How can I use lcd witch s6b1713 controller?
hamedhamedi
PostPosted: Sat Nov 08, 2014 3:52 pm    Post subject: How can I use lcd witch s6b1713 controller? Reply with quote
How can I use this LCD in bascom avr:MTB-233
its controller is s6b1713
and the link to the picture of this lcd is: http://www.picproje.org/index.php?topic=28384.0
can i use command of config graph lcd to use this lcd?
i select this lcd because of low power consumption and i use my device in battery powered always.[/url]
is any difference between ks107 controller command and s6b1713 commands?
(BASCOM-AVR version : 2.0.7.7 , Latest : 2.0.7.7 )
Deanus
PostPosted: Mon Nov 10, 2014 8:26 pm    Post subject: Reply with quote
Hi Hamedhamedi,
Check this site, he talks about is being equivalent to another type ST7565 & similar to SED1520 .
Regards
Dean
http://siwawi.bauing.uni-kl.de/avr_projects/glcd2/
hamedhamedi
PostPosted: Tue Nov 11, 2014 7:35 am    Post subject: Reply with quote
thank you Deanus
it mean i can use $lib "glcdSED1520.lbx" instruction in my code and use this lcd or no?
Regards
Paulvk
PostPosted: Tue Nov 11, 2014 8:10 am    Post subject: Reply with quote
Hello hamedhamedi
You could try it to see if it works, comparing the data sheets will give you a very good idea
Or if he is willing to, Mrshilov (our resident LCD wizard) may make one if you can send him a LCD and data on the chip to work with,
Regards Paul
hamedhamedi
PostPosted: Tue Nov 11, 2014 10:05 am    Post subject: Reply with quote
thank you every body
i found that mtb233 also has another type of controller .some website sell mtb-233 with ht0313a controller.
it seems that ht0313a is similar to s6b1713 in datasheet.
i want to find a library for display picture on this lcd.
thanks
benoit
PostPosted: Tue Nov 11, 2014 11:09 am    Post subject: KS0713 AND HT0313 Reply with quote
HI
INSTRUCTION TABLE IS SAME FOR KS0713 AND HT0313
it should work
