ADC noise (solved)
Meister
PostPosted: Sat Nov 22, 2014 6:10 pm    Post subject: ADC noise (solved) Reply with quote
Solved! Although the periphery was disconnected from the PWM outputs,
the smoothing network was still connected resulting in power supply glitches when changing N.
I am having a strange problem reading the ADC of Attiny841.
In the following code part I chose between increasing N via the For...Loop or setting N=100.
The ADC mode is free running.
Top:
For N = 1 To 255
         N=100         '<----Chose remarking or not remarking this statement
         Ocr2a = N
         Ocr2b = N
         Waitus 50
         W = 0
         W1 = Adc
         If W1.9 = 1 Then W1 = W1 Or &HFE00
         W = W + W1
         Print #1 , W ; Chr(13);
Goto Top
Remarking the line N=100 the ADC values fluctuate by about 50 LSB.
Not remarking the line N=100 the ADC fluctuates only by about 5 LSB.
Is there any idea what might cause this problem (and how to fix it)?
Regards, Meister
