new source file
sasha_1973
PostPosted: Tue Nov 25, 2014 7:02 am    Post subject: new source file Reply with quote
Health to all!
Please tell me how to implement the creation of a new source file, at each compilation?
Meister
PostPosted: Tue Nov 25, 2014 9:23 am    Post subject: Reply with quote
I am using "Autover" that immediately creates a time-tagged copy of files that have been saved or changed.
So one can easily go back to an earlier version.
http://bean.freeforums.org/autover-2-2-1-t173.html
The program is free (but unfortunately the author appears to have disappeared for a year or so).
Anyway, the program works well (Win7 64bit in my case). There are a lot of configuration options.
I run it as a service. Occasionally it partially crashes but still works -just ignore the error message.
Without using this program I would have been lost - it saved me incredible amount of work.
For instance, if you have ruined your code at some point and you don't remember because of many changes
what had happened you go back the hex files in history and test it. Once you have arrived at a previously working
version you compare the corresponding .bas file with the current one (using Winmerge) and you see the difference.
Regards, Meister
sasha_1973
PostPosted: Tue Nov 25, 2014 9:32 am    Post subject: Reply with quote
Many thanks!
Just super, just what you need!
PostPosted: Tue Nov 25, 2014 9:46 am    Post subject: Reply with quote
In bascom : options, IDe, history backup.
This will create a unique file with date time stamp each time you save or compile a file.
sasha_1973
PostPosted: Tue Nov 25, 2014 12:30 pm    Post subject: Reply with quote
Perhaps I misunderstood, but on your recommendation, saved only 1 bachkup that is constantly overwritten. I need to keep the same every compilation.
Meister
PostPosted: Tue Nov 25, 2014 4:16 pm    Post subject: Reply with quote
saved only 1 bachkup (nice typo) that is constantly overwritten
That also was my experience.
Anyway, the invaluable additional advantage of Autover is that -as mentioned above- you also can save all of the the hex-file Versions, making it very easy to identify the latest working Version just by flashing one after the other.
Regards, Meister
sasha_1973
PostPosted: Tue Nov 25, 2014 5:25 pm    Post subject: Reply with quote
Regards, Meister
You are absolutely right!
Thank you!
PostPosted: Wed Nov 26, 2014 1:14 pm    Post subject: Reply with quote
Did you checked the 'history backup' ? That option will create a hist folder in the project folder. In this folder, it will create a file named FILE~20141125 215504.hst each time you save/compile.
So the file get an additional extension with the data and time and hst extension.
AndersL
PostPosted: Wed Nov 26, 2014 4:17 pm    Post subject: Reply with quote
Hi Mark,
I suppose the ”History backup” option is for the next version? Can’t find it in 2.7.7.004.
Anders
Dibor
PostPosted: Wed Nov 26, 2014 7:21 pm    Post subject: Reply with quote
Hi Mark.
I'm also find only "Auto Backup" option under Option -> Enviroment -> IDE.
Sad Question
View user's profile MSN Messenger
PostPosted: Thu Nov 27, 2014 3:32 pm    Post subject: Reply with quote
sorry, this option was not published yet.
