"IF-THEN" problem
Mrshilov
Bascom LCD Guru
PostPosted: Mon Nov 24, 2014 7:24 pm    Post subject: "IF-THEN" problem Reply with quote
This string is works wrong:
If A <> B Or C = 1 Then
If A>0 and B>0 all works correctly, but if A=0 and B=0, the part "C=1" is ignoring.
PostPosted: Mon Nov 24, 2014 10:03 pm    Post subject: Reply with quote
It's testing well, you're wrong.
Mrshilov
Bascom LCD Guru
PostPosted: Tue Nov 25, 2014 12:34 am    Post subject: Reply with quote
On chip with RAM <64k it works well, but I use AT90USB1286.
PostPosted: Tue Nov 25, 2014 12:57 am    Post subject: Reply with quote
Ah, informations slowly dripping in...
When does it show these behavior, as flash is empty, or filled above 64k?
Mrshilov
Bascom LCD Guru
PostPosted: Tue Nov 25, 2014 3:53 am    Post subject: Reply with quote
Yes, above 64k.
PostPosted: Tue Nov 25, 2014 9:44 am    Post subject: Reply with quote
I do not see what it could have to do with 64K (rampz). But if it is reproducible, i suggest to send the code to support (zipped) so we can have a look at it.
PostPosted: Tue Nov 25, 2014 2:52 pm    Post subject: Reply with quote
Tested with $Regfile = "usb1286.dat", then the first test-code, then a 70kByte data block, then the second test-code.
This has the effect, that Bascom-internal code is placed into second page, first test-code runs on first page, second test-code on second page.
All tests well, no problems.
Mrshilov
Bascom LCD Guru
PostPosted: Mon Dec 01, 2014 4:06 am    Post subject: Reply with quote
I found mistake in my code. Now all works fine.
Topic may be deleted.
