Using Compiler Simulation
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-8051
MedhatSaber
PostPosted: Thu Oct 30, 2014 3:29 pm    Post subject: Using Compiler Simulation Reply with quote
Dear All my friends
Can i use the bascom8051 ide V2.0.14 simulation (Program --- Simulate ) for calculate an accurate time
Thanks and best regards
MedTronic
PostPosted: Thu Oct 30, 2014 8:47 pm    Post subject: Reply with quote
it depends on the chip you use and what you want to simulate. all normal 8051 processors instruction cycles are counted accurate.
but some 8051 chips have different cycles for different instructions (compared with the default). in such case the actual code will be quicker than in the simulator.
and last : some hardware requires time to execute while the simulator only counts the cycles of the instructions.
Just give it a try and compare with the real app.
MedhatSaber
PostPosted: Fri Oct 31, 2014 3:09 pm    Post subject: How this can be happen Reply with quote
Dear My friend
Test the next two program and please explain how this can be happen ?
at the simulator the result give a different time .... how ?
' MedTronic Programmable Timer
' @Medtronic
' From 11\11\2006
' To 11\11\2006
'* Auther:Eng Medhat Saber
'* Email :EngMedhatSaber@hotmail.com
'* :EngMedhat_Saber@yahoo.com
'* Program:
'* This program is a programmable timer
'$sim
'$nosp
'$noinit
$regfile "8052.dat"
$crystal = 12000000
Dim Counte0 As Byte
Config Timer0 = Timer , Gate = Internal , Mode = 2
'Timer0 = Timer : timer0 operates as AutoReload
'Gate = Internal : no external gate control
'Mode = 1 : 8-bit auto reload (default)
'Disable Serial
Config Debounce = 20
Const Xtal = 12000000
Const T0_clk = Xtal / 12
Const T0_rate = 2 '0.5 sec
Const T0_reload = &H06 'int(65536-(T0_clk/T0_rate)+0.5)
On Timer0 Timer_0_int
Load Timer0 , 200 'when the timer reaches 200 an interrupt will occur
Priority Set Timer0 'highest priority
Enable Interrupts 'enable the use of interrupts
Enable Timer0 'enable the timer
Start Timer0
Rem Setting Of Priority
Main:
Timer_0_int:
inc Counte0
If Counte0 = 10 Then
Counte0 = 0
CPL P1.0
Code No 2
' MedTronic Timer1Mode2 Simulation
' @Medtronic
' From 30\10\2014
' To 30\10\2014
'* Program:
'* This program is a Timer1Mode2 Simulation
'$sim
'$nosp
'$noinit
$regfile "8052.dat"
$crystal = 12000000
Dim Counte1 As Byte
Config Timer1 = Timer , Gate = Internal , Mode = 2
'Mode = 2 : 8-bit auto reload (default)
'Disable Serial
On Timer1 Timer_1_int
Load Timer1 , 200 'when the timer reaches 200 an interrupt will occur
Priority Set Timer1 'highest priority
Enable Timer1 'enable the timer
Start Timer1
Main:
Timer_1_int:
inc Counte1
If Counte1 = 10 Then
Counte1 = 0
CPL P1.0
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM-8051 All times are GMT + 1 Hour
