problem xmega dma
rezaqwer
PostPosted: Tue Nov 25, 2014 12:08 pm    Post subject: problem xmega dma Reply with quote
my version of bascom : 2.0.7.7
hi
i has problem in xmega dma
data from usart -- to -- dacb0
flag of dma(usartd1) is correctly,but no output in dacb0
please help me
$regfile=  "xm128a4udef.dat".
$crystal= 14745600
$hwstack = 512
$swstack = 512
$framesize = 512
$lib "xmega.lib"
$external _xmegafix_clear
$external _xmegafix_rol_r1014
Config Osc = Enabled , Pllosc = enabled , Extosc = Enabled , Range = 12mhz_16mhz , Startup = Xtal_16kclk ,PLLSOURCE=EXTCLOCK , pllmul=1
config DACb = enabled ,Io0 = Enabled ,Io1 = disabled ,INTERNAL_OUTPUT=disabled ,  Channel  =single , Reference = AVCC  , Interval  = 1  , Refresh  = 16
Config Com4 = 4800 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
Open "COM4:" For Binary As #4
Loop Until Osc_status.3 = 1
Set Osc_ctrl.4
Config Sysclock = pll , Prescalea = 1 , Prescalebc = 1_1
Config Priority = Static , Vector = Application , Lo = Enabled       'Interrupts
On Dma_ch3 Dma_ch3_int
config DMA=enabled , DOUBLEBUF = disabled ,Cpm = Ch0123
config dmach3=enabled , burstlen = 8 ,  CHANRPT=enabled , tci = lo , eil = off , Singleshot = enabled, Sar = Burst , _
 Sam = FIXED , Dar = Transaction , Dam = Fixed , trigger = &h6e , btc = 64 , repeat = 0 , sadr=Varptr(usartd1_data) , dadr =Varptr(dacb_ch0data)
enable interrupts
do
loop
Dma_ch3_int:
If Dma_intflags.3 = 1 Then
   Set Dma_intflags.3
    set porte.0
    waitus 100
    reset porte.0
return
Meister
PostPosted: Tue Nov 25, 2014 4:20 pm    Post subject: Reply with quote
A year or two ago there were problems with Xmega dat files preventing to use DACB.
Check the dat file if it looks similar for DACA and DACB.
Regards, Meister
