Fast library for SSD1963 LCD
Goto page 1, 2, 3  Next
Mrshilov
Bascom LCD Guru
PostPosted: Mon Feb 03, 2014 2:09 am    Post subject: Fast library for SSD1963 LCD Reply with quote
Library for SSD1963 LCD with 16-bit interface:
[/URL]
LCD is 3/5V compliant.
Library works in Submode = New, so its very easy to include in project and unused Subs are not compiled to save memory space.
Also to save space you may use reduced Fonts, like Font36x56 in example. It has only digits, placed at position 33...42. To correct this shift simply use Digit_font = 1.
Any Fons may be included via $include. Supports both types of BASCOM Fonts - "Color" and "B&W".
You can display 8-bit (BGC) and 16 bit (BIN) pictures. Also 16 bit pictures can be loaded from SPI-Flash ROM. To prepare bin-file from bmp, gif, jpg, wmf, emf, ico I wrote special program Pic2Bin.
Library is fast. I specially made it to work quickly. In this video test program working at 8MHz. However, display resolution is 800x480 and its better to use 16MHz or 32MHz (Atxmega).
Video - http://youtu.be/U9kgDOa79MY
Based on Mr.Six1 sources.
enniom
PostPosted: Wed Feb 05, 2014 5:48 am    Post subject: Reply with quote
Thank you MrShilov for your hard work and sharing the Bascom code for the SSD1963 color display.
I have not programmed color displays with XMega chips.
1. Do you have an idea of how difficult it would be to modify the code posted here to work on XMega?
2. Would the touch-screen routines be similar to the ones posted for the SSD1289 display?
Any help or advice you have would be greatly appreciated. Based on your (or others) feedback, I will decide to purchase additional XMega chips.
PostPosted: Wed Feb 05, 2014 8:06 am    Post subject: Reply with quote
well done ! This is a big display ! And it still works smooth. Love the YT videos Very Happy
I had no idea there were so many different graphical chips. Keep up the great work.
PostPosted: Wed Feb 05, 2014 8:09 am    Post subject: Reply with quote
this code need small adjustments for xmega.
For example :
Dim Color_h_ssd1963 As Iram Byte At 22
Dim Color_l_ssd1963 As Iram Byte At 21
These are registers R21 and R22. The xmega can not linear address these registers. But you can use bascom SETREG statement. Or use some asm with STS.
Mrshilov
Bascom LCD Guru
PostPosted: Wed Feb 05, 2014 4:15 pm    Post subject: Reply with quote
As Mark say, "this code need small adjustments". The simplest way is to change:
to:
Dim Color_h_ssd1963
Dim Color_l_ssd1963
SSD1289 and SSD1963 displays use the same touch chips XPT2046. So routines is compatible, but need to correct X and Y coefficients due to screen size.
Evert :-)
PostPosted: Wed Feb 05, 2014 9:25 pm    Post subject: Reply with quote
Always nice to see that big parts of my code is re-used.
Thanks for sharing your code.
sasha_1973
PostPosted: Fri Feb 07, 2014 2:16 am    Post subject: Reply with quote
Evert :-)
PostPosted: Fri Feb 07, 2014 12:30 pm    Post subject: Reply with quote
Sorry i can't read that, i'm not that good in my Russian.
It was meant as compliment, i'm glad that a lot of people using (parts) of my code and share the code that they made also with the Bascom community.
sasha_1973
PostPosted: Fri Feb 07, 2014 3:15 pm    Post subject: Reply with quote
Evert :-)
PostPosted: Fri Feb 07, 2014 4:34 pm    Post subject: Reply with quote
Link works fine, check your browser settings or use a other browser.
sasha_1973
PostPosted: Fri Feb 07, 2014 5:51 pm    Post subject: Reply with quote
GrainyPCB
PostPosted: Mon Feb 17, 2014 10:09 pm    Post subject: Reply with quote
Thank you Mrshilov and everyone else for sharing your hard work! This library is great, much faster than previous examples. I am running an ER-TFTM070-4 display on ATMega645A @ 16MHz. I swapped Mrshilov's initialization values for my own (based on the sample code provided by the manufacturer) and it works well with one problem:
Display is upside down and color is in BGR mode, but control register Set Address Mode 36h has no effect on the screen! In my old routine I can change Set Address Mode 36h to flip display in any orientation and change the color mode. With Mrshilov's routine, no change! Only difference I can tell is Mrshilov uses submode=new while my working routine uses old submode.
I could fix this by flipping the screen around and changing the color constants to BGR, but that feels like a hack job Razz. Does anyone have some insight?
Thanks again for sharing.
