MISO internal name
Mrshilov
Bascom LCD Guru
PostPosted: Sun Nov 16, 2014 4:22 pm    Post subject: MISO internal name Reply with quote
I try to use Din pin (MISO) in SPISOFT as "BUSY" like this:
Bitwait Miso , Set
But "MISO" name in this case not valid. Is there an internal BASCOM name of this pin?
PostPosted: Mon Nov 17, 2014 9:31 am    Post subject: Re: MISO internal name Reply with quote
... nor in any other case. Since when do you expect Bascom to know all the pin-names of the controller?
But even it would, what do you expect that the name MISO is linked with, the input Pin-, or the output Port-Register?
If you want to configure MISO in one place of your code for the sake of maintainability, you may try an Alias.
Mrshilov
Bascom LCD Guru
PostPosted: Mon Nov 17, 2014 2:02 pm    Post subject: Reply with quote
I need to know internal name of "MISO" ("Din") maked with this string:
Config Spi = Soft , Din = Pind.2 , Dout = Portd.4 , Ss = None , Clock = Portd.1
Of course I can use "Alias" or "Pind.2", but it will be better to do it once.
PostPosted: Mon Nov 17, 2014 2:46 pm    Post subject: Reply with quote
Did you try?:
Miso Alias Pind.2
Config Spi = Soft , Din = Miso , Dout = Portd.4 , Ss = None , Clock = Portd.1
That would be done then only one time.
If you want to see Bascom's internal variables, check its compiler options. As far I saw, there is no one for "Din"
PostPosted: Wed Nov 19, 2014 12:20 am    Post subject: Reply with quote
I will add _MISO. If you want a beta you know where to find me Very Happy
Mrshilov
Bascom LCD Guru
PostPosted: Wed Nov 19, 2014 12:58 am    Post subject: Reply with quote
This is good.
As I understand, in current version there is no name for MISO in SPISOFT. May be it present for HW SPI? Or may be it can be read from def-file?
PostPosted: Wed Nov 19, 2014 10:08 am    Post subject: Reply with quote
it is not present for hardware either. the compiler uses info from the dat file.
