[problem] program arduino uno r3 at win7
MIKRO_MAN
PostPosted: Tue Jul 21, 2015 3:53 pm    Post subject: [problem] program arduino uno r3 at win7 Reply with quote
i have problem to program arduino uno r3 in win7 32bit
i make all setting correctly
and working good at winxp in another pc
i use this seeting
http://wiki.mcselec.com/Getting_started_with_Arduino_UNO
c:\arduino-1.0.3\hardware\tools\avr\etc\
-v -F -C c:\arduino-1.0.3\hardware\tools\avr\etc\avrdude.conf -p m328p -P com8 -c arduino -b 115200 -Uflash:w:{FILE}:a
baud 115200
use bascom 2.0.7.5
at winxp good working
at win7
when i send code to board (tx and rx ) led flasher and code not Execution
PostPosted: Wed Jul 22, 2015 2:05 pm    Post subject: Reply with quote
I have the same config W7 32bits
here you will find the step by step solution. you can use Arduino as other AVR with the programmer option Arduino much more simple than DUDE
[url]
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=12472[/url]
bon courage
JP Wink
MIKRO_MAN
PostPosted: Thu Jul 23, 2015 10:00 pm    Post subject: Reply with quote
Duval JP wrote:
[url]
bon courage
JP Wink
step by step pdf [getting started with Arduino and bascom]
but the same problem
led tx && rex oscillation but code does not execuit and cant detect uc
MIKRO_MAN
PostPosted: Fri Jul 24, 2015 1:27 am    Post subject: Reply with quote
i find new problem may be this is main reasons for may problem
i cant find hex file in folder of project ??
PostPosted: Fri Jul 24, 2015 9:15 am    Post subject: Reply with quote
Fist with arduino IDE
Did you test the blink.ino program from Arduino sample ? Yes ? then
with bascom IDE
Do you have set the correct output options in the programmer setting ? I mean Hex and Bin files
Yes ? then try :
' ARDUINO-UNO V3.BAS
' (c) 1995-2011, MCS Electronics
' This is a sample file for the Mega328P based ARDUINO board
' Select Programmer 'ARDUINO' , 115200 baud and the proper COM port timeout 200
$regfile = "M328pdef.dat"
Config Clockdiv = 1 ' either use this or change the divider fuse byte
Config Pinb.5 = Output
'( alternative test
Waitms 200
Toggle Portb.5
Set Portb.5
Reset Portb.5
End 'end program
JP
MIKRO_MAN
PostPosted: Fri Jul 24, 2015 5:42 pm    Post subject: Reply with quote
with bascom IDE
Yes ? then try :
'( alternative test
Waitms 200
Toggle Portb.5
Set Portb.5
Reset Portb.5
End 'end program
JP
first _ i solve problem
I do not know how to implement the solution to the problem Very Happy
but i change bascom version
and use setting
when i use code [config portb.5 = output __ not working]
but [config pinb.5 = output __ working good]
and hex file working good
thanks for the help
i need help about connect hc_05 bluetooth module by bascom avr [expermint or Tutorials]
or make new topic for this ؟؟
PostPosted: Fri Jul 24, 2015 5:53 pm    Post subject: Reply with quote
did you have looked out with the search tools in this forum ? I have seen a lot of bluetooth subject
JP
