken
I test this because when I write in lib like this
ldi r17,&H78
 Call _i2c_write
 ldi r17,&HAE
 Call _i2c_write
 ldi r17,&HD5
 Call _i2c_write
 ldi r17,&H80...
..etc (data for init)
then I have progress..
I can even CLS when I change Loop in lib for 1024 bytes sending $00 builded on R30|R31 to R28|R29
But now for LCDDAT again LPM is used and so on Very Happy
I`m not that good so my experiments can take time but I find this like very interesting learning Very Happy
PostPosted: Wed Feb 10, 2016 10:22 pm    Post subject: Reply with quote
you found out correct. the twi in xmega uses Z. so Z must be saved.
I sent you a driver in support.
pier_pe
PostPosted: Fri Aug 26, 2016 11:17 am    Post subject: Reply with quote
Hello.
I wanted to make your own font style Display 7-segment for SSD1306.
I have drawn all the numbers in the format bmp.
I do not know how to convert bmp format to ASCII table.
Please advice.
bzijlstra
Bascom Ambassador
PostPosted: Fri Aug 26, 2016 3:01 pm    Post subject: Font editor Reply with quote
Check in Bascom-AVR tools / font editor
and also a nice tool
http://bart-projects.cba.pl/font.html
Have fun
Ben Zijlstra
pier_pe
PostPosted: Fri Aug 26, 2016 5:40 pm    Post subject: Reply with quote
Yeah.
I forgot about the Font Editor.
Now I have a beautiful style digit seven segment display.
Thanks a lot.
PostPosted: Sun Aug 28, 2016 5:20 pm    Post subject: Reply with quote
Hello all,
holidays off ? OK Wink
I'm just playing with the small oled display
Because I'm lazy, I use the : Config Graphlcd = Custom , Cols = 128 , Rows = 64 , Lcdname = "SSD1306"
nice tool it works fine
many thanks Ben, Ian and Mark !
but impossible to use pset, line or circle
do you have an idea to set/reset one pixel? I will do the sub after
Thanks for your help
JP Wink
My test here :
$regfile = "M328pdef.dat"
$crystal = 16000000
$hwstack = 128
$swstack = 64
$framesize = 128
'$baud = 57600
'----include and lib------------------------------------------------------------------
$include "font8x8.font"
$lib "i2c_twi.lbx" ' we do not use software emulated I2C but the TWI
$lib "glcdSSD1306-I2C.lib" ' override the default lib with this special one
'---- config-------------------------------------------------------------------------
Config Clockdiv = 1
Config Submode = New ' new method for sub
Config Sda = Portc.4
Config Scl = Portc.5
Config I2cdelay = 5 ' the Ds3232 is working only to 100kHz but it's work to 200kHz
Config Twi = 400000
'----- variables----------------------------------------------------------------------
Dim jbyte as byte, kbyte as Byte
dim jtext as string*3
dim Xbyte as Byte, ybyte as byte
Setfont Font8x8 ' select font
I2cinit
Lcdat 1 , 1 , "BASCOM-AVR"
Lcdat 2 , 10 , "1995-2015"
wait 2
cls
kbyte=1
for Jbyte= 65 to 75
jtext=chr(jbyte)
Lcdat 4, kbyte , jtext;
'waitms 100
kbyte=kbyte+10
next
kbyte=1
for Jbyte= 128 to 138
jtext=chr(jbyte)
Lcdat 5,kbyte , jtext;
kbyte=kbyte+8
next
kbyte=1
for Jbyte= 139 to 149
jtext=chr(jbyte)
Lcdat 6,kbyte , jtext;
kbyte=kbyte+8
next
Lcdat 8 , 5 , "MCS Electronics" , 1
Wait 2
end
pier_pe
PostPosted: Sun Aug 28, 2016 8:17 pm    Post subject: Reply with quote
Hello.
To do what you want to have to read data from the display. In I2C mode, this is impossible.
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=13125&highlight=ssd1306
This link is the solution.
Mrshilov
Bascom LCD Guru
PostPosted: Sun Aug 28, 2016 9:10 pm    Post subject: Reply with quote
This lib lets do it (uses 1kbytes video buffer in SRAM).
Page 3 of 4