' Init display
Sub Display_init
Res_disp = 0 : Waitms 25 : Res_disp = 1                     'Hardware Reset
Ssd1963_select_reg &H01                                     'Software reset
Waitms 10
Ssd1963_select_reg &HE2                                     'PLL multiplier, set PLL clock to 120M
Ssd1963_write_data &H0023                                   'N=0x36 for 6.5M, 0x23 for 10M crystal
Ssd1963_write_data &H0002
Ssd1963_write_data &H0004
Ssd1963_select_reg &HE0
Ssd1963_write_data &H01                                     'start PLL
Waitms 1
Ssd1963_write_data &H03                                     'LOCK PLL
Waitms 5
Waitms 10
Ssd1963_select_reg &HE6                                     'Set PCLK Pixel Clock frequency
Ssd1963_write_data &H33
Ssd1963_select_reg &HB0                                     'Set the LCD panel mode (RGB TFT or TTL)
Ssd1963_write_data &H20
Ssd1963_write_data &H03                                     'horizontal size 799 high Byte
Ssd1963_write_data &H1F                                     'horizontal size 799 low Byte
Ssd1963_write_data &H01                                     'vertical size 479 high Byte
Ssd1963_write_data &HDF                                     'vertical size 479 low Byte
Ssd1963_write_data &H00                                     'RGB
'Ssd1963_write_data &H2D                                    'BGR
Ssd1963_select_reg &HB4                                     'Set Horizontal Period  B4
Ssd1963_write_data &H04                                     'High byte of horizontal total period (display + non-display) in pixel clock HT
Ssd1963_write_data &H1F                                     'Low byte of the horizontal total period (display + non-display) in pixel clock  HT
Ssd1963_write_data &H00                                     'High byte of the non-display period between the start of the horizontal sync (LLINE) HPS
Ssd1963_write_data &HD2                                     'Low byte of the non-display period between the start of the horizontal sync (LLINE) HPS
Ssd1963_write_data &H00                                     'Set the horizontal sync pulse width (LLINE) in pixel clock. Width = (HPW + 1) pixels
Ssd1963_select_reg &HB6                                     'vsync
Ssd1963_write_data &H02                                     'set vt
Ssd1963_write_data &H0C
Ssd1963_write_data &H00                                     'set vps
Ssd1963_write_data &H22
Ssd1963_write_data &H00                                     'set vpw
Ssd1963_write_data &H00                                     'set fps
Ssd1963_select_reg &HB8                                     'GPIO Configuration
Ssd1963_write_data &H0F                                     'GPIO is controlled by host GPIO[3:0]=output   GPIO[0]=1  LCD ON  GPIO[0]=1  LCD OFF
Ssd1963_write_data &H01                                     'GPIO0 normal
Ssd1963_select_reg &HBA
Ssd1963_write_data &H01                                     'GPIO[0] out 1 --- LCD display on/off control PIN
Ssd1963_select_reg &H36                                     'Set the read order from frame buffer to the display panel
Ssd1963_write_data &H09                                     'BGR
Ssd1963_select_reg &H3A                                     'RGB Format 565
Ssd1963_write_data &H50
Ssd1963_select_reg &HF0
Ssd1963_write_data &H03                                     'Set Pixel data format 16Bit
Ssd1963_select_reg &HBC                                     'Post Processor
Ssd1963_write_data &H40                                     'contrast
Ssd1963_write_data &H40                                     'brightness
Ssd1963_write_data &H40                                     'saturation
Ssd1963_write_data &H01                                     'enable/disable
Waitms 5
Ssd1963_select_reg &H29                                     'Display ON
Ssd1963_select_reg &HBE                                     'Set PWM for B/L
Ssd1963_write_data &H06
Ssd1963_write_data &H80
Ssd1963_write_data &HF0
Ssd1963_select_reg &HD0                                     'Set DynamicBacklightControl Configuration
Ssd1963_write_data &H0D
End Sub
enniom
PostPosted: Fri Feb 21, 2014 3:15 am    Post subject: Reply with quote
Hello Mark, MrShilov, GrainyPCB, (and others)
Trying to make the SSD1963 (480x272) LCD work with a XMEGA192A3 using the library INC file posted by MrShilov.
After spending quite some time, I cannot see any function on the LCD.
The pin-out for the LCD and my modifications to the library to accommodate the XMEGA are attached.
Any help or suggestions would be greatly appreciated - and also what to do with pins F_CS and REST.
Ennio
PostPosted: Fri Feb 21, 2014 10:22 am    Post subject: Reply with quote
try to use some other port than portA. i have pulled some hairs a week ago when doing an oled driver. the odd thing was that porta worked, and that i could toggle all pins, but that for some reason it did not work as normal. had no time to check on that, but using another port worked out fine.
further i can recommend to use a virtual port for these signals. config vport. for data this is not required but for control signals it is best.
if that does not work, i can have a look at the code.
enniom
PostPosted: Fri Feb 21, 2014 3:11 pm    Post subject: Reply with quote
Hello Mark,
Somewhere between your advice NOT to use PORTA, re-reading MAK3's AN#192 for Virtual Ports and comparing my code to that of the WIKI 7 Inch SSD1963 Display, I now have the display working.
But, as pointed out by GrainyPCB, my display too shows text to be upside-down/backwards. Maybe these are Chinese right-to-left displays??? ;)
Thanks for your help and motivation.
Ennio
Page 1 of 3
